 Broken Gauge cluster?
JW94SSLT1
PostSubject: Broken Gauge cluster?   Wed Sep 07, 2011 7:23 am
I'm not sure what to do my speed and gas gauge work but nothing else Ive changed the cluster out once and nothing changed I have no engine temp it always reads cold and oil pressure reads nothing and the volts is high all the time any ideas should i just change to a z cluster?
PostSubject: Re: Broken Gauge cluster?   Wed Sep 07, 2011 8:42 am
Did you change the WHOLE cluster? or just the speedo piece?
I'd look at fuses first, then remove the whole assembly and clean the contacts. Maybe they are corroded a litte, i know mine in the 96 where.
Let me know what you need, i have a couple cars left with clusters. Come up and take a couple to try if you want.
Glen
JW94SSLT1
PostSubject: Broken Gauge cluster?   Wed Sep 07, 2011 8:52 am
yeah mark gave me a whole cluster I guess ill have to try and check the fuses and contacts Ill let you know if I need anything Ill most likely be calling you soon to pick up that heater knob and ashtray if you have any left
PostSubject: Re: Broken Gauge cluster?   Wed Sep 07, 2011 9:19 am
Yea I got some for ya, the tray is blue but should work with some SEM paint
» Finally Did The 9C1 Cluster Swap
» Gauge upgrade
» Z28 Cluster Gauge Overlay - $45
» Camaro gauge for caprice/impala mod
» Help needed for Tender Locomotive 5" gauge Kit - Stolen Boiler
