| 9c1 center caps | |
+4Machine-De-Zine MASShole9C1 GasTT mega 8 posters |
| Subject: 9c1 center caps Thu Mar 03, 2011 6:09 pm | |
| anyone out there got a set of 9c1 center caps they want to get rid of cheap. they will be for a 94 DCM | |
| Subject: Re: 9c1 center caps Sat Mar 05, 2011 1:11 pm | |
| They wont bolt onto stock wheels. You either need to get 9c1 or truck wheels.
Or, you can drill and tap holes in your stock steelies for the center caps to bolt on.
Sorry I don't have any for sale. | |
| Subject: Re: 9c1 center caps Sat Mar 05, 2011 1:25 pm | |
| ah lol i know bout how people drill 3 or 4 holes around the cap and screw em in figure will look close to 9c1's at fraction of cost plus i just love the caps looks hot. maybe ill take the ones we have on a work truck and put em on. thats were the trim rings came from. | |
| Subject: Re: 9c1 center caps Sat Mar 05, 2011 2:33 pm | |
| I just sold 3. I have 2 sets but they are in use. I think i can get you some this week tho. | |
| Subject: Re: 9c1 center caps Sat Mar 05, 2011 2:37 pm | |
| - MASShole9C1 wrote:
- I just sold 3. I have 2 sets but they are in use. I think i can get you some this week tho.
something im looking into in future still gotta get mirrors drivers one is broke, tires but i will definatly want one soon if its cheap | |
| Subject: Re: 9c1 center caps Sun Mar 06, 2011 8:15 pm | |
| how cheap can you get the caps for? prefferably alot cheaper than these.
http://cgi.ebay.com/ebaymotors/1991-1996-Chevy-Caprice-center-caps-9C1-cop-police-_W0QQcmdZViewItemQQhashZitem35b0469d56QQitemZ230590684502QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories#ht_1116wt_1166 | |
| Subject: Re: 9c1 center caps Mon Mar 07, 2011 6:13 am | |
| - I bought those very same ones from eBay.
They are made of a light weight ABS plastic and look very convincing even up close. Its also real chrome, but it does not feel very durably plated.
But the three stand off "bosses" (that on the original die cast pieces, made a secure mounting for the three attachment screws) are VERY weak on these copies.
They will crush easily if you tighten the screws a little too much. Use lock-tight instead of ample torque.
Also, don't use the supplied screws before checking the thread pitch first, mine were wrong.
My N97 wheels are all 8mm x 1.25, but the supplied screws were a coarser thread (maybe 8mm x 1.5) and would not work. I tossed them to avoid problems.
The screws I needed were 8mm x 1.25 & 18-19mm UHL, roughly 3/4" to compare std length. Maybe the trucks are different.
Clean, un-damaged OEM caps are getting harder to locate. They were made with either the gold bow tie emblem or with red GMC letters on the face.
GM part numbers are as follows:
14018276 14018277 14018279 14018280
I am still trying to locate a really close to perfect set, so now I will broaden my search so that hopefully you can get a nice set too.
Got lucky with an auction and won 8 fairly clean ones, 4 bow tie & 4 GMC, for $10 per set plus shipping.
I also have a part number for ARP flanged head attachment screws that will look better than the cruddy OEM bolts.
| Subject: Re: 9c1 center caps Mon Mar 07, 2011 6:17 am | |
| Thats funny, when I was doing it everyone told me 5/16-18. I KNEW that wasnt right (at least not for MY N97's). Thanks for the info | |
| Subject: Re: 9c1 center caps Mon Mar 07, 2011 6:18 am | |
| I can get them, but they wont be cheap. They arent cheap plastic. They are the real thing. | |
| Subject: Re: 9c1 center caps Mon Mar 07, 2011 6:49 am | |
| I would LOVE to finally have one (or two) complete perfect, or nearly so, set/s of OEM die cast caps.
Mine were scratched by the fleet mechanics with their air-gun impact sockets and the serrated flange nuts dug through the chrome.
Then the cars were subjected to snow/ice/salt/sand/grime/brake dust, etc and fleet type facility wash detergents.
Can you say "pitted"?
How "not cheap" are they? You don't have to post the $-amount if you don't want to. | |
| Subject: Re: 9c1 center caps Mon Mar 07, 2011 5:21 pm | |
| I can usually pick some up for 25/per. Its pricy, but not when you cant get them anywhere else. Actuallt, recently I met a kid at school with a box of them, Im going to see what I can snag his for. | |
| Subject: Re: 9c1 center caps Wed Mar 09, 2011 7:38 am | |
| well hell if you can get me a set for 25 would be awsome but i now gotta wait having stalling problems and CEL light is on but scan tool wont give me a code wtf | |
| Subject: Re: 9c1 center caps Wed Mar 09, 2011 9:50 pm | |
| - mega wrote:
- well hell if you can get me a set for 25 would be awsome but i now gotta wait having stalling problems and CEL light is on but scan tool wont give me a code wtf
You using an OBD1 scanner? | |
| Subject: Re: 9c1 center caps Wed Mar 09, 2011 10:28 pm | |
| yep and not getting anything even the paper clip test nothing. | |
| Subject: Re: 9c1 center caps Thu Mar 10, 2011 12:34 am | |
| The light has to be on to pull a code. | |
| Subject: Re: 9c1 center caps Thu Mar 10, 2011 1:11 am | |
| I was under the impression that even though the 94-95 LT1/ L99 cars are OBD1, they aren't like other GM OBD1 cars and use a special ECM where you still need to scan them, and the paperclip test doesn't work? Not certain though. | |
| Subject: Re: 9c1 center caps Thu Mar 10, 2011 1:23 am | |
| There are error codes that will not set the check engine light.
The "paper clip" will get you ABS codes provided the ABS light is not on for '94s, I'm not sure about '95s.
The "paper clip" will not get you PCM codes. I think maybe the Haynes manual says it works. | |
| Subject: Re: 9c1 center caps Thu Mar 10, 2011 7:32 am | |
| its weird because even the scan tool wont give em i pulled into autozone while light was on and tested it no codes. paper clip dont do abs on 94 either. im on the verge oof just getting a pcm from the yard if i cant figure this with a new egr | |
| Subject: Re: 9c1 center caps | |
| 9c1 center caps | |
