In total there are 5 users online :: 0 Registered, 0 Hidden and 5 Guests :: 1 Bot
Manual trans question EmptyWed Oct 19, 2022 1:27 pm by scot
Manual trans question EmptyTue Oct 18, 2022 8:58 pm by silverfox103
Manual trans question EmptyTue Sep 28, 2021 11:01 pm by silverfox103
Manual trans question EmptyFri Sep 24, 2021 9:53 am by ElKy
Manual trans question EmptySun Sep 19, 2021 6:22 pm by black blur 96
Manual trans question EmptySun Jun 20, 2021 11:37 am by scot
Manual trans question EmptyFri Jun 11, 2021 10:41 am by scot
Manual trans question EmptyWed Jun 09, 2021 9:41 pm by Chris Klein
Manual trans question EmptyWed Jun 02, 2021 9:02 pm by Chris Klein
2 posters
PostSubject: Manual trans question   Manual trans question EmptySun May 08, 2011 2:34 pm
Does anyone know if you HAVE to use a T56 trans with the lt1? Or can you use any manual trans?
PostSubject: Re: Manual trans question   Manual trans question EmptySun May 08, 2011 5:29 pm
Well, a T56 is a direct bolt-in in place of the 4L60. But you could do any, T5, muncie, saginaw, whatever you like. But there will be more work, such as the custom driveshaft and you'd need to convert the cable speedo to electronic and whatnot. But you could make anything work with the proper amount of time, ingenuity and moolah.
PostSubject: Re: Manual trans question   Manual trans question EmptySun May 08, 2011 5:44 pm
Ok well right now it has a 3 speed with the granny low, I think it's a Muncie or a Saginaw. If I put an lt1 in it I'd like to keep it manual, but I don't wanna pull a hole shot and grenade the trans. What would you recommend for everyday use but will take a beating? The $$ is no big deal for conversion stuff, but I don't wanna spend 1500 on a trans if I don't have to.
PostSubject: Re: Manual trans question   Manual trans question EmptySun May 08, 2011 6:43 pm
Glen has a T56 for sale right now for like 600 bucks!
PostSubject: Re: Manual trans question   Manual trans question EmptySun May 08, 2011 7:19 pm
F me Sad, if I could make it to ME I'd be all over that. will a 2 piece drive shaft work with that? How long is a t56 from bellhousing to the end of the tailshaft? I have about 10 driveshafts kicking around, but no big if I have to get one made. Also does the shifter go directly into the trans or is it external linkages.
PostSubject: Re: Manual trans question   Manual trans question EmptySun May 08, 2011 8:33 pm
Same length as a 4l60 or 700r4.
No idea on the 2 piece DS. Don't see why it wouldn't.
Shifter bolts onto the top of the tranny. No external linkages.
» Another trans question
» Haynes manual
» S10 Manual Steering Box
» Want a manual transmission in your big b?
» WTB Manual Antenna
