 Wtf Oil Leaking!!!!!!!!
PostSubject: Wtf Oil Leaking!!!!!!!!   Tue Mar 24, 2009 11:47 am
Found out it could be my rear main seal anyone know someone that does transmissions?
but ima double check the oi pan gasker amd the intake manifold
PostSubject: Re: Wtf Oil Leaking!!!!!!!!   Tue Mar 24, 2009 3:25 pm
Anyone????
UberWagon
PostSubject: Re: Wtf Oil Leaking!!!!!!!!   Tue Mar 24, 2009 4:08 pm
Well the rear main leak is a typical small block chevy thing, if it isn't a massive pressurized leak I wouldn't sweat it that much. Just look at is a way to mark your territory Very Happy .
PostSubject: Re: Wtf Oil Leaking!!!!!!!!   Tue Mar 24, 2009 4:17 pm
u sure i shudnt sweat it... it drips constant but my oil level is fine but the my change oil light is on
scratch scratch scratch scratch
PostSubject: Re: Wtf Oil Leaking!!!!!!!!   Tue Mar 24, 2009 5:04 pm
The change oil light is based off pcm calculations. There's a way to reset it after every oil change but I don't remember off the top of my head.
I had a fullsize blazer with a bad rear seal and it was never an issue. If it bothers you just don't crawl under the car and look at it Wink
PostSubject: Re: Wtf Oil Leaking!!!!!!!!   Tue Mar 24, 2009 5:25 pm
If it is dripping like that it's probably something else. To reset change oil light turn key to "on" position pump gas pedal about 4 times. That's about it.
» Transmission lines
» Head Gasket Issues RR, RRC, D1 & D2
» How to seal steam pipes
» The Lord of Youkai no Jigen
» Fuel line splicing?
