» C10: Before and After
New Wheels! EmptySun Jun 02, 2019 3:01 pm by MalibuSSwagon
New Wheels! EmptySat Mar 16, 2019 8:49 am by boojum
» Mass refugee now in Pa
New Wheels! EmptyTue Jan 22, 2019 8:46 am by MASShole9C1
New Wheels! EmptyTue Jan 22, 2019 12:03 am by boojum
» 1996 DGM RMW
New Wheels! EmptyFri Jan 18, 2019 12:00 pm by Gorillabiter
New Wheels! EmptyWed Oct 31, 2018 7:53 pm by Ironfistdog
» Roundup pics?
New Wheels! EmptyTue Oct 23, 2018 12:41 pm by silverfox103
New Wheels! EmptyThu Oct 18, 2018 7:51 pm by silverfox103
» Looking for exhaust part
New Wheels! EmptyTue Oct 16, 2018 12:37 pm by fatvet
June 2019
3456789
10111213141516
17181920212223
24252627282930
Share
 New Wheels!
New Wheels! Empty
PostSubject: New Wheels!   New Wheels! EmptySat Nov 13, 2010 3:50 pm
I picked up a set of front Weld Draglites in a partial trade this past week. They are 15x6 and have brand new 195/65 tires on them. I was going to buy this size anyways, because I feel that the "skinnies" (15x3/ 15x4) are just too thin for these big cars. I just rolled them in front of my wheels to get an idea of how they would look...
New Wheels! Springfield-20101113-00067
I think there going to look really nice with the chrome bumpers/ stainless door trim.
Does anyone know what backspace you need to run in the rear for a 15x10?
Also...does anyone know of any manufacturer that makes the long shank lug nuts in black (satin or gloss)?
New Wheels! Empty
PostSubject: Re: New Wheels!   New Wheels! EmptyTue Nov 16, 2010 1:54 pm
Wow, I dont know how i missed this lol.
I like how those wheels look but I wouldn't be comfortable with too skinny of a tire up front. Did you get two or four?
New Wheels! Empty
PostSubject: Re: New Wheels!   New Wheels! EmptyTue Nov 16, 2010 5:24 pm
I only got front runners for now. They may end up going bye-bye...
Some big changes have just come up with the direction im taking the car....
New Wheels! Empty
PostSubject: Re: New Wheels!   New Wheels! EmptyTue Nov 16, 2010 5:27 pm
Please tell me its a low rider!? LOL
New Wheels! Empty
PostSubject: Re: New Wheels!   New Wheels! EmptyTue Nov 16, 2010 7:39 pm
EEWWWWWWWW!
...Unless it gets the same ET as a lowrider with panel paint and everything Arrow
What are the REAL plans?
New Wheels! Empty
PostSubject: Re: New Wheels!   New Wheels! EmptyWed Nov 17, 2010 10:41 pm
www.x275.net
looking to shave a little off the ET for 2011 Smile
New Wheels! Empty
PostSubject: Re: New Wheels!   New Wheels! EmptyThu Nov 18, 2010 12:03 pm
bfurches wrote:
www.x275.net
Very Happy So are you keeping the small block or are you doing the LS build up? Whats goin under the hood?? Question
New Wheels! Empty
PostSubject: Re: New Wheels!   New Wheels! EmptyThu Nov 18, 2010 7:30 pm
New Wheels! Springfield-20101117-00106-1
...this for one...
New Wheels! Empty
PostSubject: Re: New Wheels!   New Wheels! EmptyThu Nov 18, 2010 7:36 pm
...this for one...
Is that a Garrett T6? Wink Billy likey! Arrow
New Wheels! Empty
I like where this is going
New Wheels! Quagmire
New Wheels! Empty
PostSubject: Re: New Wheels!   New Wheels! EmptyThu Nov 18, 2010 8:03 pm
GIGGIDY! GIGGIDY! GIGGIDY!................Awwwll Riiiight! Razz
I had Weld Draglites on my pinto 15x4 up front, and 15x10 out back. I would love to find a set of those for the wagon in 5x5 bolt pattern.
Looked almost like this one except the flames
https://www.youtube.com/watch?v=mUpi5oU-wmA&feature=related
New Wheels! Empty
PostSubject: Re: New Wheels!   New Wheels! EmptyThu Nov 18, 2010 8:04 pm
lol, yes Garrett t6 custom TV series with an 80mm wheel Smile
Good for 1200-1300hp
New Wheels! Empty
PostSubject: Re: New Wheels!   New Wheels! EmptySat Nov 20, 2010 8:48 am
In my 88 I installed true three piece centerline model"X" wheels that measure 16 x 11 by themselves, and 12"overall with 295/60-16 tires mounted on them. I rolled the wheel lip all the way up to be even with the bulge inside the wheel house just above the inner lip. This saves the side wall from the "rolling knife action" we have all seen. I welded up the 9" ford 1" narrower on each side & the wheel back space is 6.750" with a .3125" brake rotor hat (x2) added in. It is very easy to check on your own car, just measure the axle from drum to drum (with two tight lug nuts) on the car with the rear wheels off, one person on each side with a straight edge pressed tight & hanging straight down and use a tape measure. Then drag a plumb bob across the inner wheel house over the frame axle hump while scribing the floor to get the maximum inner width of the car that a tire would have to clear inboard. Then subtract the lesser chassis width from the larger drum to drum width and then divide that result by 1/2, (this is the back space that you will see "per wheel" with the tire mounted because it MUST include the bulge of the tire). You also MUST KNOW the ACTUAL width of the tire mounted on the rim. You then have to give a little clearance for the tire inside due to the deflection of the rear upper and lower control arm bushings that will allow the rear axle to shift side to side. Also remember that the top of the tire "tips in" at it's top when the opposite tire is in full droop. This would certainly be a good time to verify that the rear is centered in the car, because if it is not, you should correct that first. My tire to wheel housing clearance is less than 3/8", it NEVER even rubs, and I drive very hard. I do not know who makes black chrome nuts, but I would still recommend McGard even if you can't get the finish you desire.
New Wheels! Empty
PostSubject: Re: New Wheels!   New Wheels! EmptySat Nov 20, 2010 9:54 am
Welcome!
New Wheels! Empty
PostSubject: Re: New Wheels!   New Wheels! EmptySat Nov 20, 2010 4:57 pm
^ yes also welcome.
You brought up some great tricks for those who have never measured back space before...good valuable info.
Your car sounds interesting. Do you have any photos or details on it?
New Wheels! Empty
New Wheels!
» polished ss wheels?
» Wanted: centers for Roadmaster wheels / front turn signal lens
» 1995 buick roadmaster $10,000
» possibily pickin up my newest mod 2day...
» FS: 1996 Cadillac Fleetwood Brougham $1,800.00
