 Not a big milestone, but still a milestone.
PostSubject: Not a big milestone, but still a milestone.   Thu Nov 04, 2010 7:53 pm
I will just have to wait til the morning to see it. Razz
PostSubject: Re: Not a big milestone, but still a milestone.   Thu Nov 04, 2010 8:33 pm
Cake and Ice Cream at Bill's house.
PostSubject: Re: Not a big milestone, but still a milestone.   Thu Nov 04, 2010 8:38 pm
What milestone? That you're about to run out of gas? Wink
PostSubject: Re: Not a big milestone, but still a milestone.   Thu Nov 04, 2010 8:39 pm
You guys supply the cake and ice cream, and I will supply the house. Razz
No. My "LOW FUEL" light comes on at the empty mark, and I have another 20 or so miles. Unlike those 94 fleetwoods. pale
PostSubject: Re: Not a big milestone, but still a milestone.   Thu Nov 04, 2010 9:49 pm
Think you'll remember in the AM?
Whenever I try to do that I always forget
PostSubject: Re: Not a big milestone, but still a milestone.   Thu Nov 04, 2010 9:51 pm
Why do you think I made a big deal tonight about it. Wink
PostSubject: Re: Not a big milestone, but still a milestone.   Thu Nov 04, 2010 11:18 pm
No. My "LOW FUEL" light comes on at the empty mark, and I have another 20 or so miles. Unlike those 94 fleetwoods. pale [/quote]
daredevil! I've never ran any of my B's below 1/4 tank, which I blame strictly on my Fleetwood experience. That sucker ran out at 2 bars, sometimes 3 if I was beating on it.. Now I just play it safe.. I only hope that with my next fleetwood, i'll be able to experience the low fuel light AND chime!!
PostSubject: Re: Not a big milestone, but still a milestone.   Fri Nov 05, 2010 1:05 am
It looks like a 149,999 milestone to me!
PostSubject: Re: Not a big milestone, but still a milestone.   Fri Nov 05, 2010 5:52 am
Is the 309.7 accurate?
Thats how I know its time to fill up
20gal*15mi/gal=300mi
I hear SO many people get better mileage.
Not me, every now & then I see 16 mi/gal
PostSubject: Re: Not a big milestone, but still a milestone.   Fri Nov 05, 2010 8:54 am
I am seeing between 330-350 miles on a tank.
It is accurate. I reset at fill up.
PostSubject: Re: Not a big milestone, but still a milestone.   Fri Nov 05, 2010 9:14 am
I dont know why I dont see better mileage out of my cars
I didnt think I drove THAT hard. scratch
Whats a wagon weigh anyway?
PostSubject: Re: Not a big milestone, but still a milestone.   Fri Nov 05, 2010 9:19 am
It is 4680lbs with me in it, so 4510lbs. I do not drive it easy either.
PostSubject: Re: Not a big milestone, but still a milestone.   Fri Nov 05, 2010 9:44 am
FWIW I average anywhere from 15-17 mpg in the city (17 is sticker mpg) and from 23-26 on the highway (24 is sticker)
What gears do you run, I thought that had something to do with it. I had a friend with 2.92's and it got better miles than my car with 3.23's
PostSubject: Re: Not a big milestone, but still a milestone.   Fri Nov 05, 2010 11:48 am
It is 4680lbs with me in it, so 4510lbs......
Interesting, I thought they'd be heavier
....I hear SO many people get better mileage.
In my case gears dont matter, I run 3.08's, 3.42's & 3.73's. I think the main factor is I dont do alot of open highway driving
PostSubject: Re: Not a big milestone, but still a milestone.   Fri Nov 05, 2010 2:12 pm
I average usually from 19 to 23 MPG spread out over a tank of gas. The last one I got 23 on, I had taken a trip from Malden to Rochester NH and back right after the fill up, then drove mostly around town for the rest of the tank, I thought that was pretty good. I must have been pushing 27-28 on that NH trip! Highway gears aren't always all bad... Very Happy
PostSubject: Re: Not a big milestone, but still a milestone.   Fri Nov 05, 2010 5:11 pm
I usually fill up right at 300 miles, and it takes anywhere from 16-18 gallons, which works out to be 16-18mpg. Mostly country road driving, and spirited at that. Smile
So far, the caddy has about 220 miles on this tank and still showing more than half full. I don't believe it for a second...
PostSubject: Re: Not a big milestone, but still a milestone.   Fri Nov 05, 2010 7:24 pm
There! I remembered. Wink
PostSubject: Re: Not a big milestone, but still a milestone.   Fri Nov 05, 2010 9:25 pm
I'm impressed cheers
PostSubject: Re: Not a big milestone, but still a milestone.   Sat Nov 06, 2010 11:29 am
LiveFreeorDieTryin
PostSubject: Re: Not a big milestone, but still a milestone.   Sat Nov 06, 2010 11:34 am
meh...
PostSubject: Re: Not a big milestone, but still a milestone.   Sun Nov 07, 2010 6:26 pm
I know with b& d bodys, the chance of ever seeing the low fuel light is damn near impossible. I bet some of you don't know it has a low fuel light. scratch It does.
I put 18 gallons in and it went to 3/4 from E, about where it should. which is where I keep it since there is a leak on top of the tank. so I get about 20 mpg all around driving.
LandMaster
PostSubject: Re: Not a big milestone, but still a milestone.   Tue Nov 09, 2010 10:12 am
My low fuel light came once. Haven't seen it since and I've run loooww.
Depending on how I drive, I get about 16-17 average, but come back from wagon fest I went about 480 ish on that one tank, that was all mountain driving though. Usually though 320-350 for a tank for me.
PostSubject: Re: Not a big milestone, but still a milestone.   Sun Nov 21, 2010 6:16 pm
All this talk about odometers has just reminded me of an annoying, occasional & intermittent glitch on my odometer. Its a 1996 9C1 with the "certifried" speedo, which is always very accurate on MPH as long as i have the correct rolling tire diameter. BUT,,, The odometer sometimes flickers between the correct milage & some much higher number, however, it never stays on long enough for me to trouble shoot. I will also need to get some one to sit in the driver's seat to observe what the dash odometer does while I giggle harnesses. BTW, This higher number IS NOT the kilometer number as I first suspected. Can any one remember having this problem? Also, even though the odometer's full vehicle miles total "flickers", the trip milage number does not!
PostSubject: Re: Not a big milestone, but still a milestone.   Sun Nov 21, 2010 6:59 pm
This is a very common issue. So common, every b-body I have had with that cluster did it.
Here is your fix. http://capricess.com/tech/cluster/fading_cluster/fix.htm
PostSubject: Re: Not a big milestone, but still a milestone.   Sun Nov 21, 2010 7:47 pm
Hail yeah! I just checked out the link you suggested and see that this is absolutely the first thing for me to check over. I will be astonished if it does not solve this odometer issue conclusively. This is exactly the kind of result that I had hoped for when joining this group. Thanks a million!
PostSubject: Re: Not a big milestone, but still a milestone.   Sun Nov 21, 2010 8:06 pm
Check out the links section. Most of the answeres to all questions can be found there.
PostSubject: Re: Not a big milestone, but still a milestone.   Sun Nov 21, 2010 11:09 pm
I checked out this site a long time ago but must have forgotten to look at it recently. I searched in my mac finder & saw that I had bookmarked it ages ago.
» Biddy & Diana Rose - Milestone House Pottery
» Personal milestone
