 a/c
PostSubject: a/c   Thu Mar 03, 2011 8:52 pm
ok i removed my a/c did the bypass pulley removed lines accumulator and thats it if i remove the condensor in front of rad will this affect the cooling system i/e heat i want it out but dont know if i will have heat after because of more airflow. also the condensor under the dash how easy is it to get out in one piece
a/c
