water pump seal  EmptyWed Oct 19, 2022 1:27 pm by scot
water pump seal  EmptyTue Oct 18, 2022 8:58 pm by silverfox103
water pump seal  EmptyTue Sep 28, 2021 11:01 pm by silverfox103
water pump seal  EmptyFri Sep 24, 2021 9:53 am by ElKy
water pump seal  EmptySun Sep 19, 2021 6:22 pm by black blur 96
water pump seal  EmptySun Jun 20, 2021 11:37 am by scot
water pump seal  EmptyFri Jun 11, 2021 10:41 am by scot
water pump seal  EmptyWed Jun 09, 2021 9:41 pm by Chris Klein
water pump seal  EmptyWed Jun 02, 2021 9:02 pm by Chris Klein
 water pump seal
2 posters
SScarlett_Caprice
SScarlett_Caprice
PostSubject: water pump seal    water pump seal  EmptyWed Feb 23, 2011 11:05 pm
it seems like part of my oil leak problem is from something at the front of the engine, and it looks sort of like the opti, crank, or water pump drive seals could be leaking. i didnt use the special tool thing to put the water pump seal in, but ive heard that a sharpie cap works kind of the same? i tried using the drive shaft its self but that just mangled the seal so i replaced it again and i think the new(er) one is messed up as well.
the good news is that the temporary hillbilly fix (hose clamps) for the cooler lines is working well. jegs parts will be on the way as money allows. (so probably not any time soon Surprised)
PostSubject: Re: water pump seal    water pump seal  EmptyThu Feb 24, 2011 12:03 am
You can use the wp drive as the install tool, as long as it's cleaned up.
water pump seal
» rear axle seal
» Lt1 water pump install question
» Any good ideas for water pump removal?
» differential bearing and seal
» WP Seal 1
