March 2018
 Crank/ no start
PostSubject: Crank/ no start   Thu Jan 27, 2011 12:24 pm
My '95, after normal driving yesterday, sat covered in a foot of snow all ight until 11am. wont start. Fuel pump turns on, I can smell fuel, no leaks, battery is tight and 4 months old. Given that the opti, plugs and wires, need to be changed, cold this be the issue. It runs very slow and then stops. no air restrictions and the proper sensor connections are made and dry. Hopefully theres no vapor lock or anything. Maybe inside the opti spark is frozen. Im leaving the hood open so it can thaw in the sun light. Any help will be appreciated. Thanks
PostSubject: Re: Crank/ no start   Thu Jan 27, 2011 1:08 pm
Moisture in the opti frozen would be my guess to.
Crank/ no start
» Lt1 long crank?
» How do you get the courage to start writing?
» No Start---No Spark
» Start of Memory book
» Birch Crank Phonograph
