| help!!!!!!! | |
| Subject: help!!!!!!! Tue Feb 01, 2011 10:27 am | |
| alright iam workin on my 94 9c1. had a bad brake line so i replaced it and blead the rears. i would have a petal with the car off but if u held it it would slowly sink 2 the floor and if u started it. the petal would go to the floor.. so i put my master cylinder in it from the impala 2 see if that was it. put it is still doin the same. i bled all 4 wheels many times. there all getting fluid.. where do i go from here???? iam bein told it still could be air in the abs, a bad caliper, or booster?? iam lost on ot now. i need 2 get it goin 2night.. | |
| Subject: Re: help!!!!!!! Tue Feb 01, 2011 10:34 am | |
| I had good brake pedal when I had it. The two things I would check is brake pad thickness. If two or more corners are down to 2/32 or so on the pad, you are not going to get a good brake pedal. It also sounds like you still may have air in the rear. I would replace all the fluid in the system by filling the master cylinder and keep bleeding until only fresh fluid squirts out. How are you bleeding the system? Start with the pass rear, then the drivers rear, then the pass front, then finally the drivers front. Also try pumping the pedal a couple times. |
| Subject: Re: help!!!!!!! Tue Feb 01, 2011 11:09 am | |
| & hit the caliper with a rubber mallet before you start bleeding. My car basically gravity feeds the calipers but that rear brakeline takes a while to clear the air
| Subject: Re: help!!!!!!! Tue Feb 01, 2011 11:23 am | |
- & hit the caliper with a rubber mallet before you start bleeding.
+1 mine took forever. | |
| Subject: Re: help!!!!!!! Tue Feb 01, 2011 6:05 pm | |
| ya i bled them last night again in that same pattern.. rr,lr,rf,lf. not sure where 2 go from here. iam goin 2 fill it up again 2night and bleed the all the crap out of it. ill keep everyone filled in | |
Grumpy
| Subject: Re: help!!!!!!! Tue Feb 01, 2011 6:36 pm | |
| gravity bleed em.. AGAIN. | |
| Subject: Re: help!!!!!!! Thu Feb 03, 2011 1:00 am | |
| ok before i go and fully bleed the system again. i went ahead and bought new front calipers, pads, rotors.. it needed it anyways and the bleeders sucked on the old ones.. i pulled everything apart 2night and i found that the pads are junk the inside pad has a washer thickness left 2 it. also because of that the caliper piston was pushed way out of the caliper. so i believe that is my problem with losing the pressure. it has no stroke left. both sides are like that in the front.. heres some pics... here is the caliper as it was when i pulled it off (the fluid is from pullin the line off) and here is the inside pad there is nothin left to it.. | |
| Subject: Re: help!!!!!!! Thu Feb 03, 2011 5:53 am | |
| If the bleeders even worked, that was a miracle. I dont think it was a piston travel thing. I've seen people eat the pad completely. With new parts you've eliminated that anyway.
BTW dont do a brake job with your dress shirt on | |
| Subject: Re: help!!!!!!! Thu Feb 03, 2011 7:13 am | |
- If the bleeders even worked, that was a miracle.
BTW dont do a brake job with your dress shirt on lol thats my work shirts for the shop i work at.. and yes that eliminates that as being a problem plus i needed them any how. | |
| Subject: Re: help!!!!!!! Thu Feb 03, 2011 8:58 am | |
| But if that was a 9c1 caliper and non-9c1 pads, the piston may have travelled too far? | |
| Subject: Re: help!!!!!!! Thu Feb 03, 2011 9:01 am | |
- But if that was a 9c1 caliper and non-9c1 pads, the piston may have travelled too far?
Never thought of that, but that would definatly cause issues. | |
| Subject: Re: help!!!!!!! Thu Feb 03, 2011 9:09 am | |
| Did you put anti-sieze on the bleeders? Thats the only reason my 95 calipers failed. | |
| Subject: Re: help!!!!!!! Thu Feb 03, 2011 10:20 am | |
now that u say that i think your right.. they seemed wrong just because how small they were inside the caliper.. well it will have all new everything 2night and iam crossing my fingers it has a nice petal. bacause iam driving it to penn. next weekend | |
| Subject: Re: help!!!!!!! Fri Feb 04, 2011 10:01 am | |
| Here one of the pads I pulled off my Caprice wagon, no wonder it stopped so poorly! | |
| Subject: Re: help!!!!!!! Fri Feb 04, 2011 10:52 am | |
| - 96slowss wrote:
- ok so i installed new calipers,pads,rotors,wheel berrings and seals 2night on the caprice.. gravity bleed the rears and normally bleed the new front calipers seeing i had fluid already in the lines up front.. the brakes will put into the dash now!! there mint. still planning on doin rear rotors and pads and possibily calipers as well so i know everthing is perfect.. i took a few pics
and yes i painted my calipers red. some people hate it but they look good behind the 9c1 wheels..
Looks good. Nice time of the year to have good brakes... - 95brmw wrote:
- Here one of the pads I pulled off my Caprice wagon, no wonder it stopped so poorly!
Exactly what I expect to find as soon as I can get into my RMW It sux having to baby the car to a stop because the ABS is off & 1 side locks up WAY before the other | |
| Subject: Re: help!!!!!!! Sat Feb 05, 2011 9:33 am | |
| thanks. it stops awsome! and drives real good. taking it to penn. next weekend. hopefully all gos well.. | |
| Subject: Re: help!!!!!!! Sat Feb 05, 2011 8:04 pm | |
| - 96slowss wrote:
- thanks. it stops awsome! and drives real good. taking it to penn. next weekend. hopefully all gos well..
Lookin good Mike, aren't brakes a blast! | |
| Subject: Re: help!!!!!!! Sun Feb 06, 2011 9:52 am | |
| - Tomz9C1 wrote:
Lookin good Mike, aren't brakes a blast! oh ya there a blast! not! it does make it alot easier when ur dealing with all new stuff | |
| Subject: Re: help!!!!!!! | |
| help!!!!!!! | |
