» Mass refugee now in Pa
» 1996 DGM RMW
» Roundup pics?
» Looking for exhaust part
February 2019
 Mystery Oil light
PostSubject: Mystery Oil light   Sun Jul 03, 2011 1:20 am
I was on the way to the beach today and on 95 i noticed that the oil light had come on. I pulled off to check it out and I had no leaks around the intake, nothing leaking down below, I just changed the oil before the mod day, and it was still full of clean oil. I looked in back of the motor and saw that there was some oil around the base of the plug for the sender to the oil light.
I have NO idea whats going on, she runs perfect without any noises what-so-ever:scratch: scratch . Could the sender just be bad and sending info to the comp. to put the light on? It goes out when I rev it at idle but comes back on when i take my foot off the gas.
Any ideas???? Question Question
PostSubject: Re: Mystery Oil light   Sun Jul 03, 2011 9:21 am
If your level is still the same and you don't have leaks I would say the obvious place to start would be a new oil level sensor and then go from there if the light comes back.
PostSubject: Re: Mystery Oil light   Sun Jul 03, 2011 5:02 pm
Figued that but I'm a little paranoid that one of my intake manifold gaskets didnt set the way it should have. I'll do the sensor though.
PostSubject: Re: Mystery Oil light   Sun Jul 03, 2011 5:05 pm
But then you'd have a nice oil/coolant mix.
PostSubject: Re: Mystery Oil light   Sun Jul 03, 2011 5:27 pm
Good point. At least it'd be better than my friends oil/gas mix in his camaro.
I;ll see if I can get the sensor tomorrow morning.
Mystery Oil light
» Pass Key Light?
» Pedestal-mount Tach and shift light
» Solstice-Light-Coors Racing Team
» How many quilters does it take to change a light bulb?
» Light keeps going on and off.
