| should I tune my car? | |
chapel
| Subject: should I tune my car? Mon Oct 31, 2011 9:16 pm | |
| I was curious if there's any benefit to getting a tune on a stock engine? I've always tuned my stock engines to at least get some advance in the spark to get some more efficiency and throttle response. | |
| Subject: Re: should I tune my car? Mon Oct 31, 2011 9:25 pm | |
| Yes, Yes Yes!
http://pcmperformance.com/
Change VIN
=Disable VATS
=Change RPM or speed limiters
=Speedometer recalibration for axle ratio or tire changes
=POWER TUNE = spark timing and fuel remapped for more hp/torque
=ECONOMY TUNE = improved mpg
=High or low octane programming
=Lower fan turn-on temp settings
=Remap shift patterns for performance or towing
=Remap shift pressures for firmer shifts
=Modify TCC lockup speeds for performance or towing
Compensate for high stall TC
Switch automatic to manual transmission or vice versa
Compensate for displacement changes
Adjust for different fuel injectors
Adjust for larger throttle body
Compensate for cam changes for driveability and power
=Delete emission functions and codes (EGR, AIR pump, EVAP, O2s, etc.)
=Program for MAFless operation = speed density mode
=Delete various nuisances (SKIP SHIFT, traction control ,etc.)
Remove or add torque management
Delete other miscellaneous functions and trouble codes (A/C, oil level, etc.)
Nitrous, forced induction and more...
Things marked = at the begining, are ones that you can do to a stock motor without any real mods.
Or there are some on here that can tune as well.
chapel
| Subject: Re: should I tune my car? Mon Oct 31, 2011 9:29 pm | |
- Yes, Yes Yes!
Change VIN why would I want to change my VIN? - IMPALADAKID wrote:
- Disable VATS
what's VATS? - IMPALADAKID wrote:
- Change RPM or speed limiters
Speedometer recalibration for axle ratio or tire changes Oooo - IMPALADAKID wrote:
- POWER TUNE = spark timing and fuel remapped for more hp/torque
Lower fan turn-on temp settings Do they have selectable tunes or is it one or the other? - IMPALADAKID wrote:
- Remap shift patterns for performance or towing
Program for MAFless operation = speed density mode MAFless? what other changes do you need to make? is there an existing MAP sensor that's got a high enough resolution to handle it or do you need an aftermarket sensor? - IMPALADAKID wrote:
- Remove or add torque management
so, basically... yes, I should... I kinda wish I had OBD2 so I could flash it myself | |
| Subject: Re: should I tune my car? Tue Nov 01, 2011 2:22 pm | |
| Subject: Re: should I tune my car? Tue Nov 01, 2011 3:34 pm | |
- No.
But should he Dyno it? | |
| Subject: Re: should I tune my car? Tue Nov 01, 2011 3:42 pm | |
- No.
But should he Dyno it? No | |
| Subject: Re: should I tune my car? Tue Nov 01, 2011 4:16 pm | |
chapel
| Subject: Re: should I tune my car? Tue Nov 01, 2011 8:35 pm | |
| did someone get a bad tune and a blow up? | |
| Subject: Re: should I tune my car? Tue Nov 01, 2011 9:00 pm | |
| OBD2 SUCKS ASS. |
chapel
| Subject: Re: should I tune my car? Tue Nov 01, 2011 9:02 pm | |
| oh I have OBD1... so no big deal. I was wondering about those 'DIY' tuning kits. I think I saw something called TunerCAT or something?
| Subject: Re: should I tune my car? Tue Nov 01, 2011 10:29 pm | |
| I bought the cable and used tunerCAT before, not too hard to use. I did only change fan temps and adjust my speedo though. Looks like you can do some fun stuff in there. | |
chapel
| Subject: Re: should I tune my car? Wed Nov 02, 2011 9:56 am | |
| - 95brmw wrote:
- I bought the cable and used tunerCAT before, not too hard to use. I did only change fan temps and adjust my speedo though. Looks like you can do some fun stuff in there.
Is TunerCat locked to your ECU when you use it or if someone I know has TunerCAT and the cable, can they tune my car? | |
| Subject: Re: should I tune my car? | |
