| duel exhaust | |
+7Cadet57 Matt Trakker Pooge bowtiepimp mega V8Killer boojum 11 posters |
| Subject: duel exhaust Fri Aug 19, 2011 4:58 pm | |
| i see that all the faster cars on craigslist have duel exhuast what would be a good duel exhuast to use on our cars i don't want to spend too much thanks | |
| Subject: Re: duel exhaust Fri Aug 19, 2011 5:25 pm | |
| - boojum wrote:
- i see that all the faster cars on craigslist have duel exhuast what would be a good duel exhuast to use on our cars i don't want to spend too much thanks
How much is "too much"? | |
| Subject: Re: duel exhaust Fri Aug 19, 2011 7:11 pm | |
| $500 is too much $60 would be ok it should sound mean
| Subject: Re: duel exhaust Fri Aug 19, 2011 7:14 pm | |
| just pick up some pipe and make one pretty cheap | |
| Subject: Re: duel exhaust Fri Aug 19, 2011 8:07 pm | |
| 10 points for Jim .... I needed a good joke | |
| Subject: Re: duel exhaust Fri Aug 19, 2011 9:12 pm | |
| - bowtiepimp wrote:
- 10 points for Jim
.... I needed a good joke Yup, I got a good chuckle out of it. Doug | |
| Subject: Re: duel exhaust Fri Aug 19, 2011 11:43 pm | |
| exhust on hold need new breaks now | |
| Subject: Re: duel exhaust Sat Aug 20, 2011 6:09 am | |
| Someone spends way to much time on craigslist. |
| Subject: Re: duel exhaust Sat Aug 20, 2011 8:20 am | |
| Subject: Re: duel exhaust Sat Aug 20, 2011 12:01 pm | |
| my 93 is too slow does ne1 have a cheep LT1 with new opti I can drop in to the car | |
| Subject: Re: duel exhaust Sat Aug 20, 2011 12:04 pm | |
| - Matt Trakker wrote:
- my 93 is too slow does ne1 have a cheep LT1 with new opti I can drop in to the car
D00D, u r so wronfg. The 93 has the LT6. | |
| Subject: Re: duel exhaust Sat Aug 20, 2011 5:18 pm | |
| now the sterio is acting up it cuts out and comes back on not too often | |
| Subject: Re: duel exhaust Sat Aug 20, 2011 7:25 pm | |
| Um, any extra drum brakes? I want to convert my fronts. I need spindles too! | |
| Subject: Re: duel exhaust Sun Aug 21, 2011 10:41 am | |
| - boojum wrote:
- exhust on hold need new breaks now
I thought this was an Exhaust thread? I'm SO confused! | |
| Subject: Re: duel exhaust Sun Aug 21, 2011 10:48 am | |
| things change at least i'm not having any problems with the moter | |
| Subject: Re: duel exhaust Sun Aug 21, 2011 12:44 pm | |
| The chek engen lite is on sometime it go away | |
| Subject: Re: duel exhaust Sun Aug 21, 2011 1:28 pm | |
| - GasTT wrote:
- The chek engen lite is on sometime it go away
Yore master cylander is louse. | |
| Subject: Re: duel exhaust Sun Aug 21, 2011 2:40 pm | |
| u better check ur taillight fluid.. | |
| Subject: Re: duel exhaust Sun Aug 21, 2011 5:16 pm | |
| - 96slowss wrote:
- u better check ur taillight fluid..
..... What DOT level do they require?...... I can see a little fluid in the left one but the right looks pretty dry. | |
| Subject: Re: duel exhaust Sun Aug 21, 2011 5:42 pm | |
| guys i cut all d springs in my car n it rids funny now help plz | |
| Subject: Re: duel exhaust Sun Aug 21, 2011 6:08 pm | |
| - bowtiepimp wrote:
- ..... What DOT level do they require?...... I can see a little fluid in the left one but the right looks pretty dry.
2 quarts per light, but if you have DexLight in there you might as well flush it. - Matt Trakker wrote:
- guys i cut all d springs in my car n it rids funny now help plz
Pt extrah bumper stopss (i thank that what there called) under yor springs. | |
| Subject: Re: duel exhaust Sun Aug 21, 2011 6:29 pm | |
| 2 quarts per light. And the tires take 3 gallons of helium.. | |
| Subject: Re: duel exhaust Sun Aug 21, 2011 6:32 pm | |
| - 96slowss wrote:
- And the tires take 3 gallons of helium..
No, thats not OME spec! It's 4 gallons of Methane! | |
| Subject: Re: duel exhaust Sun Aug 21, 2011 8:52 pm | |
| guys i wird neww speakers from walmart in my car but now it wont start and I smell burnt toast did i need to attach ground help | |
| Subject: Re: duel exhaust Mon Aug 22, 2011 12:36 am | |
| I hurd the SS impala camee with a factery souper chargers I want won bad anyone have one for sells | |
| Subject: Re: duel exhaust Mon Aug 22, 2011 2:35 am | |
| Enough please. This could go on ad Infinity! I posted some serius questions. This has been a waist of my time. P.S. I decided to go with Flowmaster. | |
| Subject: Re: duel exhaust Mon Aug 22, 2011 4:42 am | |
| Good choice. What vehicle are they for? Which series and whatd you end up paying? I'm going that root sewn that's y I ask. | |
| Subject: Re: duel exhaust Mon Aug 22, 2011 9:50 am | |
| All I have to say is: WOW....reellie | |
| Subject: Re: duel exhaust Mon Aug 22, 2011 1:24 pm | |
| I has too add transmisions kewlerz allso | |
| Subject: Re: duel exhaust | |
| duel exhaust | |
