 BRAKES!
PostSubject: BRAKES!   Wed Jan 05, 2011 8:36 am
THE DAY THE STORM happened i was coming a down a hill i pressed the brakes and it went almost to the floor . i checked the the brake fluid and it was fine. So the next day it happened again and i checked aagain . i Mustve left the cap off and the fluid was low ,so i filled it.
Still goes to the floor . Does it need to bled?
PostSubject: Re: BRAKES!   Wed Jan 05, 2011 8:58 am
Good starting point to find out whats really wrong.
Brakes dont go to the floor for no reason.
If you hadnt done any work theres a problem.
Did the idiot light come on (prop valve off center)?
Dont screw around, take it to a mechanic.
Good tires & brakes are the only thing between you & disaster
PostSubject: Re: BRAKES!   Wed Jan 05, 2011 10:04 am
Yes the idiot brake light came on..im not driving the car anymore its off the road in the driveway...
PostSubject: Re: BRAKES!   Wed Jan 05, 2011 10:19 am
99% chance if the idiot light is on you lost a brakeline.
If the inside of the wheel is wet the caliper may be shot.
Neither one of these is a big deal, just a PIA
Glad it didnt put you in a bad spot.
Did you use the old....
"Honey.....I NEED a new car, the brakes are gone on this one & I dont want to die" line?
PostSubject: Re: BRAKES!   Wed Jan 05, 2011 8:30 pm
It's got a leak at the frame rail under the driver's seat. I can almost see it from here.
PostSubject: Re: BRAKES!   Wed Jan 05, 2011 9:07 pm
If its the back. For some reason I was thinking front.
When my rear went it was behind the fuel filter
Find out which reservior goes dry & that'll confirm it
PostSubject: Re: BRAKES!   Thu Jan 06, 2011 2:50 am
the front reservoir was empty when i checked it.
PostSubject: Re: BRAKES!   Thu Jan 06, 2011 6:01 am
Jims right then.
Rear line goes down the drivers frame rail, curves past the LCA & lands on the rubber line on top of the differential. You should see the wet spot if you look for it
PostSubject: Re: BRAKES!   Thu Jan 06, 2011 8:39 am
Jims right then.
Something about flour and a wet spot?
In all seriousness, my last brake line break was at the fuel pump on the driver side just under the driver rear door.
Good luck man!
BRAKES!
» WW II German 7.5cm Pak40 Barrel with Late Muzzle Brake
» New guy from North Shore
» Caprice or Impala Rear End
» OTC Brake Rotors
» Brake/burning wires smell.
