 Instrument cluster
PostSubject: Instrument cluster   Sat Mar 05, 2011 8:25 pm
Ok today I went out to remove the stpid idiot lights for pass key and abs well I belive I broke it because the damn fuel gauge goes to full and it's not full all the idiot lights on left don't work and the temp gauge ain't workin Noe do I think oil pressure gauge is either.speedo works all the digital and when headlights Are on the courtesy lights go on do I need a new cluster or no and if I do I need on cheap
PostSubject: Re: Instrument cluster   Sat Mar 05, 2011 9:02 pm
Quit reckin your car. Razz J/K man. Im not sure about this, but it sounds like a mother board or ground issue in the dash.
PostSubject: Re: Instrument cluster   Sun Mar 06, 2011 6:32 am
im gonna check the connection on left side again found that mot 1 idiot light works and check engine should turn on while key is in on position at least speedo is workin right now just hate not knowing the gas situation
PostSubject: Re: Instrument cluster   Sun Mar 06, 2011 2:23 pm
I am a friggin IDIOT YES I WILL SAY IM A IDIOT it was fuse #11 IND 10 amp
im gonna hurt myself now here watch......
Instrument cluster
