| HEADLIGHTS NOT WORKING | |
| Subject: HEADLIGHTS NOT WORKING Thu Feb 05, 2009 8:56 pm | |
| PARKING LIGHTS WORK TURNING SIGNALS WORK HIGHBEAMS WORK HEADLIGHTS DONT? I BOUGHT A HEADLIGHT SWITCH THINKING THAT WAS THE PROBLEM BUT WASNT WHAT COULD IT BE? | |
| Subject: Re: HEADLIGHTS NOT WORKING Thu Feb 05, 2009 9:53 pm | |
| - BoSStonsSS wrote:
- PARKING LIGHTS WORK
WHAT COULD IT BE? Behind the passenger side footwell trim. The piece that goes from under the dash, and becomes the door sill. There is a white box whith a wire harness. This is the control box for twilite centinal. It may have failed and needs replacement. But there is a maxi fuse for just the head lights I think in the fuse panel. Try there first. |
| Subject: Re: HEADLIGHTS NOT WORKING Thu Feb 05, 2009 9:58 pm | |
| I had both bulbs fail at the same time on my old 9C1. I couldn't believe it! Did you check them? I know it seems unlikely... | |
| Subject: Re: HEADLIGHTS NOT WORKING Thu Feb 05, 2009 10:09 pm | |
- I had both bulbs fail at the same time on my old 9C1. I couldn't believe it! Did you check them? I know it seems unlikely...
would the high beams still work if the bulbs failed? | |
| Subject: Re: HEADLIGHTS NOT WORKING Thu Feb 05, 2009 10:12 pm | |
would the high beams still work if the bulbs failed? Pull the bulbs out and inspect the elements. And yes if the lower elements are the only thing that failed. |
| Subject: Re: HEADLIGHTS NOT WORKING Thu Feb 05, 2009 10:25 pm | |
would the high beams still work if the bulbs failed? Mine did. | |
| Subject: Re: HEADLIGHTS NOT WORKING Thu Feb 05, 2009 10:28 pm | |
| i'll check tomarrow morning its freezing out there(and finish watching the celts and lakers)...... thanx guyz will definitely check alll those things | |
| Subject: Re: HEADLIGHTS NOT WORKING Fri Feb 06, 2009 7:14 pm | |
| Its the black wire connected to the blue socket thingy( its burnt).. what should i do? | |
| Subject: Re: HEADLIGHTS NOT WORKING Fri Feb 06, 2009 9:54 pm | |
| - BoSStonsSS wrote:
- Its the black wire connected to the blue socket thingy( its burnt).. what should i do?
Splice in a new wire. Or you can replace the whole socket. They sell them at Autozone and PepBoys... Upgrade the wiring. APC makes a nice, cheap harness. There's plenny on eBay, too... (And it'll help your light output, too! ) | |
| Subject: Re: HEADLIGHTS NOT WORKING Fri Feb 06, 2009 11:03 pm | |
| thanx man appreciate it | |
| Subject: Re: HEADLIGHTS NOT WORKING | |
