opti EmptyWed Oct 19, 2022 1:27 pm by scot
opti EmptyTue Oct 18, 2022 8:58 pm by silverfox103
opti EmptyTue Sep 28, 2021 11:01 pm by silverfox103
opti EmptyFri Sep 24, 2021 9:53 am by ElKy
opti EmptySun Sep 19, 2021 6:22 pm by black blur 96
opti EmptySun Jun 20, 2021 11:37 am by scot
opti EmptyFri Jun 11, 2021 10:41 am by scot
opti EmptyWed Jun 09, 2021 9:41 pm by Chris Klein
opti EmptyWed Jun 02, 2021 9:02 pm by Chris Klein
 opti
4 posters
opti Empty
PostSubject: opti   opti EmptySun Jul 31, 2011 7:24 pm
anyone got a spare working opti i think mine crapped the bed. seems like its running on 7 cyl.
opti Empty
PostSubject: Re: opti   opti EmptySun Jul 31, 2011 7:29 pm
How do you know its an opti? Maybe a bad plug? Bad wires?
opti Empty
PostSubject: Re: opti   opti EmptySun Jul 31, 2011 8:53 pm
covering my bases wires are 2 months old so dont think them plugs will check tommorow i hope its that exahust smells and sound weird
opti Empty
PostSubject: Re: opti   opti EmptyMon Aug 01, 2011 10:07 am
ok ok you were right lol last plug wire driver side was on exaust and cooked. same thing happened last set to.
opti Empty
PostSubject: Re: opti   opti EmptyMon Aug 01, 2011 12:41 pm
Wire looms Arrow
opti Empty
PostSubject: Re: opti   opti EmptyMon Aug 01, 2011 4:00 pm
weird thing is i got em maybe in wrong spot hell i belive the wire are wrong. they are routed behind the manifols time for some damn work i see. i guess putting them back the way they were wasnt a good idea.
opti Empty
PostSubject: Re: opti   opti EmptyMon Aug 01, 2011 4:56 pm
ok did a little more digging found out that they are 7mm wires, so they gotta go deffinatly need some 8mm or 8.5
opti Empty
PostSubject: Re: opti   opti EmptyMon Aug 01, 2011 9:31 pm
mega wrote:
...... they are routed behind the manifols time for some damn work i see.....
Huh?
opti Empty
PostSubject: Re: opti   opti EmptyMon Aug 01, 2011 9:37 pm
my exact thought when i was looking at it was huh.. it was the last one one the driverside dont know why it was done but seem alot of wire looms are gone yay impulse spend time lol
opti Empty
PostSubject: Re: opti   opti EmptyTue Aug 02, 2011 8:24 am
Aren't LT1 wires numbered and shaped according to what cylinder they're supposed to go into?
opti Empty
PostSubject: Re: opti   opti EmptyTue Aug 02, 2011 9:59 am
No, but you check the lengths (cap is marked so you cant really screw up)
The #7 is always to long
I go past the plug & loop it back making sure it wont pivot down onto the exhaust.
Its a PIA (especially if you use the old brackets that hold the 5 & 7 against the block
Better off just tywrapping to the bracket (or anything you can)
When you've got them right you'll know it
Headers are 2X more difficult
If you work it while the motors cold you'll be fine
opti Empty
PostSubject: Re: opti   opti EmptyWed Aug 03, 2011 6:37 pm
yeah for now its just temp fixed but going to talk to the idiots who gave me the 7mm wires. for not its tied off so it wont hit exaust, but now need to look into some different wires. i,m kinda leaning towards some accel wires any thought on those and if youve done em before whats the part number if ya know.
opti Empty
PostSubject: Re: opti   opti EmptyWed Aug 03, 2011 6:49 pm
I'd go with Ac Delco. They're OEM spec.
opti Empty
PostSubject: Re: opti   opti EmptyWed Aug 03, 2011 6:59 pm
are the ac delco's 7mm or 8mm but im kinda looking towards 8.5mm and want to try to get them a little longer so I can use the wire looms that bolt to the valve covers.
opti Empty
PostSubject: Re: opti   opti EmptyWed Aug 03, 2011 7:02 pm
Whatever stock spec is. No idea off the top of my head.
opti Empty
PostSubject: Re: opti   opti EmptyWed Aug 03, 2011 7:04 pm
maybe these for only 65 bucks
http://www.summitracing.com/parts/SUM-887824/?rtype=10
opti Empty
PostSubject: Re: opti   opti EmptyWed Aug 03, 2011 9:03 pm
AC Delco or any top name wire set will cost you $120+
I'm guessing thats not the weak link in your car now (guessing)
So those wires from summit would be fine
opti Empty
PostSubject: Re: opti   opti EmptyWed Aug 03, 2011 9:06 pm
$67 at Rockauto: http://www.rockauto.com/catalog/moreinfo.php?pk=1140029
That said, I read somewhere that the Jegs/Summit wiresets are nothing more than an aftermarket rebrand of the part store brands.
opti Empty
PostSubject: Re: opti   opti EmptyWed Aug 03, 2011 9:10 pm
I had chris quote me when he worked at the dealership. I went MSD
opti Empty
PostSubject: Re: opti   opti EmptyThu Aug 04, 2011 6:15 am
now I have read the thread on plug wires and some have had the boot problem on the msd wires. how are your boots? also would getting a msd or similar coil improve my performance, or will it not be noticed
opti Empty
PostSubject: Re: opti   opti EmptyThu Aug 04, 2011 6:22 am
Pretty sure the only problems are related to headers.
With the stock manifolds there's acres of room.
Cant comment on the coil, but once again, its a weak link thing.
If your car is so fresh & crisp that it recognizes the improvement great...most arent
opti Empty
PostSubject: Re: opti   opti EmptyThu Aug 04, 2011 6:38 pm
hope they will improve things because besides a hard start once in a while it runs great no shakes hesitation smoke. not how i recived the car though. also i need to look into deleting the cats and upgrading to dual pipes. damn i need a welder.
opti Empty
opti
» OMG! Not another opti? LOL
» Oh no! Not another opti?
» tearing down and rebuild of a Opti
» OPTI supplier
» wanted used opti
