| opti | |
| Subject: opti Sun Jul 31, 2011 7:24 pm | |
| anyone got a spare working opti i think mine crapped the bed. seems like its running on 7 cyl. | |
| Subject: Re: opti Sun Jul 31, 2011 7:29 pm | |
| How do you know its an opti? Maybe a bad plug? Bad wires? | |
| Subject: Re: opti Sun Jul 31, 2011 8:53 pm | |
| covering my bases wires are 2 months old so dont think them plugs will check tommorow i hope its that exahust smells and sound weird | |
| Subject: Re: opti Mon Aug 01, 2011 10:07 am | |
| ok ok you were right lol last plug wire driver side was on exaust and cooked. same thing happened last set to. | |
| Subject: Re: opti Mon Aug 01, 2011 12:41 pm | |
| - mega wrote:
- ok ok you were right lol last plug wire driver side was on exaust and cooked. same thing happened last set to.
Wire looms | |
| Subject: Re: opti Mon Aug 01, 2011 4:00 pm | |
| weird thing is i got em maybe in wrong spot hell i belive the wire are wrong. they are routed behind the manifols time for some damn work i see. i guess putting them back the way they were wasnt a good idea. | |
| Subject: Re: opti Mon Aug 01, 2011 4:56 pm | |
| ok did a little more digging found out that they are 7mm wires, so they gotta go deffinatly need some 8mm or 8.5 | |
| Subject: Re: opti Mon Aug 01, 2011 9:31 pm | |
| - mega wrote:
- ...... they are routed behind the manifols time for some damn work i see.....
Huh? | |
| Subject: Re: opti Mon Aug 01, 2011 9:37 pm | |
| my exact thought when i was looking at it was huh.. it was the last one one the driverside dont know why it was done but seem alot of wire looms are gone yay impulse spend time lol | |
| Subject: Re: opti Tue Aug 02, 2011 8:24 am | |
| Aren't LT1 wires numbered and shaped according to what cylinder they're supposed to go into? | |
| Subject: Re: opti Tue Aug 02, 2011 9:59 am | |
| No, but you check the lengths (cap is marked so you cant really screw up) The #7 is always to long I go past the plug & loop it back making sure it wont pivot down onto the exhaust. Its a PIA (especially if you use the old brackets that hold the 5 & 7 against the block Better off just tywrapping to the bracket (or anything you can) When you've got them right you'll know it Headers are 2X more difficult If you work it while the motors cold you'll be fine | |
| Subject: Re: opti Wed Aug 03, 2011 6:37 pm | |
| yeah for now its just temp fixed but going to talk to the idiots who gave me the 7mm wires. for not its tied off so it wont hit exaust, but now need to look into some different wires. i,m kinda leaning towards some accel wires any thought on those and if youve done em before whats the part number if ya know. | |
| Subject: Re: opti Wed Aug 03, 2011 6:49 pm | |
| I'd go with Ac Delco. They're OEM spec. | |
| Subject: Re: opti Wed Aug 03, 2011 6:59 pm | |
| are the ac delco's 7mm or 8mm but im kinda looking towards 8.5mm and want to try to get them a little longer so I can use the wire looms that bolt to the valve covers. | |
| Subject: Re: opti Wed Aug 03, 2011 7:02 pm | |
| - mega wrote:
- are the ac delco's 7mm or 8mm but im kinda looking towards 8.5mm and want to try to get them a little longer so I can use the wire looms that bolt to the valve covers.
Whatever stock spec is. No idea off the top of my head. | |
| Subject: Re: opti Wed Aug 03, 2011 7:04 pm | |
| maybe these for only 65 bucks http://www.summitracing.com/parts/SUM-887824/?rtype=10 | |
| Subject: Re: opti Wed Aug 03, 2011 9:03 pm | |
| AC Delco or any top name wire set will cost you $120+ I'm guessing thats not the weak link in your car now (guessing) So those wires from summit would be fine | |
| Subject: Re: opti Wed Aug 03, 2011 9:06 pm | |
| $67 at Rockauto: http://www.rockauto.com/catalog/moreinfo.php?pk=1140029
That said, I read somewhere that the Jegs/Summit wiresets are nothing more than an aftermarket rebrand of the part store brands. | |
| Subject: Re: opti Wed Aug 03, 2011 9:10 pm | |
| I had chris quote me when he worked at the dealership. I went MSD | |
| Subject: Re: opti Thu Aug 04, 2011 6:15 am | |
| now I have read the thread on plug wires and some have had the boot problem on the msd wires. how are your boots? also would getting a msd or similar coil improve my performance, or will it not be noticed | |
| Subject: Re: opti Thu Aug 04, 2011 6:22 am | |
| Pretty sure the only problems are related to headers. With the stock manifolds there's acres of room. Cant comment on the coil, but once again, its a weak link thing. If your car is so fresh & crisp that it recognizes the improvement great...most arent | |
| Subject: Re: opti Thu Aug 04, 2011 6:38 pm | |
| hope they will improve things because besides a hard start once in a while it runs great no shakes hesitation smoke. not how i recived the car though. also i need to look into deleting the cats and upgrading to dual pipes. damn i need a welder. | |
| Subject: Re: opti | |
| opti | |
