 Hood Tach?
LandMaster
PostSubject: Hood Tach?   Tue Mar 29, 2011 4:07 pm
I saw a 70 something GMC with one today and not gunna lie I liked it, and I think it may not look to shabby on the RMS if done right, and I don't mind the A pillar pods but I don't really need three little guages and don't NEED a tach ( the HVAC system can display one) but it would nice to see RPM when I'm cruising would nice. maybe it'll be a real betch to install? What do you guys think?
PostSubject: Re: Hood Tach?   Tue Mar 29, 2011 4:49 pm
I remember the hood mounted tachs from 60's and 70's GTO's & Firebirds. They were pretty sharp!
PostSubject: Re: Hood Tach?   Tue Mar 29, 2011 5:46 pm
easy enough to wire
if you get a sunpro or like, it ususally has 4 wires
RED-Ingintion power
WHITE- + for tach back light
BLACK- Ground
GREEN- Tach signal
splice the red to an ignition source or tuck into a fuse in the panel that only comes on with key on
find the wire that get 12v when the light switch is turned/pulled on splice the white wire here,
black goes to any ground
and the green goes to pin 13 in the RED connector of the pcm (caprice, i assume its the same for roadmaster too)
you could probably pull the wires through where the windshield sprayer hose come up through. and mount where you like it
PostSubject: Re: Hood Tach?   Tue Mar 29, 2011 7:10 pm
Search one out & post it up for info Arrow
PostSubject: Re: Hood Tach?   Tue Mar 29, 2011 7:52 pm
Do it
PostSubject: Re: Hood Tach?   Tue Mar 29, 2011 10:25 pm
I say Hell yes! bounce
LandMaster
PostSubject: Re: Hood Tach?   Wed Mar 30, 2011 1:13 pm
So I was thinking getting one like this
http://www.bing.com/images/search?q=Hood+Tach+for+Buick&view=detail&id=42AD2545D33B346DDD16096F7EB7682A15445E7E&first=1&FORM=IDFRIR
I think its from a late 60s early 70s GSX and I'll probably snag it from...
Here
http://www.mfsperformance.com/index.php?main_page=product_info&products_id=9
When I get it I'll have to figure out the wiring it seems relatively striaght forward
PostSubject: Re: Hood Tach?   Wed Mar 30, 2011 1:21 pm
That looks sweet.
I couldnt picture it before you posted.
Havent seen one in a long time.
Better set something on the hood first to make sure your ok with it.
Wiring is always the simple part, especially because you dont have to go into the cabin.
PostSubject: Re: Hood Tach?   Wed Mar 30, 2011 2:27 pm
I think I remember seeing one on a Grand National back in the early 90s, pretty cool item
PostSubject: Re: Hood Tach?   Wed Mar 30, 2011 8:15 pm
i accually been thinking about the same idea as well. this is the one i been keeping my eye on but want one a bit cheaper. http://cgi.ebay.com/ebaymotors/Pontiac-hood-tachometer-firebird-GTO-never-mounted-/200591388098?pt=Vintage_Car_Truck_Parts_Accessories&hash=item2eb42dadc2#ht_500wt_956
LandMaster
PostSubject: Re: Hood Tach?   Wed Mar 30, 2011 10:29 pm
yea I took an old fake scoop my friend had and put it on, right now the registration sticker blocks the view of were I'd like it to be But I think if I line it up at like around were the hood creases it should look pretty thrifty. I looked at the pontiac one but I saw the one that says buick on it and like that alot more, I have to go into to have a mirror paint matched any ways so I might as well bring that and have it painted too when I get it... could be awhile though they aren't dirt cheap.
PostSubject: Re: Hood Tach?   Thu Mar 31, 2011 5:23 pm
hell the one i been lookin at is a little over $250. be nice if they made the same style gauge without the housing would be alot cheaper, then i could fab up a newer housing. oh well
Hood Tach?
» So, I think I Need A Pontiac Hood Tach Bulge....
» Lets talk hood supports
» FS: IMPALA SS HOOD
» WTB DGGM hood and grill
» Fort Hood Shooting
