| where the hell is the remote programmer? | |
chapel
| Subject: where the hell is the remote programmer? Sat Oct 22, 2011 1:20 pm | |
| So, I got a new remote. I went to jump the 'programming connector' but I couldn't find it. it's supposed to be the only cable not connected to anything, right? I assume that box is the receiver. | |
| Subject: Re: where the hell is the remote programmer? Sat Oct 22, 2011 10:50 pm | |
| Not sure about the jumper, but that is the box for sure
Doug | |
chapel
| Subject: Re: where the hell is the remote programmer? Sat Oct 22, 2011 11:00 pm | |
| someone on longroof told me to look in the D-pillar trim. | |
| Subject: Re: where the hell is the remote programmer? Sat Oct 22, 2011 11:15 pm | |
| It should be a pigtail hanging near that box. Follow the wire from the small connector. |
| Subject: Re: where the hell is the remote programmer? Sat Oct 22, 2011 11:28 pm | |
| I thought you programmed it by jumping terminals in the DLC? | |
chapel
| Subject: Re: where the hell is the remote programmer? Sat Oct 22, 2011 11:33 pm | |
- I thought you programmed it by jumping terminals in the DLC?
all the bits and bobbles I've seen show like a cable hanging out near the tail light. | |
| Subject: Re: where the hell is the remote programmer? Sun Oct 23, 2011 6:27 am | |
| well if it turns out to be a bad reciever here is the fix.
http://www.w-body.com/content.php/201-Repair-for-non-functional-keyless-entry | |
YachtDriver
| Subject: Re: where the hell is the remote programmer? Sun Oct 23, 2011 11:48 pm | |
| I had to program the fob on my first wagon. The connector was near where the shock for the rear window connected to the D pillar. You have to peel the plastic trim back from the rubber gasket on the D pillar on the drivers side. That's where it was for my old wagon. (95 roadmaster) It's a small black connector with just enough room to jam a paperclip into it. As soon as I pulled the plastic back it popped out.
Hope this helps. I don't have a picture handy right now. | |
| Subject: Re: where the hell is the remote programmer? Mon Oct 24, 2011 5:50 am | |
chapel
| Subject: Re: where the hell is the remote programmer? Mon Oct 24, 2011 6:34 am | |
| I found it up in the d pillar trim | |
| Subject: Re: where the hell is the remote programmer? | |
