Cylinder 5 misfire EmptyWed Oct 19, 2022 1:27 pm by scot
Cylinder 5 misfire EmptyTue Oct 18, 2022 8:58 pm by silverfox103
Cylinder 5 misfire EmptyTue Sep 28, 2021 11:01 pm by silverfox103
Cylinder 5 misfire EmptyFri Sep 24, 2021 9:53 am by ElKy
Cylinder 5 misfire EmptySun Sep 19, 2021 6:22 pm by black blur 96
Cylinder 5 misfire EmptySun Jun 20, 2021 11:37 am by scot
Cylinder 5 misfire EmptyFri Jun 11, 2021 10:41 am by scot
Cylinder 5 misfire EmptyWed Jun 09, 2021 9:41 pm by Chris Klein
Cylinder 5 misfire EmptyWed Jun 02, 2021 9:02 pm by Chris Klein
 Cylinder 5 misfire
JRS9C1
JRS9C1
PostSubject: Cylinder 5 misfire   Cylinder 5 misfire EmptyThu Apr 21, 2011 4:39 pm
Found out today cylinder 5 is misfiring. For those of you familiar with the GM Tech 2 I was in misfire graphic and all cylinders are good except 5...tomorrow plan on swapping wires 5 & 7 on the opti/spark plugs...if that solves it, great, if not, I'll swap injectors on 5 and 7 to see if that does the trick.
I was starting to think it's the opti, but I'd be getting misfires on multiple cylinders...someone correct me if wrong.
Anyone have any other ideas as to what could be causing this? Don't wanna miss anything while I have the car apart (again...) tomorrow.
JRS9C1
JRS9C1
PostSubject: Re: Cylinder 5 misfire   Cylinder 5 misfire EmptyFri Apr 22, 2011 8:40 pm
Another burnt plug wire was the culprit...triple wrapped with heat insulation as well as an OEM spark plug boot shield. Should be ready for drag day.
Cylinder 5 misfire
» 96 9c1 L99 misfire
» WTB --- Cast Iron Cylinder Heads
» Bad stumble/misfire
» I never knew how cheap aluminum LT1 cylinder heads are
» Temporary misfire when hitting bumps
