Wanted...LT1 Short Block EmptyWed Oct 19, 2022 1:27 pm by scot
Wanted...LT1 Short Block EmptyTue Oct 18, 2022 8:58 pm by silverfox103
Wanted...LT1 Short Block EmptyTue Sep 28, 2021 11:01 pm by silverfox103
Wanted...LT1 Short Block EmptyFri Sep 24, 2021 9:53 am by ElKy
Wanted...LT1 Short Block EmptySun Sep 19, 2021 6:22 pm by black blur 96
Wanted...LT1 Short Block EmptySun Jun 20, 2021 11:37 am by scot
Wanted...LT1 Short Block EmptyFri Jun 11, 2021 10:41 am by scot
Wanted...LT1 Short Block EmptyWed Jun 09, 2021 9:41 pm by Chris Klein
Wanted...LT1 Short Block EmptyWed Jun 02, 2021 9:02 pm by Chris Klein
3 posters
PostSubject: Wanted...LT1 Short Block   Wanted...LT1 Short Block EmptyTue Nov 23, 2010 7:24 pm
Looking for an LT1 short block for a project. Internals do NOT matter as long as the block has not been damaged. I just picked up a set of the 374 casting alumin heads, and I have some sbc internals I plan on using to make a nasty 368.
If you have one you want to let go...let me know!
PostSubject: Re: Wanted...LT1 Short Block   Wanted...LT1 Short Block EmptyTue Nov 23, 2010 8:20 pm
I don't know y you don't just pm me, how many do u want?
PostSubject: Re: Wanted...LT1 Short Block   Wanted...LT1 Short Block EmptyTue Nov 23, 2010 8:50 pm
I have a core from a camaro in pieces for inspection. I also have photos of some rust pitting damage that will have to be cleaned up in the over bore step & I have already power wire brushed all eight bores for measuring purposes. But remember that although these blocks often have reasonably good absence of "deal-breaking" core shift, the cylinder wall thickness, if longevity means anything to you, limits maximum power to just over 500 HP and ONLY if you can stay out of detonation. If you are racing these babies, use block-fill. Also, pouring that stuff is a little trickier than normal due to the reverse cooling. It's indoors & ready to be picked up. I paid $300 for it but I chose an RM motor that did not require an over bore. Take it away, its yours for the cost of your travels.
PostSubject: Re: Wanted...LT1 Short Block   Wanted...LT1 Short Block EmptyTue Nov 23, 2010 9:29 pm
Thanks man. Check your pm's just replied
» 94 Camaro LT1 short block - $200
» Free stock short block
» WANTED Front Wheel wells WANTED
» WTB: 97 or 98 Chevy/GMC Ext cab, short box, 4x4
» I know that this is short notice but...
