| NEW GOODIES! | |
+3toomanytoyz Tomz9C1 96slowss 7 posters |
| Subject: NEW GOODIES! Thu Jul 21, 2011 10:18 am | |
| as u know i get the 96 9c1 only for the tranny. its a rebuilt trans with a shift kit. just ordered a 3200 lock up stall converter. and also picked up a eaton tru-trac from a INC member in florida attached to it are 3.73 gears. if all goes good i should have it all in and driving in a few weeks. | |
| Subject: Re: NEW GOODIES! Thu Jul 21, 2011 10:19 am | |
| ill keep it updated with pics when i get ups boxes on my porch and start putting it 2gether | |
| Subject: Re: NEW GOODIES! Tue Jul 26, 2011 10:26 am | |
| got into the motor alttle more than i wated to but its all done now. pulled the fly wheel to do the rear main seal and found the oil pan gasket had a rip. so i had 2 jack up the motor and pull the pan. cleaned up everything replaced the oil pan gasket,rer main seal,and surrounding gaskets. re tourqed the fly wheel and got the motor bolted back in. when i get home there should be a 3500 stall sitting on my porch and hoping to get the stall and tranny installed tonight. then run my new lines and HUGE external cooler up front.. | |
| Subject: Re: NEW GOODIES! Tue Jul 26, 2011 3:03 pm | |
| Lol it says the converter is a 3200-3500 stall. And the car already ran a 14.1 with stock tranny and rearend. So iam shooting for a low-mid 13 | |
| Subject: Re: NEW GOODIES! Tue Jul 26, 2011 9:56 pm | |
| covnerter didnt show up 2day but i did finish up the motor. did all new msd wires (had a few arcing wire issues) and also replaced my k and n intake with the ramairss kit that was on the parts caprice. took a few pics.. old k&n test fit of the new one new intake painted and in new tranny cooler | |
| Subject: Re: NEW GOODIES! Tue Jul 26, 2011 11:33 pm | |
| Coming along nicely! (watch for deep puddles! :eek: ) Guess you don't need the t56? | |
| Subject: Re: NEW GOODIES! Wed Jul 27, 2011 12:00 am | |
| Lol good deal came up for the built auto. Someday I will lol | |
| Subject: Re: NEW GOODIES! Wed Jul 27, 2011 9:18 pm | |
| nice set up man. Wheres the washer tank? | |
| Subject: Re: NEW GOODIES! Wed Jul 27, 2011 9:26 pm | |
| Wow that is a wicked intake. I've never seen one like that. | |
| Subject: Re: NEW GOODIES! Thu Jul 28, 2011 12:08 am | |
| What washer tank? Lol who needs one of those? | |
| Subject: Re: NEW GOODIES! Thu Jul 28, 2011 12:33 am | |
| - 96slowss wrote:
- What washer tank? Lol who needs one of those?
Its a weight saving racing mod! | |
| Subject: Re: NEW GOODIES! Thu Jul 28, 2011 7:17 pm | |
| Subject: Re: NEW GOODIES! Fri Jul 29, 2011 8:52 am | |
| Mike, be careful of those cooler hoses, mine split near the inlet/outlet and partially blew out on I-81 in Virginia. I spliced it and later installed hard lines. Can't remember the required PSI for trans lines. | |
| Subject: Re: NEW GOODIES! Fri Jul 29, 2011 10:02 am | |
| Iam running hard lines from the tranny up the rubber lines are only 2 feet long just to seek around the radiator. | |
| Subject: Re: NEW GOODIES! Fri Jul 29, 2011 10:53 am | |
| - 96slowss wrote:
- Iam running hard lines from the tranny up the rubber lines are only 2 feet long just to seek around the radiator.
Did you by-pass the engine coolant to trans oil cooler in the radiator? They are very effective when used in series with the air to trans oil cooler up front [as in the OEM 9C1]. Of course all reused lines and coolers must be thoroughly back-flushed. Lower line is the converter/lube oil line out of the trans & upper pipe is return back to trans. The pressure in those lines (with no restriction) is very low, and it never gets main line fluid pressure. The main thing is that they can handle the heat and are compatible with transmission oil. Those higher stall converters will definitely cause you to run higher trans fluid temperatures, a LOT hotter if you drive hard. There are also very sharp sheet metal edges that will cut thru rubber hoses as you pass through the radiator support. Also, the 9C1 oil cooler cars were fitted with larger diameter oil pipes than the civi models. Did you delete the converter clutch lock-up feature? I think you are still running a 4L60E, yes? If so, how do you make that work? It looks like you are going to be having a lot of fun in that car, it should be a real beast! | |
| Subject: Re: NEW GOODIES! Fri Jul 29, 2011 1:17 pm | |
| The converter is a lock up converter. And yes I bypassed the radiator part of the cooling system. | |
| Subject: Re: NEW GOODIES! Sat Jul 30, 2011 1:29 pm | |
| its alive! got the new trans, stall in last night with the help of a few friends. ran new cooler lines flushed the tranny, replaced the filter and gasket all new castol dextron-6 fluid and oil change. runs way better with new wires,plugs. only got 2 test drives in so far. running/driving good. rearend is getting done this week or weekend coming up finally got the locker and 3:73s in got bored at work and sprayed the inspection cover lol and when i went to get food after i decided to grab a $2 ticket and won $500 on it.. | |
| Subject: Re: NEW GOODIES! Wed Aug 03, 2011 6:54 pm | |
| sounds like it was a very good day then | |
| Subject: Re: NEW GOODIES! | |
| NEW GOODIES! | |
