| My to-do list | |
+8toomanytoyz 1984twodoor Ironfistdog LandMaster mp775 MASShole9C1 96Brougham chapel 12 posters |
chapel
| Subject: My to-do list Sun Sep 25, 2011 11:14 pm | |
| Align front end oil change Align headlights and possibly upgrade bulbs. I don't suppose there's any projector headlights for these cars? Stock lights are REALLY dim. Clean interior and spray bomb (smokers) detail exterior. See if I can cut some gloss into the paint. Install a radio (no CD player and the tape deck is jammed) secure drivers side door panel (seems like it's missing some clips or a bolt or something, it moves when you open the door.) re-attach cowl piece (in the trunk for some reason) spare driver's side mirror in the trunk, need to figure out if there's a problem there Shifter stalk has no spring to it... loose and floppy. is this fixable? Engine has all the stock intake parts. I see people remove the 'home plate' and the baffle between the throttle and the MAF. is there a write up for this? what does it accomplish? Is it wise to do a cone filter or is the stock box fine? Do a brake stand... just to try Other questions: after the car is shut off, there's a pump running somewhere in the engine bay for 5 minutes after I shut it down. Paul thought it was the air pump for the suspension? Is this normal or does this indicate a leak? | |
| Subject: Re: My to-do list Sun Sep 25, 2011 11:46 pm | |
| I didnt think it was the air compressor, I know it is. This is normal due to a leaking shock(as I explained). It wont kill the battery, you could either replace the shocks with new air shocks, or simply unplug the compressor. Drivers mirror is cracked in half(the outer housing) as I showed you, I bought that black mirror off 96slowss to replace it, just never got around to it..
You can delete home plate with a hockey puck, and build yourself an intake out of pvc piping from Lowes. Throw a cone filter on there and youre good to go! I did this on my blue Fleetwood, plenty of write-ups out there.. | |
| Subject: Re: My to-do list Mon Sep 26, 2011 12:38 am | |
| Don't buy a hockey puck. I will give you one of mine. Ok? | |
| Subject: Re: My to-do list Mon Sep 26, 2011 7:55 am | |
| - chapel wrote:
- I see people remove the 'home plate' and the baffle between the throttle and the MAF. is there a write up for this?
Of course there's a writeup! | |
chapel
| Subject: Re: My to-do list Mon Sep 26, 2011 9:20 am | |
| - 96Brougham wrote:
- I didnt think it was the air compressor, I know it is. This is normal due to a leaking shock(as I explained). It wont kill the battery, you could either replace the shocks with new air shocks, or simply unplug the compressor.
Oh ok. Is this going to affect ride quality? I don't really know much about the air shocks on these cars... are they additional shocks or are they the standard shocks with air assist? - Quote :
- Drivers mirror is cracked in half(the outer housing) as I showed you, I bought that black mirror off 96slowss to replace it, just never got around to it..
Oh, I saw you point to that. I could probably just epoxy it so I don't need to paint it. I'll keep it just in case - Quote :
- You can delete home plate with a hockey puck, and build yourself an intake out of pvc piping from Lowes. Throw a cone filter on there and youre good to go! I did this on my blue Fleetwood, plenty of write-ups out there..
Is it worth it? are there any benefits (aside from more induction noise)? I just bought my new radio. What should I be getting to install it? do I need something like this? http://www.sonicelectronix.com/item_9724_Scosche-GM1590AB-GM1590A.html I know I need a wiring harness for it (because I hate cutting up stock harnesses to install radios) also, is there a fixed aerial option for these? the power one is stuck up (at least it's up) but I wanted to just get a regular whip aerial. I'd like to order the radio stuff today so I can install it on the weekend if possible. | |
LandMaster
| Subject: Re: My to-do list Mon Sep 26, 2011 9:41 am | |
| USE A GLASS CANDLE TOP... I did for a while the hockey puck looks more "stock" if thats what your going for, but if you use the candle top it smells like christmas trees everywhere you go and unless you want to pony up for a K&N or better yet the Rammit or RAISS intakes the PVC lowes intake is the best dollar for dollar intake upgrade car sounds better and is a little snappier if you keep you foot out of it you should pick up an mpg I went from 15.7 over a tank to about 16.8 with "spirited" driving | |
| Subject: Re: My to-do list Mon Sep 26, 2011 9:43 am | |
| Radio install parts as right at walmart.... Under $25 for everything. Check in the car audio section. | |
chapel
| Subject: Re: My to-do list Mon Sep 26, 2011 9:45 am | |
| - LandMaster wrote:
- USE A GLASS CANDLE TOP... I did for a while the hockey puck looks more "stock" if thats what your going for, but if you use the candle top it smells like christmas trees everywhere you go and unless you want to pony up for a K&N or better yet the Rammit or RAISS intakes the PVC lowes intake is the best dollar for dollar intake upgrade car sounds better and is a little snappier if you keep you foot out of it you should pick up an mpg I went from 15.7 over a tank to about 16.8 with "spirited" driving
yeah, low dollar is the only way to go I'm going to Home Depot tonight for some stuff. I saw some people running 'caps' instead of hockey pucks. Sad to say, as a former hockey player, I have no pucks at my house! but I will be going to Home Depot, so what size cap is it? I'll just grab one while I'm there That write up mentions a straight piece of 3" PVC, but I saw other people using angled pieces. I thought I saw a write up somewhere else, but I can't find it now. I had a question about the giant mechanical fan. I know this is part of the tow pack, but is it 'necessary'? it's REALLY loud... Could I remove it and replace it with twin electric fans? I think I have some slim fans in a box somewhere... | |
| Subject: Re: My to-do list Mon Sep 26, 2011 9:46 am | |
- Quote :
- Quote :
I'd like to order the radio stuff today so I can install it on the weekend if possible. You could probably get the radio harness cheap at AZ or Advanced, maybe even wally world. The power antenna on those you need to remove the fender I'm pretty sure, but if you really want to get rid of it I know a few guys have done that fix/swap. the PVC is worth it because it's fun! Get something that can handle High Pressure, they can also handle high heat. I posted a video a few weeks ago about a whole radio swap to a stock style Ipod ready radio in a roadmaster, really cool. Maybe you'd like to do that instead as it plugs into the stock harness. The guys user name is saabkyle04 or something. You could probably find the link if you search all of my posts or something like that. EDIT: theres a write up for the fans somewhere | |
chapel
| Subject: Re: My to-do list Mon Sep 26, 2011 9:48 am | |
| - Ironfistdog wrote:
- Radio install parts as right at walmart.... Under $25 for everything. Check in the car audio section.
oh ok. Yeah, I guess this isn't really a 'special car' in terms of getting install parts... there's a first. What parts do I need though? Do I need the double DIN install kit? I know I need the GM wiring harness (think I'll just hook the wires, solder and shrink wrap them this time rather than using the more elaborate Metra Smart Harness | |
| Subject: Re: My to-do list Mon Sep 26, 2011 9:51 am | |
What parts do I need though? Do I need the double DIN install kit? I know I need the GM wiring harness (think I'll just hook the wires, solder and shrink wrap them this time rather than using the more elaborate Metra Smart Harness LOL I twist mine together and tape em! | |
chapel
| Subject: Re: My to-do list Mon Sep 26, 2011 9:55 am | |
| - 1984twodoor wrote:
- You could probably get the radio harness cheap at AZ or Advanced, maybe even wally world. The power antenna on those you need to remove the fender I'm pretty sure, but if you really want to get rid of it I know a few guys have done that fix/swap.
Yeah, I don't need to do it right now. Just an idea for later. - 1984twodoor wrote:
- the PVC is worth it because it's fun! Get something that can handle High Pressure, they can also handle high heat.
Ok. It mentions having to mount the airbox at an angle in the write up. I guess a piece of 3" PVC is cheap enough to just give is a try without using the 'elbows' method. - 1984twodoor wrote:
- I posted a video a few weeks ago about a whole radio swap to a stock style Ipod ready radio in a roadmaster, really cool. Maybe you'd like to do that instead as it plugs into the stock harness. The guys user name is saabkyle04 or something. You could probably find the link if you search all of my posts or something like that.
I already bought this: http://www.sonicelectronix.com/item_33387_JVC-KW-AVX840.html I haven't had a 'good radio' in a LONG time. I have this awesome 10" CDT sub with an Alpine 400W amp in a simple box in my basement that I never got to install in my Audi... I can't wait to wire it up again. It's small and removable, but it hits pretty clear. I would eventually like to integrate it into the car so it doesn't need to be in a standing box. - Quote :
- EDIT: theres a write up for the fans somewhere
Should I be trolling the Impala SS Forum for these writeups? I already know that EVERY question I have about these cars has been answered somewhere... it's just a matter of compiling the questions (which I'm doing here) so I can go and check where I'm at with it as I go along. Oh, I know the other thing I wanted to talk about: I'd like to get a keyless entry remote. This didn't come with one. Paul said I could buy one and reprogram it. Today I nearly left the car unlocked as I was heading to the train. I locked the driver's door, expecting the entire car to lock (like my old car) and ran to the train... then I realized it only locks the driver door... so I had to run back, unlock the driver door, hit the 'lock doors' button on the door and then haul ass to the train... | |
| Subject: Re: My to-do list Mon Sep 26, 2011 10:02 am | |
- Quote :
Today I nearly left the car unlocked as I was heading to the train. I locked the driver's door, expecting the entire car to lock (like my old car) and ran to the train... then I realized it only locks the driver door... so I had to run back, unlock the driver door, hit the 'lock doors' button on the door and then haul ass to the train... I dont know much about the fob but that is a nice radio! If I had a double DIN i'd want something like that. The SS forum is something ive never visited, and from the rep. it has I dont want to lol. But a lot of the good tech is on there according to the guys i've met on this site. If you were to do the PVC tube I would just stick a cone on the end and ditch the stock box, maybe there is a better reason to keep it but it would seem like the cone is the way to go. | |
chapel
| Subject: Re: My to-do list Mon Sep 26, 2011 10:04 am | |
| oh yeah, one other thing: it needs a new steering wheel BAD I might toss a cover on it for a bit, but I'd like to get a new wheel. | |
| Subject: Re: My to-do list Mon Sep 26, 2011 10:11 am | |
LandMaster
| Subject: Re: My to-do list Mon Sep 26, 2011 10:14 am | |
| I think Brian MASSHOLE9C1 has a monte steering wheel with no air bag if you dont care about such thinks, you can buy an interior paint to touch yours up otherwise nice examples can be scarce | |
chapel
| Subject: Re: My to-do list Mon Sep 26, 2011 10:32 am | |
- I got you covered on the lights.
Ebay euro headlamps, and 6000k hids https://badass-of-ne.forumotion.com/t2281-stock-vs-euro-hid-and-updated-harnesses
https://badass-of-ne.forumotion.com/t2158-euro-headlights-for-the-wagon How's the build quality? any leaking or condensation? I'm always concerned about that with ebay lights. what bulbs do they take? I get my HIDs from a friend for dirt cheap ($30 with ballasts) - LandMaster wrote:
- I think Brian MASSHOLE9C1 has a monte steering wheel with no air bag if you dont care about such thinks, you can buy an interior paint to touch yours up otherwise nice examples can be scarce
Generation 1 airbags scare me... so I wouldn't mind removing it. I'd just need to silence any airbag dummy lights if they arise. I wish it was a touch up job, but the leather is actually peeling off raw. | |
| Subject: Re: My to-do list Mon Sep 26, 2011 11:06 am | |
| Pvc intake. Two 45's and you're good. Drill out the stock airbox (swiss cheese mod) Gm double din install kit and harness. Tit. Get the ebay lights, but skip the 6k's. They suck. They look cool, but the 4500k is closer to sunlight color and works way batter. I have my stock wheel. Sem it and you're gtg. Door panel is an easy fix. You can get replacement transmitters on ebay cheap. Programming is tit. Dual fans is easy. Get a primary fan, radiator hold down, and wiring from a sedan/non tow pack car and swap it in. Pcm already programmed to run it. I used gary's harness and it is the balls. Shocks... Go to autozone and get the gabriel hd shocks for a 9c1. 20 bucks a piece, lifetime warranty, and they ride very close to the bilsteins. Sounds like you have a busy weekend. | |
chapel
| Subject: Re: My to-do list Mon Sep 26, 2011 11:18 am | |
- Pvc intake. Two 45's and you're good. Drill out the stock airbox (swiss cheese mod)
How do you join the two? Plastic weld? - Quote :
- Gm double din install kit and harness. Tit.
any better than others or just whatever? - Quote :
- Get the ebay lights, but skip the 6k's. They suck. They look cool, but the 4500k is closer to sunlight color and works way batter.
I normally use a 5200K but at 55W instead of 35W. That shifts the color more into a pure white due to the extra voltage. - Quote :
- I have my stock wheel. Sem it and you're gtg.
SEM? - Quote :
- Door panel is an easy fix.
Cool. when I go to pull the door shut, I feel like I'm going to yank the panel off entirely. - Quote :
- You can get replacement transmitters on ebay cheap. Programming is tit.
Paul said it has to do with the rear tail lamps? - Quote :
- Dual fans is easy. Get a primary fan, radiator hold down, and wiring from a sedan/non tow pack car and swap it in. Pcm already programmed to run it. I used gary's harness and it is the balls.
Might go yard diving for that. after winter though. - Quote :
- Shocks... Go to autozone and get the gabriel hd shocks for a 9c1. 20 bucks a piece, lifetime warranty, and they ride very close to the bilsteins.
LOL. $20 shocks... awesome. Coilovers for my S6 were $2800... When swapping to regular shocks, do you need to remove any air lines or the compressor? | |
| Subject: Re: My to-do list Mon Sep 26, 2011 12:14 pm | |
| I've never seen the inside, but does it have tan interior? I have a tan wheel somewhere from a Civi caprice i think it was in good shape. Now where did i put that damn thing? | |
chapel
| Subject: Re: My to-do list Mon Sep 26, 2011 12:15 pm | |
| - No Moa wrote:
- I've never seen the inside, but does it have tan interior? I have a tan wheel somewhere from a Civi caprice i think it was in good shape. Now where did i put that damn thing?
it is tan, yes. Thanks | |
| Subject: Re: My to-do list Mon Sep 26, 2011 1:18 pm | |
chapel
| Subject: Re: My to-do list Mon Sep 26, 2011 1:22 pm | |
| - MASShole9C1 wrote:
- Ive got a tan Lumina wheel that I had in my '95 LDM. Heres the picks
https://badass-of-ne.forumotion.com/t2833-f-s-steering-wheel does it bolt straight in? Even if I can get something to slap on while I send this out for recovering (and bulking up, the rim is a bit thin for my big paws) | |
| Subject: Re: My to-do list Mon Sep 26, 2011 10:45 pm | |
| Subject: Re: My to-do list Mon Sep 26, 2011 11:08 pm | |
| Yea it bolts right up. It has "meaty grips". I have small hands so I took it off. | |
chapel
| Subject: Re: My to-do list Tue Sep 27, 2011 9:10 am | |
| how much you want? Does unplugging the old wheel make an airbag light go on? and if it does can it be defeated? | |
| Subject: Re: My to-do list Tue Sep 27, 2011 9:13 am | |
| Yes it does. Yes it can. Either by a resistor (I think) or pulling the bulb. (Which would probably be my option lol) | |
| Subject: Re: My to-do list Tue Sep 27, 2011 1:04 pm | |
| ^^^he answered it. - chapel wrote:
- how much you want?
Does unplugging the old wheel make an airbag light go on? and if it does can it be defeated? Make an offer, as long as you are going to meet up at the park before Newicks, you wont have to pay shipping. | |
chapel
| Subject: Re: My to-do list Tue Sep 27, 2011 1:05 pm | |
- ^^^he answered it.
Does unplugging the old wheel make an airbag light go on? and if it does can it be defeated? Make an offer, as long as you are going to meet up at the park before Newicks, you wont have to pay shipping. Bring it with you and if I can make it, I'll probably grab it | |
| Subject: Re: My to-do list Tue Sep 27, 2011 1:40 pm | |
| see you there then...maybe | |
chapel
| Subject: Re: My to-do list Wed Sep 28, 2011 11:59 pm | |
| I got the 3 volume manual on Ebay for $65 thanks MP775 | |
chapel
| Subject: Re: My to-do list Thu Sep 29, 2011 5:30 pm | |
| http://www.impalassforum.com/vBulletin/showthread.php?t=258138 this is what mine is doing too
what kind of spring is this? I'd like to fix it. it rattles around pretty bad | |
| Subject: Re: My to-do list Thu Sep 29, 2011 9:20 pm | |
| [QUOTE=Fred Kiehl]The spring is probably broken. You can replace it without disassembling the entire steering column. The instructions are in any FSM for B bodies...... [/QUOTE] Not sure the instructions are in the $65 Ebay manuals. | |
| Subject: Re: My to-do list Thu Sep 29, 2011 9:35 pm | |
- [QUOTE=Fred Kiehl]The spring is probably broken.
You can replace it without disassembling the entire steering column. The instructions are in any FSM for B bodies...... Steve Not sure the instructions are in the $65 Ebay manuals. [/quote] You have probably figured it out, but although he means well, listening to Fred Kiehl for advice can be dangerous. He answer many questions, regardless if he knows the answers. Tom | |
chapel
| Subject: Re: My to-do list Thu Sep 29, 2011 9:41 pm | |
- Fred Kiehl wrote:
- The spring is probably broken.
You can replace it without disassembling the entire steering column. The instructions are in any FSM for B bodies...... Not sure the instructions are in the $65 Ebay manuals. ? http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=330617027419&viewitem=&sspagename=ADME%3AL%3AOC%3AUS%3A1123#ht_961wt_939 these are the manuals I bought. That's the official Factory Service Manual, right? I guess I just need to know what the part# is for the spring. | |
| Subject: Re: My to-do list Thu Sep 29, 2011 10:03 pm | |
| Yes, those are them... just a bad joke on my part.... goes like this... You reference expensive manual price...$200+ I say sometimes you can get them cheaper $80-$90 but just buy them You get a tip...Ebay $65=score. You have something to look up in said manual.. I say the CHEAP one doesnt have that info... awww....nevermind | |
chapel
| Subject: Re: My to-do list Thu Sep 29, 2011 10:05 pm | |
- Yes, those are them...
You reference expensive manual price...$100+ I say sometimes you can get them cheaper $80-$90 but just buy them You get a tip...Ebay $65=score.
awww....nevermind
oh, I see what you mean. I don't have the manuals yet. I should have them next week. | |
| Subject: Re: My to-do list Fri Sep 30, 2011 5:48 am | |
| http://www.rmsautoparts.com/proddetail.php?prod=7812853 As Tom pointed out, better check your FSM yourself. I've never done this (or tried) | |
chapel
| Subject: Re: My to-do list Sat Oct 15, 2011 12:56 pm | |
| Got the Cowl piece on today. no more sponge in the HVAC intake... that should alleviate a majority of the musty smell.
Need to try to do the radio this weekend. | |
| Subject: Re: My to-do list Sat Oct 15, 2011 7:19 pm | |
| And you didnt come to the meet WHY?......
Edit: Saw the other post....been there...done that...GLWTW | |
chapel
| Subject: Re: My to-do list Sat Oct 15, 2011 7:23 pm | |
| My wife had an emergency skin biopsy yesterday and she's in a lot of pain | |
| Subject: Re: My to-do list | |
| My to-do list | |
