My '95, after normal driving yesterday, sat covered in a foot of snow all ight until 11am. wont start. Fuel pump turns on, I can smell fuel, no leaks, battery is tight and 4 months old. Given that the opti, plugs and wires, need to be changed, cold this be the issue. It runs very slow and then stops. no air restrictions and the proper sensor connections are made and dry. Hopefully theres no vapor lock or anything. Maybe inside the opti spark is frozen. Im leaving the hood open so it can thaw in the sun light. Any help will be appreciated. Thanks
