PassKey II EmptyWed Oct 19, 2022 1:27 pm by scot
PassKey II EmptyTue Oct 18, 2022 8:58 pm by silverfox103
PassKey II EmptyTue Sep 28, 2021 11:01 pm by silverfox103
PassKey II EmptyFri Sep 24, 2021 9:53 am by ElKy
PassKey II EmptySun Sep 19, 2021 6:22 pm by black blur 96
PassKey II EmptySun Jun 20, 2021 11:37 am by scot
PassKey II EmptyFri Jun 11, 2021 10:41 am by scot
PassKey II EmptyWed Jun 09, 2021 9:41 pm by Chris Klein
PassKey II EmptyWed Jun 02, 2021 9:02 pm by Chris Klein
 PassKey II
5 posters
nailhead445
PassKey II Empty
PostSubject: PassKey II   PassKey II EmptySat Nov 05, 2011 9:16 pm
PassKey II system acting up on my '96 Roadie. Just lookin' for free advice. Intermittently, it won't recognize the key (Either one) and goes into its 3 minute lockdown, then resets. Then you try again. Maybe it works, maybe it doesn't. If it starts, there's no more problems during operation until the next time. I've read a whole bunch of stuff online. Seems like the two small wires coming from the ignition lock cylinder are the usual suspects. May look at that tomorrow if I feel energetic. Has anyone out there built the circuit that "newrockies.com" sells to bypass the system? He claims that it goes beyond merely substituting the appropriate resistor in the circuit. As per usual, I'm lookin' for the easy/cheap way out.
YachtDriver
YachtDriver
PassKey II Empty
PostSubject: Re: PassKey II   PassKey II EmptySat Nov 05, 2011 11:19 pm
Been there done that. My 95 did this to me several times. 96 uses the same system. So get out the OHM meter. Take the key and put the terminals on the resistor pellet. This will give you your value. Head on over to RadioHack and buy some resistors. Problem solved.
Read this article on the Yahoo forum.
This is how I got around this issue.
http://www.buickforums.com/forums/showthread.php?t=5804
Worked like a charm.
Another good article.
http://www.sofasst.com/pass_key_fault_fix.htm
I think I had more money into the solder and tape than the cost of the resistors.
PassKey II Empty
PostSubject: Re: PassKey II   PassKey II EmptySun Nov 06, 2011 4:31 am
heres the way to bypass the system.
PassKey II Empty
PostSubject: Re: PassKey II   PassKey II EmptySun Nov 06, 2011 8:21 am
Bingo. If I ever got a 94+ car this would be the first thing I do, even if the passkey is working fine.
PassKey II Empty
PostSubject: Re: PassKey II   PassKey II EmptySun Nov 06, 2011 9:32 am
PassKey II Empty
PassKey II
» Vats/passkey delete
