 Replacement Coolant Restrictors
JaySS
PostSubject: Replacement Coolant Restrictors    Sat Nov 20, 2010 1:42 pm
Probably most of us have experienced this, or at least know it happening:
http://badass-of-ne.forumotion.com/bad-talk-f5/good-morning-t2535.htm
I have replaced 2 that were about to break myself, and have seen 2 other broken ones firsthand.
Realizing that the coolant restrictors are becoming more fragile after this many years in service, T&M has been quietly moving towards production on a billet aluminum replacement.
They are machined out of solid bar stock with a hose barb at each end, and anodized black for protection & appearance. A fixed orifice to duplicate the intent of the design replaces the internal valve assembly and eliminates the moving parts.
Pricing hasn't been determined yet, but they will be reasonable alternative when compared to the GM replacements that are currently running about $22.00.
No pics yet, but I'll see if I can get some from them.
If you want one right away, just contact T&M through the info posed on F2Bkit.com.
- J
PostSubject: Re: Replacement Coolant Restrictors    Sat Nov 20, 2010 1:44 pm
The hose that runs from the "T" to the tank is available at NAPA.
Tom C.
PostSubject: Re: Replacement Coolant Restrictors    Sat Nov 20, 2010 2:00 pm
This is the part that just let go on my car guys.. I will be ordering one of these in the near future..
PostSubject: Re: Replacement Coolant Restrictors    Mon Nov 29, 2010 1:08 am
- J
I just found this reply & want to say thanks for the info. So this little piece of plactic restricts coolant flow, but my 96 car does not have one and neither did my 95 parts car. Is there a difference in the performance or reliability of the cooling system if I fail to install one, or are they not normally factory equipped on 9C1s?
