| Rearends | |
| Subject: Rearends Tue Oct 25, 2011 7:35 pm | |
| So I put the rearend in the 95ss tonight, it's no good. So I need to try again. I have a civi 94 lt1Car rearend, posi, 293 or something gear drum brakes. Can I assume the brakes from the SS and everything will fit? I have seen people talk about the swap over, but never done it. If this doesn't work I'm gonna snap.
Thanks. | |
| Subject: Re: Rearends Tue Oct 25, 2011 7:39 pm | |
| yea, housing ends are the same between the two rears as long as they are both 8.5s
| Subject: Re: Rearends Tue Oct 25, 2011 7:40 pm | |
| - bfurches wrote:
- yea, housing ends are the same between the two rears as long as they are both 8.5s
Yeah, the only 91+'s that have the 7.5 are the 2:56 cars. | |
| Subject: Re: Rearends Tue Oct 25, 2011 7:41 pm | |
| Glen You just pull the axles from both rear ends, but keep the axles with the rears they came with. Now just unbolt the backing plates and swap everything over. Very easy. |
| Subject: Re: Rearends Wed Oct 26, 2011 7:25 am | |
| Thank you all. I'm gonna try this rearend. | |
| Subject: Re: Rearends Wed Oct 26, 2011 7:39 am | |
| Does this apply to swapping the disc setup from a sedan axle to a wagon axle? | |
| Subject: Re: Rearends Wed Oct 26, 2011 2:52 pm | |
| - No Moa wrote:
- So I put the rearend in the 95ss tonight, it's no good. So I need to try again. I have a civi 94 lt1Car rearend, posi, 293 or something gear drum brakes. Can I assume the brakes from the SS and everything will fit? I have seen people talk about the swap over, but never done it.
Thanks. whats bad (wrong) with the rear end? | |
| Subject: Re: Rearends Wed Oct 26, 2011 2:58 pm | |
| Back cover was covered in small pinholes, no oil in it at all. Everything in there was covered in dust and dirt. It's my own fault. | |
| Subject: Re: Rearends Wed Oct 26, 2011 3:44 pm | |
| Subject: Re: Rearends Wed Oct 26, 2011 3:50 pm | |
| Thats my whole month. Changed the mobil 1 in the rearend of my truck, the night before the roundup, realized today I never put the limited slip lube in te oil for the posi. Guess what, got some nice clutch chatter now. Fak! | |
| Subject: Re: Rearends Wed Oct 26, 2011 4:13 pm | |
| I would still add the posi fluid! | |
| Subject: Re: Rearends Wed Oct 26, 2011 4:29 pm | |
| You just did. My gm guy said it should be ok. I haven't run it to much. Lol | |
| Subject: Re: Rearends Wed Oct 26, 2011 6:32 pm | |
| Subject: Re: Rearends | |
| Rearends | |
