 oil cooler
PostSubject: oil cooler   Sat Jul 09, 2011 9:13 am
ok is this all i need to add the cooler to my car? The new radiator cam with the oil cooler.
Component Parts
Showing parts that fit a 1994 Chevrolet Caprice.
Index Stock Code Description Price
001 10269713 HOSE. Engine Oil Cooler
HOSE,ENG OIL CLR. Required: 01For: B 4.3W(L99),ENG OIL CLG(KC4) (1994-1996) (1994 - 1996). For: B 5.7P(LT1),ENG OIL CLG(KC4) (1994-1996) (1994 - 1996)... Show More $93.84
005 10244495 SEAL. Engine Oil Filter. Oil Filter.
SEAL,OIL FLTR ADAP(3.359"). Required: 01For: B 4.3W(L99) (1994-1996) (1994 - 1996). For: B 5.7P(LT1) (1994-1996) (1994 - 1996). For: D 5.7P(LT1) (1994... Show More $3.67
006 12556201 ADAPTER. Engine Oil Filter
ADAPTER,OIL FLTR(**VPI 1-877-846-8243). Required: 01
For: B 4.3W(L99),ENG OIL CLG(KC4) (1994-1994) (1994 - 1994).
For: B 5.7P(LT1),ENG OIL CLG(KC4) (1994-1994) (1994 - 1994).
For: B 5.7P(LT1),ENG OIL CLG(KC4),HVY DUTY CLG(V08) (1995-1996) (1995 - 1996).
For: B 5.7P(LT1),SEO PUBLIC SERVICE VEH(1A2),SEO POLICE CAR(9C1) (1995-1996) (1995 - 1996).
For: D 5.7P(LT1),ENG OIL CLG(KC4) (1994-1994) (1994 - 1994).
For: D 5.7P(LT1),ENG OIL CLG(KC4),HVY DUTY CLG(V08) (1995-1996) (1995 - 1996).
$124.29
008 10168445 BOLT. Engine Oil Filter
BOLT,OIL FLTR ADAP(5/16-18X3,)(**VPI 1-877-846-8243). Required: 02For: B 5.7P(LT1),ENG OIL CLG(KC4) (1994-1996) (1994 - 1996). For: B 5.7P(LT1),SEO PU... Show More $4.25
009 12490148 FILTER. Engine Oil Filter
FILTER,OIL(BULK PKG, QTY 12)(ACDelco #12490148)(DURAPACK). Required: 01For: B 4.3W(L99) (1994-1996) (1994 - 1996). For: B 5.7P(LT1) (1994-1996) (1994 ... Show More $6.12
009 25322836 FILTER. Engine Oil Filter
FILTER,OIL(ACDelco #UPF52)(ULTRAGUARD GOLD). Required: 01For: B 4.3W(L99) (1994-1996) (1994 - 1996). For: B 5.7P(LT1) (1994-1996) (1994 - 1996). For: ... Show More $16.76
009 19210286 FILTER. Engine Oil Filter.
FILTER,OIL(ACDelco #PF52E)(DURAGUARD). Required: 01For: B 4.3W(L99) (1994-1996) (1994 - 1996). For: B 5.7P(LT1) (1994-1996) (1994 - 1996). For: D 5.7P... Show More $7.16
011 25014006 VALVE. Engine Oil Cooler. Engine Oil Filter. Transmission.
VALVE,OIL FLTR BYPASS(W/CAGE, SEAT, SPRING & VALVE)(OPENING PRESSURE 11 PSI NOMINAL)(ACDelco #25014006). Required: 01VALVE,OIL FLTR BYPASS(W/CAGE, SEA... Show More $5.36
012 14090911 PIPE; PLUG. PLUG. Thermostat. PIPE. Air. Air Brake Pipe/Hose. Air Brake Piping. Air Brakes & chambers. Air Brake Valve. Brake Chamber. Brake Vacuum And Air Reservoir. Emission System. Engine Block. Engine Coolant. Engine Coolant By-Pass Hose. Engine Coolant Pump. Engine Coolant Thermostat. Engine Coolant Thermostat Housing. Engine Cylinder Head. Engine Fuel Filter. Engine Fuel Intake Manifold. Engine Oil Cooler. Engine Oil Distribution. Engine Oil Filter. Engine Oil Pan Drain. Engine Oil Pump. Fuel Pump. Fuel Pump Rocker Arm. Rear Axle. Vacuum Pump.
PLUG,OIL FLTR ADAP HOLE(AUTO DRAIN,INT SQ,3/8-18X.42 PEOR STL)(08.971). Required: 01For: B 4.3W(L99) (1994-1996) (1994 - 1996). For: B 5.7P(LT1) (1994... Show More $4.46
014 14090908 GASKET. Engine Oil Pan Drain Plug. Oil Pan Drain Plug. SEAL. Engine Oil Cooler.
SEAL,OIL FLTR INL & OTLT HOSE(01.456). Required: 02For: B ENG OIL CLG(KC4) (1994-1996) (1994 - 1996). For: D 5.7P(LT1),ENG OIL CLG(KC4) (1994-1994) (1... Show More $3.42
K01 88893990 Engine Oil Filter. GASKET. GASKET KIT.
GASKET KIT,OIL FLTR ADAP(2 RET HOLES)(INCLS GASKET AND SEAL). Required: 01GASKET KIT,OIL FLTR ADAP(INCLS GASKET AND SEAL). Required: 01For: B 4.3W(L99... Show More $4.35
PostSubject: Re: oil cooler   Mon Jul 11, 2011 11:19 pm
My new rad for my 1A2 came with the connections, I just never hooked them up. I hate those leaky lines. That said, you need the line, the adapter and the gasket/o-ring.
oil cooler
» Trans cooler line replacement???
» cooler running power transformer with change in driver tubes ?
» PA-060 Heatsink
» Transmission lines
» RPM are cool on youtube; Horsepower is cooler in the air
