| Subject: Mystery Oil light Sun Jul 03, 2011 1:20 am | |
| I was on the way to the beach today and on 95 i noticed that the oil light had come on. I pulled off to check it out and I had no leaks around the intake, nothing leaking down below, I just changed the oil before the mod day, and it was still full of clean oil. I looked in back of the motor and saw that there was some oil around the base of the plug for the sender to the oil light. I have NO idea whats going on, she runs perfect without any noises what-so-ever:scratch: . Could the sender just be bad and sending info to the comp. to put the light on? It goes out when I rev it at idle but comes back on when i take my foot off the gas. Any ideas???? | |
| Subject: Re: Mystery Oil light Sun Jul 03, 2011 9:21 am | |
| If your level is still the same and you don't have leaks I would say the obvious place to start would be a new oil level sensor and then go from there if the light comes back. | |
| Subject: Re: Mystery Oil light Sun Jul 03, 2011 5:02 pm | |
| - Cadet57 wrote:
- If your level is still the same and you don't have leaks I would say the obvious place to start would be a new oil level sensor and then go from there if the light comes back.
Figued that but I'm a little paranoid that one of my intake manifold gaskets didnt set the way it should have. I'll do the sensor though. | |
| Subject: Re: Mystery Oil light Sun Jul 03, 2011 5:05 pm | |
| - 1984twodoor wrote:
- Figued that but I'm a little paranoid that one of my intake manifold gaskets didnt set the way it should have.
But then you'd have a nice oil/coolant mix. | |
| Subject: Re: Mystery Oil light Sun Jul 03, 2011 5:27 pm | |
But then you'd have a nice oil/coolant mix. Good point. At least it'd be better than my friends oil/gas mix in his camaro. I;ll see if I can get the sensor tomorrow morning. | |
| Subject: Re: Mystery Oil light | |
