Yesterday at 9:21 pm by MASShole9C1
 Will A '93 RMW ECM Work In My Caprice
PostSubject: Will A '93 RMW ECM Work In My Caprice   Tue Oct 11, 2011 3:42 pm
in my quest to fix my wagon I snagged an ECM from a '93 RMW at the JY. It is a 350/ 3:23/posi/ air ride car just like mine. Will the ECM be the same between the two cars or will I need to reprogram it?
PostSubject: Re: Will A '93 RMW ECM Work In My Caprice   Tue Oct 11, 2011 5:13 pm
I believe it should be the same thing, others may chime in w/additional info.
It will work. Arrow
PostSubject: Re: Will A '93 RMW ECM Work In My Caprice   Tue Oct 11, 2011 5:14 pm
It will work. Arrow
Schweet! Thanks Matt, Billy Arrow
PostSubject: Re: Will A '93 RMW ECM Work In My Caprice   Tue Oct 11, 2011 6:09 pm
At this point, it probably wouldn't hurt to try it.
PostSubject: Re: Will A '93 RMW ECM Work In My Caprice   Tue Oct 11, 2011 6:37 pm
ECM was a bust. Still same symptoms so my ECM is fine. At least I can get my $30 back from the jy! Laughing
PostSubject: Re: Will A '93 RMW ECM Work In My Caprice   Tue Oct 11, 2011 7:05 pm
The way you've been going....keep it. Cool
» Body shops for rust work
» dynaco sca-35 phono amplification on right speeker doesn't work
» got bored at work
» Possible Camille Naudot Early work Nouveau vase ????
