 running issues
PostSubject: running issues   Sun Oct 23, 2011 9:43 pm
driving the girls car for a few days and it has a hesitation when u first get on it and both fans kick on 5-10 after u start it.. iam thinking coolent sensor? just wanted to rum it by everyone. it goes fine at full throttle
PostSubject: Re: running issues   Sun Oct 23, 2011 9:44 pm
its a 94 ss if that matters
PostSubject: Re: running issues   Sun Oct 23, 2011 9:48 pm
sounds right to me.
PostSubject: Re: running issues   Mon Oct 24, 2011 6:44 pm
alright. i changed the coolent sensor and its still doin it.. the gas milage is WICKED BAD!!! so i played around with some wires and i touched the wires on the coolent sensor plug and the car shut off.. so i put a new plug on it from another harness and thats fine now. but still getting check engine light and fans are kicking on 5 secs. after start up. I NEED IDEAS!! confused confused
PostSubject: Re: running issues   Mon Oct 24, 2011 7:37 pm
I know when the MAf is unplugged the fans come on I'd check that wiring
PostSubject: Re: running issues   Mon Oct 24, 2011 7:40 pm
i played around with that plug as well. didnt change tone.
PostSubject: Re: running issues   Mon Oct 24, 2011 7:52 pm
Did you check the fuses?
I know a CEL will turn on the fans.
Lots of possibilities for CEL
I'll get to my FSM asap (daughter has BBall tryouts tonight sorry)
PostSubject: Re: running issues   Mon Oct 24, 2011 7:55 pm
ya its a 94 so my obd2 scanner dont work on it. ill have to find a way to check the codes
PostSubject: Re: running issues   Mon Oct 24, 2011 7:58 pm
Could still be a bad temp sensor.
PostSubject: Re: running issues   Mon Oct 24, 2011 8:00 pm
the one on the side of the block?
PostSubject: Re: running issues   Mon Oct 24, 2011 8:05 pm
Yeah, if they are made like the TBI ones it sometimes takes 2-3 before you get a good one.
PostSubject: Re: running issues   Mon Oct 24, 2011 8:10 pm
No. That is for the guage only. I would also look at the EGR solenoid. The reason you are getting bad gas mileage is that the system is staying in open loop, which is causing the pcm to command too much fuel since in open loop, the pcm does not adjust fuel based on o2 sensor info. MAF is another place to look.
PostSubject: Re: running issues   Mon Oct 24, 2011 8:13 pm
i have a maf and a egr from the other lt1 ill play the swap game tomorrow night before i throw money at new parts
PostSubject: Re: running issues   Mon Oct 24, 2011 8:15 pm
Oh come on man, its fun! I did it for a month straight! Wink
PostSubject: Re: running issues   Mon Oct 24, 2011 8:17 pm
But I am sure he wants the car fixed while the thread is still on the first page. Wink
PostSubject: Re: running issues   Mon Oct 24, 2011 8:18 pm
That hurts man. Crying or Very sad
PostSubject: Re: running issues   Mon Oct 24, 2011 8:21 pm
But funny. jocolor
PostSubject: Re: running issues   Mon Oct 24, 2011 8:23 pm
But funny. jocolor
I laughed!
PostSubject: Re: running issues   Mon Oct 24, 2011 10:51 pm
Is this CEL new?
running issues
» Babe Bee Running Issues
» New tubes, ST-70 transformers running hot
» Running Lean
» Crikey! Back issues
» Men Running Around in Their B.V.D.s
