| BRAKES! | |
| Subject: BRAKES! Wed Jan 05, 2011 8:36 am | |
| THE DAY THE STORM happened i was coming a down a hill i pressed the brakes and it went almost to the floor . i checked the the brake fluid and it was fine. So the next day it happened again and i checked aagain . i Mustve left the cap off and the fluid was low ,so i filled it.
Still goes to the floor . Does it need to bled? | |
| Subject: Re: BRAKES! Wed Jan 05, 2011 8:58 am | |
| Good starting point to find out whats really wrong. Brakes dont go to the floor for no reason. If you hadnt done any work theres a problem. Did the idiot light come on (prop valve off center)? Dont screw around, take it to a mechanic. Good tires & brakes are the only thing between you & disaster | |
| Subject: Re: BRAKES! Wed Jan 05, 2011 10:04 am | |
| Yes the idiot brake light came on..im not driving the car anymore its off the road in the driveway... | |
| Subject: Re: BRAKES! Wed Jan 05, 2011 10:19 am | |
| 99% chance if the idiot light is on you lost a brakeline. If the inside of the wheel is wet the caliper may be shot. Neither one of these is a big deal, just a PIA Glad it didnt put you in a bad spot. Did you use the old.... "Honey.....I NEED a new car, the brakes are gone on this one & I dont want to die" line? | |
| Subject: Re: BRAKES! Wed Jan 05, 2011 8:30 pm | |
| It's got a leak at the frame rail under the driver's seat. I can almost see it from here. | |
| Subject: Re: BRAKES! Wed Jan 05, 2011 9:07 pm | |
| - boojum wrote:
- It's got a leak at the frame rail under the driver's seat. I can almost see it from here.
If its the back. For some reason I was thinking front. When my rear went it was behind the fuel filter Find out which reservior goes dry & that'll confirm it | |
| Subject: Re: BRAKES! Thu Jan 06, 2011 2:50 am | |
| the front reservoir was empty when i checked it. | |
| Subject: Re: BRAKES! Thu Jan 06, 2011 6:01 am | |
- BoSStonsSS wrote:
- the front reservoir was empty when i checked it.
Jims right then. Rear line goes down the drivers frame rail, curves past the LCA & lands on the rubber line on top of the differential. You should see the wet spot if you look for it | |
| Subject: Re: BRAKES! Thu Jan 06, 2011 8:39 am | |
Jims right then. Rear line goes down the drivers frame rail, curves past the LCA & lands on the rubber line on top of the differential. You should see the wet spot if you look for it Something about flour and a wet spot? In all seriousness, my last brake line break was at the fuel pump on the driver side just under the driver rear door. Good luck man! Doug | |
| Subject: Re: BRAKES! | |
| BRAKES! | |
