| Fuel pressure guage mod | |
| Subject: Fuel pressure guage mod Fri Nov 12, 2010 10:55 am | |
| I saw on like Marks car, and someone elses car, they have a fuel guage attached to the back of the intake. What is this? It wasn't attached to the schrader, Ross sleeps all day, so he is hard to reach. | |
| Subject: Re: Fuel pressure guage mod Fri Nov 12, 2010 11:03 am | |
| are you sure it wasn't attached to the schrader valve
| Subject: Re: Fuel pressure guage mod Fri Nov 12, 2010 11:08 am | |
| I looked like it was on the drivers side. Shrader is low and more towards Middle. I'll call Ross later when he gets up | |
| Subject: Re: Fuel pressure guage mod Fri Nov 12, 2010 11:12 am | |
| you could drill and tap the fuel rail if you want | |
| Subject: Re: Fuel pressure guage mod Fri Nov 12, 2010 11:29 am | |
| - mean ss wrote:
- are you sure it wasn't attached to the schrader valve
That may have been exactly it. And im not drilling a hole in any fuel line, I'd screw that up | |
| Subject: Re: Fuel pressure guage mod Fri Nov 12, 2010 12:01 pm | |
| Maybe this is it. Ron's old car. |
| Subject: Re: Fuel pressure guage mod Fri Nov 12, 2010 12:06 pm | |
| Yes looks to be the same. | |
| Subject: Re: Fuel pressure guage mod Fri Nov 12, 2010 3:12 pm | |
| I have some parts to do that, I'll take a look asap & let you know It has to be the schrader | |
| Subject: Re: Fuel pressure guage mod Fri Nov 12, 2010 3:18 pm | |
- I have some parts to do that, I'll take a look asap & let you know
It has to be the schrader sweet. I tried to find one locally. Nothing. | |
justinlamb82
Posts : 85 Join date : 2010-03-25 Age : 41 Location : Berlin MA
| Subject: Re: Fuel pressure guage mod Fri Nov 12, 2010 3:42 pm | |
| Pretty sure thats what I have. I remember the little fitting Who knows what the fluid is in that gauge? | |
| Subject: Re: Fuel pressure guage mod Fri Nov 12, 2010 3:45 pm | |
- Pretty sure thats what I have.
I remember the little fitting Who knows what the fluid is in that gauge? Probably vegtable oil or some canola oil. Thanks for the link justinlamb82 | |
justinlamb82
| Subject: Re: Fuel pressure guage mod Fri Nov 12, 2010 5:43 pm | |
I remember the little fitting Who knows what the fluid is in that gauge? The fluid inside the gauge is usually glycerin or silicone fluid which helps cushion the internals of the gauge from vibrations or an impact | |
| Subject: Re: Fuel pressure guage mod Fri Nov 12, 2010 5:50 pm | |
| - justinlamb82 wrote:
- sdstick wrote:
- ....Who knows what the fluid is in that gauge?
The fluid inside the gauge is usually glycerin or silicone fluid which helps cushion the internals of the gauge from vibrations or an impact Thank you. | |
| Subject: Re: Fuel pressure guage mod | |
