» Looking for SEO 6J6 wiring [FOUND]
Battery Cable Routing EmptyWed Aug 21, 2019 4:28 pm by MASShole9C1
Battery Cable Routing EmptyThu Aug 08, 2019 9:41 am by CrashMaster
» 1984 Caprice project
Battery Cable Routing EmptySun Jun 30, 2019 8:05 pm by Boxchevy84
» C10: Before and After
Battery Cable Routing EmptySun Jun 02, 2019 3:01 pm by MalibuSSwagon
Battery Cable Routing EmptySat Mar 16, 2019 8:49 am by boojum
» Mass refugee now in Pa
Battery Cable Routing EmptyTue Jan 22, 2019 8:46 am by MASShole9C1
Battery Cable Routing EmptyTue Jan 22, 2019 12:03 am by boojum
» 1996 DGM RMW
Battery Cable Routing EmptyFri Jan 18, 2019 12:00 pm by Gorillabiter
August 2019
Share
PostSubject: Battery Cable Routing   Battery Cable Routing EmptyFri Apr 08, 2011 9:06 am
Does someone mind popping there hood and verifying that I have things at least close...LOL
The positive cables have three wires; One to the starter, one to the fuse box, and the other is cut on my car...what would that have gone to?
The negative was not with the car, so I just picked up the one that Napa called for and it is a single large (physically) gauge wire with a single 10ish gauge "auxiliary" lead that I assume is the body ground...Can someone verify that?
Thanks, hopefully making the final push....
YachtDriver
YachtDriver
PostSubject: Re: Battery Cable Routing   Battery Cable Routing EmptyFri Apr 08, 2011 10:30 am
3rd Wire goes to the Alternator.
So the three leads from positive go to.
Fusebox.
Starter.
Alternator.
Negative is as follows.
One to engine ground and one to body ground.
I have a new replacement battery harness from Innovative wiring. Going through this myself.
www.innovativewiring.com
Douglas.
» Battery Cable Routing
» Impala 96 SS Console shifter cable
» Battery Power for Stainz and Similar Locomotives
» Any body running an AGM battery.
» Star Grounding Scheme Observations and Questions
