| | Going to look at an SS today... | |
+4Matt Trakker Ironfistdog No Moa 95brmw 8 posters | Author | Message |
| Subject: Going to look at an SS today... Tue Feb 08, 2011 9:57 am | |
| After buying my 9C1, I have an urge for the real thing. I found a 96 SS with 60k locally that the owner says has some rust. It's a one owner car, DCM (my favorite color), has the WX3 code, and he says the interior has no rips, but the carpet needs to be cleaned. I have to find out the actual milage though, he says the odometer blacked out. Depending on rust, what would you guys realistically pay for one? The book shows around $10k, which I know you can probably never get close to. Heres the compnine breakdown:
UH8 CLUSTER-COOL TEMP, TACH, TRIP ODOM GA(UH8) 41,941 UN0 RADIO,AM/FM,STEREO,SEEK/SCAN,COMPACT DISC,AUTO TONE,CLOCK,ETR STEREO W/CD PLAYER(UN0) 40,552 UQ1 RADIO,PROVISIONS FOR STEREO STEREO RDO PR0VISIONS(UQ1) 93,205 UQ5 SPEAKER SYSTEM,4,DUAL FRONT DOOR MOUNTED,DUAL EXTENDED RANGE QUARTER MOUNTED 4 SPKR SYS(UQ5) 82,516 U75 ANTENNA,POWER(CHROME) PWR ANT(EXPORT)(U75) ANTENNA,POWER(CHROME) PWR ANT(U75) 82,153 VK3 LICENSE PLATE,FRONT MOUNTING PACKAGE FRT LIC PLT MTG PKG(VK3) 84,728 VL7 BUMPER STANDARD IMPACT, 5 MPH, FRONT AND REAR, NEW YORK 5 MPH FRT & RR BMPR IMPACT STANDARD-NEW YORK(VL7) 5,310 V03 COOLING SYSTEM,EXTRA CAPACITY EXTRA CAPACITY CLG(V03) 69,634 V73 VEHICLE STATEMENT - US/CANADA US/CANADA VEHICLE STATEMENT(V73) 71,987 WS7 Unk. 33,031 WX3 IMPALA SS IMPALA SS(WX3) 33,031 1AY ORDER MODIFICATION - STOCK 41,756 1SE PACKAGE OPTION 05 (1SE) 41,482 14I INTERIOR TRIM LT GRAY (14I) 57,462 143 TRIM COMBINATION,LEATHER, LT GRAY (143) 41,941 6TY COMPONENT FRT LH COMPUTER SEL SUSP (6TY) SUSP(6TY) 41,941 7TY COMPONENT FRT RH COMPUTER SEL SUSP (6TY) SUSP(7TY) 41,941 77Q MOLDING COLOR,DARK MAPLE RED METALLIC (77Q) 15,915 77U EXTERIOR COLOR,PRIMARY (77U) EXTERIOR COLOR,PRIMARY,DARK CHERRY METALLIC (77U) 15,936 8HL COMPONENT RR LH COMPUTER SEL SUSP (8HL) SUSP(8HL) 41,941 9HL COMPONENT RR RH COMPUTER SEL SUSP (9HL) SUSP(9HL) 41,941 AA7 WINDOW,ELECTRIC OPERATED,QUICK OPENING QUICK OPG ELEC WDO(AA7) 91,901 AG1 ADJUSTER FRT ST POWER, MULTI-DIRECTIONAL, DRIVER MULTI-DIRECTIONAL PWR D/SEAT ADJR(AG1) 78,575 AG2 ADJUSTER,SEAT,6-WAY POWER,SPLIT BENCH,PASSENGER 6-WAY PWR P/SEAT ADJR(AG2) 73,491 AK5 RESTRAINT SYSTEM,FRONT SEAT,INFLATABLE,DRIVER AND PASSENGER DRIVER & PASS F/SEAT INFL RST SYS(AK5) 94,594 AP9 NET,CONVENIENCE CONVENIENCE NET(AP9) 67,493 ARL PLANT CODE-ARLINGTON TX, CPC ARLINGTON,TX ASSEMBLY PLANT(ARL) 94,594 AS7 SEAT,55-45 FRONT SPLIT FRT SPLIT ST(AS7) 51,893 AU0 LOCK CONTROL,REMOTE ENTRY(KEYLESS ENTRY SYSTEM) REMOTE ENTRY LK CONT(AU0) 66,312 A23 WINDSHIELD-HEAT REFLECTIVE HT REFLECTIVE W/S(A23) 58,579 A90 LOCK,REAR COMPARTMENT LID,REMOTE CONTROL,ELECTRIC RELEASE ELEC REL LID LK(A90) 82,156 BA5 ORNAMENTATION,EXTERIOR(CUSTOM) CUSTOM EXTR(BA5) ORNAMENTATION,EXTERIOR(CUSTOM)(PONTIAC GTP) PONTIAC GTP(BA5) 41,941 BC9 ORNAMENTATION,EXTERIOR,HOOD(DELETE) BC9) 41,941 BD2 ORNAMENTATION,EXTERIOR(DELETE) BD2) 41,941 BV8 ORNAMENTATION EXTR DR HANDLE, LOCK CYLINDER, COLOR PAINTED DR LK CYL & DOOR HANDLE(BV8) 53,777 B19 ORNAMENTATION,INTERIOR(CUSTOM) CUSTOM INTR(B19) 41,941 C4A MERCHANDISED PKG - SAVER 1 82,119 C49 DEFOGGER,REAR WINDOW,ELECTRIC ELEC RR WDO DEFG(C49) 93,334 C60 AIR CONDITIONER,FRONT,MANUAL CONTROLS A/C MAN CONT(C60) 94,594 C71 LAMP,INTERIOR,FRONT DOOR COURTESY FRT DR CTSY LP(C71) 66,436 C96 LAMP,INTERIOR,QUARTER COURTESY AND SINGLE READING QUARTER CTSY & RDG LP(C96) 82,819 DD2 MIRROR,INSIDE,SUNSHADE,COVERED I/S CVR S/S MIR(DD2) 66,548 DE5 MIRROR,OUTSIDE,LH & RH,REMOTE CONTROL,ELECTRIC,DEFOG,FOLDING,PAINTED O/S MIR(DE5) 82,156 DF6 MIRROR I/S R/V TILT, AUTO, DUAL READING LAMPS I/S REAR VIEW TILT(DF6) 81,726 DL5 DECAL ROADSIDE SERVICE INFORMATION ROADSIDE SERVICE INFO DECAL(DL5) 69,089 D55 CONSOLE,FRONT COMPARTMENT FLOOR F/CMPT FLR CNSL(D55) 41,941 D64 MIRROR,INSIDE,RH VISOR VANITY,ILLUMINATED ILLUM S/S MIR(D64) 74,667 FE4 SUSPENSION SYSTEM SPECIAL RIDE & HANDLING SPECIAL SUSP(FE4) 51,659 GU4 AXLE,REAR,3.08 RATIO 3.08R(GU4) 49,737 G80 AXLE,REAR,POSITRACTION,LIMITED SLIP POSITRACTION L/SLIP R/AXL(G80) 68,409 IH3 TRIM,INTERIOR DESIGN TRIM, INT DES(IH3) 41,941 JB9 BRAKE LIGHT WEIGHT, DISC/DISC BRAKE,LT WGT,DISC/DISC(JB9) 41,941 JL9 BRAKE SYSTEM,POWER,FRONT AND REAR DISC,ANTILOCK FRT & RR DISC ANTILOCK BRK(JL9) 52,800 KC4 COOLING SYSTEM,ENGINE OIL ENG OIL CLG(KC4) 67,791 KD1 COOLING SYSTEM,TRANSMISSION OIL TRANS OIL CLG(KD1) 69,265 KG9 GENERATOR,140 AMPERE 140 AMP(KG9) 78,995 K34 CRUISE CONTROL,AUTOMATIC,ELECTRONIC CRCONT(K34) 83,486 LT1 ENGINE-GAS, 8 CYL, 5.7L(5.7P),MFI,HO 5.7P(LT1) 68,501 MX0 TRANSMISSION,AUTOMATIC,OVERDRIVE(MERCHANDISING OPTION) A/TRANS PROVISIONS(MX0) 94,594 M30 TRANSMISSION,AUTOMATIC 4 SPEED,4L60E,ELECTRONIC 4-SPD A/TRANS(M30) 94,594 NB6 EMISSION SYSTEM CALIFORNIA,TIER 1 CALIF EMIS, TIER 1(NB6) 10,098 NG1 EMISSION CERTIFICATION,GEOGRAPHICALLY RESTRICTED CERTIFICATION RESTRICTED EMIS CERTIFICATION(NG1) 5,840 NG5 REGISTRATION EMISSION, CERTIFICATION, FIFTY STATE (50) FIFTY STATE U.S. EMIS(NG5) 69,126 NK4 STEERING WHEEL,SPORT,LEATHER SPORT WHL(NK4) STEERING WHEEL,SPORT,LEATHER WRAPPED LEATHER WRAPPED SPORT STRG WHL(NK4) 60,757 N10 EXHAUST SYSTEM,DUAL D/EXH(N10) 68,501 N40 STEERING,HYDRAULIC(NON-VARIABLE) NON-VARIABLE P/S(N40) 94,594 N81 TIRE,SPARE(FULL SIZE RADIAL) FULL SIZE RADIAL SPA(N81) TIRE,SPARE(FULL SIZE RADIAL)(EXPORT) FULL SIZE RADIAL SPA(N81)(EXPORT) 93,426 PB4 LOCK KIT,ALUMINUM WHEEL AL WHL LOCK KIT(PB4) 72,513 QA0 WHEEL 17 X 8.5 ALUMINUM, STYLED STYLED ALUM WHL(QA0) 41,941 QBJ TIRE ALL P255/50ZR17 BW R/PE ST TL AL3 TIRE(QBJ) 41,941 R7A Unk. 69,089 TL4 GRILLE,PAINTED PAINTED GRL(TL4) 41,941 T43 SPOILER,REAR RR SPLR(T43) 41,941 T82 HEADLAMPS,AUTOMATIC ON/OFF CONTROL AUTO HDLP CONT(T82) 64,537 T87 LAMP,CORNERING COR LP(T87) 73,931
| | | No Moa
| Subject: Re: Going to look at an SS today... Tue Feb 08, 2011 11:49 am | |
| It would have to be mint to get 10k for it. If it has rust, and the carpets filthy, i'd question the mileage. probably more like 160k not 60k.
It really depends, i've bought so many of them in the past 10 years. 2500-5k depending.
| | | Ironfistdog
| Subject: Re: Going to look at an SS today... Tue Feb 08, 2011 2:33 pm | |
| I know its a little work, but won't cost you a dime: If you have an ebay account or know someone who does, ask the guy for the VIN number Take the number and go to ebay and start a listing for an impala ss, put in the VIN and put the starting bid @ 40,000 or some ridiculous number that no one Is gonna bid (This may work in the classified section too not sure, ebay automatically will incluse an autocheck on the vehicle (which was automatically loaded when you type in the VIN. After posting you can click on the auto check and it will give you the entire history of the car, registrations and inspections all the way back to new. With each inspection the mileage should be listed. Obviously if its got one listed at over 60k you know he's full of shit. You can cancel the ebay post now and use item is no longer for sale as the reason and you are charged nothing for listing/unlisting.
I have done this 6 times to find out the true mileage on my caddy brougham and 5 caprices. Worked everytime and on 2 occasions caught someone full of shit and the mileage was actually 3 times what they said it was! Swapped a digi gauge from the junkyard and I wouldve never known! Worth a shot! I'll do it myself if you wanna PM me the VIN | |
| | | 95brmw
| Subject: Re: Going to look at an SS today... Tue Feb 08, 2011 3:23 pm | |
| - Ironfistdog wrote:
- I know its a little work, but won't cost you a dime:
I have done this 6 times to find out the true mileage on my caddy brougham and 5 caprices. Worked everytime and on 2 occasions caught someone full of shit and the mileage was actually 3 times what they said it was! Swapped a digi gauge from the junkyard and I wouldve never known! Worth a shot! I'll do it myself if you wanna PM me the VIN Thats an awesome idea! I'm gonna give that a shot. I did get the vin from him so I could check compnine and see that it was a true SS (at least as far as the vin shows). | |
| | | 95brmw
| Subject: Re: Going to look at an SS today... Tue Feb 08, 2011 3:42 pm | |
| That is so cool! I just did that and he is full of shit. The last reading was in NY in 2005 at 140k. I'm still going to look at it, but knowing this he isnt gonna get the asking price out of me, thats for sure. Thanks for the tip. | |
| | | Matt Trakker
| Subject: Re: Going to look at an SS today... Tue Feb 08, 2011 4:24 pm | |
| - 95brmw wrote:
- That is so cool! I just did that and he is full of shit. The last reading was in NY in 2005 at 140k. I'm still going to look at it, but knowing this he isnt gonna get the asking price out of me, thats for sure. Thanks for the tip.
What a great idea! Can't believe I never thought of that. I have gotten free Carfaxes from people on FSC before but this is ingenious. | |
| | | Ironfistdog
| Subject: Re: Going to look at an SS today... Tue Feb 08, 2011 4:28 pm | |
| Not a problem guys! Glad to help! I came up with this after getting poked hard on a 94 caprice with a faulty gauge. Been working ever since! | |
| | | 95brmw
| Subject: Re: Going to look at an SS today... Tue Feb 08, 2011 5:08 pm | |
| And btw, the classified section worked for me and was a lot less work than listing an auction. Took a few minutes to get what I wanted. | |
| | | Ironfistdog
| Subject: Re: Going to look at an SS today... Tue Feb 08, 2011 5:15 pm | |
| Ahhh I thought so yeah its quicker w/ the classified, I didn't wanna say it would work and then it not. I knew for a fact the national ad would. I'm glad it worked out for you. Next time I do it -'ll have to use the classified way for a quicker check! | |
| | | Pooge
| Subject: Re: Going to look at an SS today... Tue Feb 08, 2011 6:01 pm | |
| Great idea about ebay!
Walk away from the car, there is more they are hiding, guarantee it.
Duog | |
| Subject: Re: Going to look at an SS today... Tue Feb 08, 2011 7:57 pm | |
| I know a nice, modded, 6 speeded, 95 that the history is well documented on that you could have for $7500... | |
| | | 95brmw
| Subject: Re: Going to look at an SS today... Tue Feb 08, 2011 9:25 pm | |
| This is the CL ad for it. Random price drop? Hmmm, I wonder how much of a mess this car really is http://newhaven.craigslist.org/cto/2202358385.html | |
| | | 1984twodoor
| | | | chapel
| Subject: Re: Going to look at an SS today... Wed Feb 09, 2011 4:18 pm | |
- I know a nice, modded, 6 speeded, 95 that the history is well documented on that you could have for $7500...
mmmmmmmmmm | |
| | | 95brmw
| Subject: Re: Going to look at an SS today... Wed Feb 09, 2011 8:28 pm | |
| The guy sold it to the body shop that was appraising the rust repairs. Kind of a good thing. If I had bought the SS, I would have to sell my 9C1 due to lack of room, and I really like the 9C1. Hard to resist the DCM SS though, thats my favorite B-body color. | |
| Subject: Re: Going to look at an SS today... | |
