| Wagon Rookie | |
| Subject: Wagon Rookie Mon Jan 03, 2011 10:15 am | |
| The wagon tailgate doesnt open. How do I get into it? I'm assuming there's an access panel back there where I can pop the glass & then open the gate ....is that correct? I have 1 arm for now & there's an extra rear seat thrown back there so I'm just taking the easy way out & typing instead of tearing into it. Thanks | |
| Subject: Re: Wagon Rookie Mon Jan 03, 2011 10:23 am | |
| damn 1 arm excuse, you going to use that forever or what? Try the latch? | |
| Subject: Re: Wagon Rookie Mon Jan 03, 2011 10:33 am | |
| Glen is correct!
Steve, do you mean the button inside, does not pop the rear window? The rear gates can be temperamental. Try unlocking the rear window with your key. I think you turn it all the way to the right. It will pop the glass and then you can open the door.
Last edited by silverfox103 on Mon Jan 03, 2011 10:41 am; edited 1 time in total | |
| Subject: Re: Wagon Rookie Mon Jan 03, 2011 10:34 am | |
| Its the drugs hez on Tom, i'm convinced of that. lol | |
| Subject: Re: Wagon Rookie Mon Jan 03, 2011 10:47 am | |
| Wagon FOR SALE.... I'm not dealing with these wagon AHoles.... Justin told me the rear glass doesnt open. I ASSUME the glass needs to open BEFORE the gate will (as Tom just confirmed) I'll figure out how to pop the glass Thanks I go to the DR. in an hour. I'll ask him how long I can use this excuse for. Until then, please duct tape your best arm to your body to feel my pain... | |
| Subject: Re: Wagon Rookie Mon Jan 03, 2011 10:49 am | |
| Inspector Girard and Dr. Richard Kimball are still looking for the one armed man. Do you think it could be..................
Tom C. | |
| Subject: Re: Wagon Rookie Mon Jan 03, 2011 10:54 am | |
| Had they known to look for him in the back of a RMW the series would have ended Of course the RMW wasnt a hiding spot until 30 yrs later...but.... OK, NOW its the drugs kickin in... | |
| Subject: Re: Wagon Rookie Mon Jan 03, 2011 10:56 am | |
- Wagon FOR SALE....
I go to the DR. in an hour. I'll ask him how long I can use this excuse for. Until then, please duct tape your best arm to your body to feel my pain... Hey, i don't own a wagon, so i'm just an Ahole. I'm not duct taping anything on my hairy body. | |
| Subject: Re: Wagon Rookie Mon Jan 03, 2011 12:33 pm | |
| - silverfox103 wrote:
- Glen is correct!
Tom Did you get in Steve? | |
| Subject: Re: Wagon Rookie Mon Jan 03, 2011 12:37 pm | |
| he at the dr getting his arm checked to see how much longer he will be a 1 armed car guy! | |
| Subject: Re: Wagon Rookie Mon Jan 03, 2011 12:42 pm | |
| If the glass won't open you'll have to remove the tailgate solenoid from the inside which will be a pain to do. Does it not open at all or just not open by the button? | |
| Subject: Re: Wagon Rookie Mon Jan 03, 2011 4:12 pm | |
| Did you actually try the key in the popper button on the gate? Turn it and the glass should pop. Pretty sure that bypasses the "popper" and pops it manually. If not, you need to try and remove the plastic panel, and it may be damaged during removal while closed. There is 2 small screws on each handle at the top of the gate and you can remove those. Then the panel itself has a couple screws on the outer edge of it. Two in the middle and two at the lower corners, IIRC. There are also a half dozen screws at the top of the panel that go in from the glass side though. Good luck on those. That's why I think the panel will be broken during removal. Wait. You live in Ma. Break the glass. It's free replacement.
Last edited by toomanytoyz on Mon Jan 03, 2011 4:19 pm; edited 1 time in total | |
| Subject: Re: Wagon Rookie Mon Jan 03, 2011 8:41 pm | |
| Subject: Re: Wagon Rookie Mon Jan 03, 2011 8:53 pm | |
| Subject: Re: Wagon Rookie Mon Jan 03, 2011 9:56 pm | |
- Did you actually try the key in the popper button on the gate? Turn it and the glass should pop. Pretty sure that bypasses the "popper" and pops it manually.
If not, you need to try and remove the plastic panel, and it may be damaged during removal while closed............... I sent a guy out to unload it. He screwed with the keys in the popper button. I'll try it again tommorrow Thanks | |
| Subject: Re: Wagon Rookie | |
| Wagon Rookie | |
