 Another trans question
PostSubject: Another trans question   Fri Sep 23, 2011 10:58 pm
Soon I will be installing(with some good help) a low mileage 4L60E from what I believe was a '96 B4U. It may be a dumb question, but is there any difference for a 9C1 4L60E? The only thing Ive found is that the years vary to some extent. Being that its from a '96, going into a '96, there should be no problems. I plan on having the problematic trans built up with a shift kit and such at some point, so I need this to be able to work for now.
PostSubject: Re: Another trans question   Sat Sep 24, 2011 12:11 am
My trans will go right in.
Differences:
’94: First year of electronic controls in the valvebody (versus the ’93 4L60, which did not have this). The PCM controls line pressure (holding power and shift feel), 1-2, 2-3 and 3-4 shift points (rpm), and TCC lockup (timing and in the ’95-up models, apply feel). Everything else is done mechanically/hydraulically.
’95: Added a Pulse-Width Modulation Torque Converter Clutch (TCC) apply solenoid to control the feel of the TC clutch lockup (blamed for many 4L60E problems; TransGo HD2-C bypasses this, or you can stake the TCC apply valve in place). Also changed 3-2 downshift solenoid mid-year (see '96, below).
’96: PWM TCC plus a different tailhousing design with new-style Vehicle Speed Sensor (VSS). Also changed the 3-2 downshift solenoid in mid-1995 from TBD to TBD. There was a new manual valve added along with a relief port over the manual valve on the valve body casting with this change. This solved the low/reverse clutch release problem and makes the TransGo manual valve mod unnecessary.
PostSubject: Re: Another trans question   Sat Sep 24, 2011 12:41 am
Sounds good. As far as the job goes, Ive never R&R'd a tranny except at school. Its different when its your own car Wink . How long will this job take per say, with the exhaust and cross member removal? Its a good thing theres no rust Smile
PostSubject: Re: Another trans question   Sat Sep 24, 2011 12:55 am
Few hrs with hand tools,
6 bolts in the bell housing, Probably the hardest part....
3 15mm torque converter bolts
4 u-joint bolts in the rear end
1 nut in the middle of cross member
I believe it's 4 bolts for the cross member to frame
If you have dual exhaust it will be easier. Just undo the ball/socket where cats meets intermediate's might not even have to come off.
Biggest pita is working on the jack stands and doing the bell housing bolts. I got torches and air tools though just incase the cross member want to be stubborn.
PostSubject: Re: Another trans question   Sat Sep 24, 2011 12:57 am
And obviously we have to unhook the electrical plug and trans lines as well
PostSubject: Re: Another trans question   Sat Sep 24, 2011 12:59 am
Awesome. Now, if we can get a nice day or a shop with a lift silent
If your not busy, Id definitely like to swing by and pickup that item you worked on for me bounce
PostSubject: Re: Another trans question   Sat Sep 24, 2011 1:19 am
I'l be home all weekend. If Toni feels up to it have her come up with the babe. I'm sure my wife and baby would love to see them. I'm excited about the wagon project now too! bounce bounce bounce Damn rain
PostSubject: Re: Another trans question   Sat Sep 24, 2011 1:26 am
I'll text you in the a.m......well, later in the a.m.
PostSubject: Re: Another trans question   Sat Sep 24, 2011 6:34 am
This is where the national forum can be very helpful. Joel "Sherlock9c1" did a writeup on the differences between the three years the b-body used the 4L60E.
Some of it is above, the rest can be found here.
http://www.impalassforum.com/vBulletin/showthread.php?t=232098
PostSubject: Re: Another trans question   Sat Sep 24, 2011 9:57 am
Details NAOW! Razz
PostSubject: Re: Another trans question   Sat Sep 24, 2011 11:43 am
Ah soon my friend soon. I'll be posting a thread. Still "ironing"out details. I'm gonna be part of the long roof crowd REAL soon. Arrow Twisted Evil Twisted Evil Twisted Evil
PostSubject: Re: Another trans question   Sat Sep 24, 2011 12:02 pm
lol! lol! lol! lol! lol! lol! lol!
PostSubject: Re: Another trans question   Sat Sep 24, 2011 9:14 pm
When you get to this point, you'll want to get 2 1/2 feet of 3/8" Extentions to access the 6 Bellhousing bolts. JR Pulled my trans out in 57 minutes, without a lift. Of course we've done it 4-5 times Rolling Eyes
PostSubject: Re: Another trans question   Sun Sep 25, 2011 9:46 am
I've installed transmissions in about 15 or so cars, the top 2 I usually do with 6 sided bent wrenches, and the bottom 2 are pretty straight forward....., it's the 2 in the middle that make me wish the car would just fall on me. I will try the 2 1/2' of extensions. Btw CLEAN pic! I'll post the stop watch time When we get to this project Very Happy . Also for anyone who's interested in transmissions. The link Bill posted above is a great thread. Has all the info on how to interchange 94,95,96 4l60e's good read if you have the time,
PostSubject: Re: Another trans question   Sun Sep 25, 2011 9:58 am
I can do a tranny removal and install in just under 3 hours on jack stands in the driveway. I have done 6 or 7 of them so far. Rolling Eyes
PostSubject: Re: Another trans question   Fri Sep 30, 2011 1:29 am
The new trans went in today. Thanks to Indigo and pouring rain/thunder and lightning with jack stands and 3 floor jacks to supplement the fact that we didnt have a trans jack. All went well and quick with the two people, basic hand tools,and no problems driving an hour home. Thanks again!
