 Oh boy CEL on and fans running. CTS replaced twice
PostSubject: Oh boy CEL on and fans running. CTS replaced twice   Tue Dec 07, 2010 12:27 pm
I got up this morning planning to do a few simple things, I have done many times before. I now have a CEL on, and both fans coming on, and idle is a bit rough. So I swapped out my temp sensor in the water pump with a known good one, then a brand new one. With no change. It all started when I replaced the coil. I have even went back and swapped the stock coil back in, replaced the MAF with a brand new one I had lying around, replaced the ICM with another known good one. I am starting to think the wire harness may be my culprit, as it has been repaired at some point, but I did take off the grounds at the stud that holds the coil on to the head. I did not have it twisted out of shape or anything, and I used dielectric grease every place that had a ground or current, cleaned all conections. I am at a loss. On the up side of things, It does seem to have more power when I put my foot in it a bit. Probably due to the MSD coil, and I found a fourth screw for my other opti. I had to pull both fan fuses out so I can get heat in the car.
Any ideas
PostSubject: Re: Oh boy CEL on and fans running. CTS replaced twice   Tue Dec 07, 2010 12:30 pm
Wireing harness repaired? Elaborate more? Definatly sounds broken wireish. Whats the CEL showing?
PostSubject: Re: Oh boy CEL on and fans running. CTS replaced twice   Tue Dec 07, 2010 12:39 pm
I have has a miss sound since I replaced the Exhaust. The wire harness looks as if it has been pulled apart and repaired at some point. Not sure why. I have no way of checking codes on a OBD1 sytem. My plan was to start at the easy stuff and replace the coil, and fuel filter. So in fixing the coil, I somehow damaged the wire harness, and I drove over my new fuel filter to take it for a drive to see if it was drivable. No I am so close to just cutting my losses and let the car go. This is exactly the bullshit I do not need. Out farting with a 15 year old piece of shit in 28 degree weather.
PostSubject: Re: Oh boy CEL on and fans running. CTS replaced twice   Tue Dec 07, 2010 1:06 pm
Ok, time to sit back and regroup. Shit happens. The wire harness is an easy fix, just replace it. I have a couple here from an old 9c1 i'll give you. But there is a simple explanation. Find someone that can check the CEL (Bill C? or how about VIP) That is where you need to start.
Did you get all the grounds on the coil? I change the one on the 96 (which was sold and he bailed on me, bastard) and i left one off, it wouldn't start untill i hooked it up. Did you get the coil wire back on right, did it pull out of the opti? Just throwing stuff out there.
PostSubject: Re: Oh boy CEL on and fans running. CTS replaced twice   Tue Dec 07, 2010 1:12 pm
Checked and rechecked. I have done this stuff in my sleep. I tried 3 coil wires. The ground pack was all together and never seperated, I checked that a couple times as well to make sure one of the grounds was not missing. I need to find someone local who can scan OBD1 and won't charge an arm and a leg to do it. All the parts stors including mine only scan OBD2. scratch
Bill
PostSubject: Re: Oh boy CEL on and fans running. CTS replaced twice   Tue Dec 07, 2010 1:15 pm
Bill
Yea that sucks, The matco guy just left i said find my an OBD1 scanner only will ya, he said ha good luck.
Isnt there another way to check codes, doesn't the light flash of some shit if you jump a490349304 to b203920392 , lol or something of that nature.
LandMaster
PostSubject: Re: Oh boy CEL on and fans running. CTS replaced twice   Tue Dec 07, 2010 4:22 pm
On my 94 I had a bad wire that split and frayed, it was the one that conected to the MAF, and my car did the exact same thing both fans stayed on and the CEL stayed on but didn't flash. I followed that wire and sliced a new section in and that solved the problem. Hope you find the culprit soon.
PostSubject: Re: Oh boy CEL on and fans running. CTS replaced twice   Wed Dec 08, 2010 8:42 am
Bill
At work last night I asked around to see if anyone had a obd1 reader, but no one had anything. I can get a reader for 30 bucks, but it does the code flash. I may just get one. It is better than not knowing.
PostSubject: Re: Oh boy CEL on and fans running. CTS replaced twice   Wed Dec 08, 2010 1:26 pm
Sounds like you need to untape that whole harness and follow each wire and see if you can find a fault...
Got a spare PCM you can try?
PostSubject: Re: Oh boy CEL on and fans running. CTS replaced twice   Wed Dec 08, 2010 4:33 pm
Update: Took the car to work today, and used the big machine. It can read all codes. Sat in my car and drove it around a bit with it hooked up. Found a broken MAF wire, and, and temp sensor wire. I had to pull the harness apart to find it. Also dicovered two drivers bank injectors were not firing correctly. Upon further inspection, I found both injectors rusted bad. More like rot. So I fixed the two wires, replaced all 8 injectors with known good ones that had low miles on them, along with the fuel rail, as the other one had a rotted crossover tube, found a broken vacume line from the intake to the egr control, and another from the wire harness to the intake. Fixed both of those. swapped out the ignition wires, and replaced the fuel filter.
Took it for a drive. It is about 95% better now. Still a slight spudder at low rpms, but nothing at idle, and nothing over 2500 or so. So hopefully some much needed programing will fix the rest, and get rid of the need for 93 octane.
Hope I did not come off too pissy before. I was mad. Evil or Very Mad
But I am much better now. Very Happy
PostSubject: Re: Oh boy CEL on and fans running. CTS replaced twice   Wed Dec 08, 2010 4:39 pm
Those big machines are the shit!!!!
PostSubject: Re: Oh boy CEL on and fans running. CTS replaced twice   Wed Dec 08, 2010 4:44 pm
It is basicly a military grade laptop with many connectors to choose from. Worked pissa. Gave me real time veiws of everything, and I checked the operation of everything too. Wink
PostSubject: Re: Oh boy CEL on and fans running. CTS replaced twice   Wed Dec 08, 2010 6:27 pm
Well yes you did,. and my feeling were hurt,.
and by better do you mean you are more,. or less,. pissy??
does pissy cause slight spudders?
nick
$1500 next time it screws up ,.
PostSubject: Re: Oh boy CEL on and fans running. CTS replaced twice   Wed Dec 08, 2010 6:35 pm
nick
You will get over it. LOL.
I am less pissy.
For 1500, I will part it out and chop up the rest in little pieces. I will never sell. I think...... Maybe. scratch
Actually I am about done with b-bodys. Now that it is my daily, I can not afford to break down. Who knows I may sell, not sure. The right offer, and it is gone. I think. I just don't care anymore about it.
PostSubject: Re: Oh boy CEL on and fans running. CTS replaced twice   Wed Dec 08, 2010 7:07 pm
For $1501 I'll save it from the sawzall. Spring can't get here fast enough. I want your car Laughing
PostSubject: Re: Oh boy CEL on and fans running. CTS replaced twice   Wed Dec 08, 2010 7:42 pm
You literally JUST said your next car will come from out west. this is the total opposite of that confused
PostSubject: Re: Oh boy CEL on and fans running. CTS replaced twice   Wed Dec 08, 2010 7:48 pm
Yeah, I know what I said, and that's my plan for the most part. But in this case since its a 1A2, plus one as rare as this, and there aren't many left period, i'd make an exception. Then again, with my luck it'll be long gone by the time I can actually afford it. Surprised
PostSubject: Re: Oh boy CEL on and fans running. CTS replaced twice   Wed Dec 08, 2010 7:55 pm
I will never sell it. Or will I? I get those two confused. Razz
PostSubject: Re: Oh boy CEL on and fans running. CTS replaced twice   Wed Dec 08, 2010 8:01 pm
Its ok. It happens. Just take some Geritol and it'll be all better Wink
PostSubject: Re: Oh boy CEL on and fans running. CTS replaced twice   Wed Dec 08, 2010 8:08 pm
It's a love/hate relationship. Luckily for it, that it is more love than hate.. I love you
PostSubject: Re: Oh boy CEL on and fans running. CTS replaced twice   Wed Dec 08, 2010 8:12 pm
I think there was a lot more hate when this thread started thou Laughing
PostSubject: Re: Oh boy CEL on and fans running. CTS replaced twice   Wed Dec 08, 2010 8:14 pm
Not hate. Anger. Evil or Very Mad
I probably should not have vented the way I did. Rolling Eyes
PostSubject: Re: Oh boy CEL on and fans running. CTS replaced twice   Thu Dec 09, 2010 12:00 pm
<snip>Found a broken MAF wire, and, and temp sensor wire. I had to pull the harness apart to find it. <snip>
You're welcome, by the way. Bitch.
LandMaster
PostSubject: Re: Oh boy CEL on and fans running. CTS replaced twice   Thu Dec 09, 2010 2:23 pm
^^^lol; I remember my 94 did the same kinda thing though. Atleast you found what it was.
PostSubject: Re: Oh boy CEL on and fans running. CTS replaced twice   Thu Dec 09, 2010 6:03 pm
^^^^ Yeah, Mark too! Smile
PostSubject: Re: Oh boy CEL on and fans running. CTS replaced twice   Thu Dec 09, 2010 6:34 pm
Actually, I do owe you a thank you..... Bitch. Wink
PostSubject: Re: Oh boy CEL on and fans running. CTS replaced twice   Thu Dec 09, 2010 8:05 pm
LOL. Smile
Sorry I posted that before my attitude adjustment in this thread. Please continue as though this never happened. Smile
