A/C delete pully EmptyWed Oct 19, 2022 1:27 pm by scot
A/C delete pully EmptyTue Oct 18, 2022 8:58 pm by silverfox103
A/C delete pully EmptyTue Sep 28, 2021 11:01 pm by silverfox103
A/C delete pully EmptyFri Sep 24, 2021 9:53 am by ElKy
A/C delete pully EmptySun Sep 19, 2021 6:22 pm by black blur 96
A/C delete pully EmptySun Jun 20, 2021 11:37 am by scot
A/C delete pully EmptyFri Jun 11, 2021 10:41 am by scot
A/C delete pully EmptyWed Jun 09, 2021 9:41 pm by Chris Klein
A/C delete pully EmptyWed Jun 02, 2021 9:02 pm by Chris Klein
 A/C delete pully
SScarlett_Caprice
6 posters
SScarlett_Caprice
SScarlett_Caprice
PostSubject: A/C delete pully   A/C delete pully EmptyWed Feb 09, 2011 1:41 pm
Theres an ac delete pully available for the lt1 camaro, but as far as ive seen theres not one for the b body. will the camaro pully fit a caprice? i never use my a/c in the summer so its really just in the way.
PostSubject: Re: A/C delete pully   A/C delete pully EmptyWed Feb 09, 2011 2:38 pm
I have one from a lt1 firebird on my impala ss.
PostSubject: Re: A/C delete pully   A/C delete pully EmptyWed Feb 09, 2011 3:29 pm
Yeah, it should be the same part number.
Does your A/C work though? I wouldn't touch anything if it does.
PostSubject: Re: A/C delete pully   A/C delete pully EmptyWed Feb 09, 2011 9:35 pm
i went to advanced and got one for a 96 impala ss. it was pretty easy lol
PostSubject: Re: A/C delete pully   A/C delete pully EmptyWed Feb 09, 2011 11:34 pm
You have to gind off just a little bit off the GM part for it to fit.
PostSubject: Re: A/C delete pully   A/C delete pully EmptyThu Mar 03, 2011 5:56 pm
i can say this mod can be a pain in the ass. so i will tell you what you need to do exactly with the part you get from advanced, auto zone, etc.
First if you have a l99 or ls1 go to advance ask for part number #34209 its a doorman/ motormite a/c bypass pulley and bracket fully assembled.
second remove old a/c compressor 3 bolts in front cant remember size but belive 1/2 or 9/16
you will have 2 10mm bolt on the rear of a/c compressor have fun with these but doable.
next remove a/c lines, accumulator cut bracket for accumulator to hold just power steering res.
after all lines and a/c components are removed then get your bracket and take a 3/8in drill bit and drill out threads on bracket. (very important or will not bolt up properly. second you need fender washers 3/8 x 1/16
take your 3 bolt and put in bracket make sure they slide smooth and place 2 washers on all bolts behind the bracket this will give you the 1/8 in difference between the bracket and original design or it will squeal and blow your bearings.
after it is on and belt is secure start it up and go. thought i would throw this info out there since some people dont know this i didnt and went through 3 pulleys lol.
A/C delete pully
» EGR tube delete
» Air pump delete
» Delete Delete
» Air Pump Delete??
» Mechanical Fan Delete
