February 2018
 duel exhaust
PostSubject: duel exhaust   Fri Aug 19, 2011 4:58 pm
i see that all the faster cars on craigslist have duel exhuast what would be a good duel exhuast to use on our cars i don't want to spend too much thanks
PostSubject: Re: duel exhaust   Fri Aug 19, 2011 5:25 pm
How much is "too much"?
PostSubject: Re: duel exhaust   Fri Aug 19, 2011 7:11 pm
$500 is too much $60 would be ok it should sound mean
PostSubject: Re: duel exhaust   Fri Aug 19, 2011 7:14 pm
just pick up some pipe and make one pretty cheap
PostSubject: Re: duel exhaust   Fri Aug 19, 2011 8:07 pm
10 points for Jim cheers
.... I needed a good joke
PostSubject: Re: duel exhaust   Fri Aug 19, 2011 9:12 pm
Yup, I got a good chuckle out of it.
PostSubject: Re: duel exhaust   Fri Aug 19, 2011 11:43 pm
exhust on hold need new breaks now
PostSubject: Re: duel exhaust   Sat Aug 20, 2011 6:09 am
Someone spends way to much time on craigslist. Wink
PostSubject: Re: duel exhaust   Sat Aug 20, 2011 8:20 am
need wheels too 5 lug
PostSubject: Re: duel exhaust   Sat Aug 20, 2011 12:01 pm
my 93 is too slow does ne1 have a cheep LT1 with new opti I can drop in to the car
PostSubject: Re: duel exhaust   Sat Aug 20, 2011 12:04 pm
D00D, u r so wronfg. The 93 has the LT6.
PostSubject: Re: duel exhaust   Sat Aug 20, 2011 5:18 pm
now the sterio is acting up it cuts out and comes back on not too often
PostSubject: Re: duel exhaust   Sat Aug 20, 2011 7:25 pm
Um, any extra drum brakes? I want to convert my fronts. I need spindles too!
PostSubject: Re: duel exhaust   Sun Aug 21, 2011 10:41 am
I thought this was an Exhaust thread? I'm SO confused!
PostSubject: Re: duel exhaust   Sun Aug 21, 2011 10:48 am
things change at least i'm not having any problems with the moter
PostSubject: Re: duel exhaust   Sun Aug 21, 2011 12:44 pm
The chek engen lite is on sometime it go away
PostSubject: Re: duel exhaust   Sun Aug 21, 2011 1:28 pm
Yore master cylander is louse.
PostSubject: Re: duel exhaust   Sun Aug 21, 2011 2:40 pm
u better check ur taillight fluid..
PostSubject: Re: duel exhaust   Sun Aug 21, 2011 5:16 pm
..... What DOT level do they require?...... I can see a little fluid in the left one but the right looks pretty dry.
PostSubject: Re: duel exhaust   Sun Aug 21, 2011 5:42 pm
guys i cut all d springs in my car n it rids funny now help plz
PostSubject: Re: duel exhaust   Sun Aug 21, 2011 6:08 pm
2 quarts per light, but if you have DexLight in there you might as well flush it.
Pt extrah bumper stopss (i thank that what there called) under yor springs.
PostSubject: Re: duel exhaust   Sun Aug 21, 2011 6:29 pm
2 quarts per light. And the tires take 3 gallons of helium..
PostSubject: Re: duel exhaust   Sun Aug 21, 2011 6:32 pm
No, thats not OME spec!
It's 4 gallons of Methane!
PostSubject: Re: duel exhaust   Sun Aug 21, 2011 8:52 pm
guys i wird neww speakers from walmart in my car but now it wont start and I smell burnt toast did i need to attach ground help
PostSubject: Re: duel exhaust   Mon Aug 22, 2011 12:36 am
I hurd the SS impala camee with a factery souper chargers I want won bad anyone have one for sells
PostSubject: Re: duel exhaust   Mon Aug 22, 2011 2:35 am
Enough please. This could go on ad Infinity!
I posted some serius questions.
This has been a waist of my time. Smile
P.S. I decided to go with Flowmaster.
PostSubject: Re: duel exhaust   Mon Aug 22, 2011 4:42 am
Good choice. What vehicle are they for? Which series and whatd you end up paying? I'm going that root sewn that's y I ask.
PostSubject: Re: duel exhaust   Mon Aug 22, 2011 9:50 am
All I have to say is: WOW....reellie Question
PostSubject: Re: duel exhaust   Mon Aug 22, 2011 1:24 pm
I has too add transmisions kewlerz allso
duel exhaust
» Gunz The Duel
» KCVDS Duel Videos
» Looking for an exhaust shop with a mandrel bender in NE...
» Can you play YGO 2 WITH OUT PAYING FOR DUEL PASSES?
» LT1/L99 Exhaust manifolds
