| Stumble help. | |
| Subject: Stumble help. Sat Oct 23, 2010 8:32 pm | |
| The 9c1 has a small issue. When you give it throttle, it will stumble and then clear out and go. This is just a slight stumble, but still a stumble. I know the opti is good. Pretty sure the wires are. I left the plugs in. Any Ideas? |
| Subject: Re: Stumble help. Sat Oct 23, 2010 8:46 pm | |
| With the TPS being a potentiometer, it can get dead spots. It may be stumbling at a spot it consistantly rides at. Check its resistance with OEM specs | |
| Subject: Re: Stumble help. Sat Oct 23, 2010 8:51 pm | |
| It only does it in gear driving. In park, it revs fine. I probably know the answer, but my head is so full crap, I can't think. |
| Subject: Re: Stumble help. Sat Oct 23, 2010 8:59 pm | |
| Light throttle? EGR?
Regular throttle? TPS? IAC reset? TBS cleaning? Plugs? Vacuum leaks?
| Subject: Re: Stumble help. Sat Oct 23, 2010 9:03 pm | |
- Light throttle? EGR?
yes | |
| Subject: Re: Stumble help. Sat Oct 23, 2010 9:05 pm | |
yes BINGO! Thanks guys. |
| Subject: Re: Stumble help. Sat Oct 23, 2010 9:41 pm | |
- IAC reset?
Is this something I can do? What is involved? |
| Subject: Re: Stumble help. Sat Oct 23, 2010 9:45 pm | |
| Im guessing you need a scan tool
http://www.gnttype.org/techarea/faq/IACresetscan.html | |
| Subject: Re: Stumble help. Sat Oct 23, 2010 9:46 pm | |
- IAC reset?
Is this something I can do? What is involved? http://shbox.com/1/4th_gen_tech2.html#iac_reset Depress accelerator slightly Start engine, then release accelerator pedal, run engine for 5 seconds Turn ignition "OFF" for ten seconds Restart engine and check for proper idle operation | |
| Subject: Re: Stumble help. Sat Oct 23, 2010 9:58 pm | |
| Subject: Re: Stumble help. Sat Oct 23, 2010 10:13 pm | |
| I figured as much. I took a quick glance, posted, then found what you posted | |
| Subject: Re: Stumble help. Wed Oct 27, 2010 3:07 pm | |
| Ok I found the IAC valve was no good. I replaced it with another one I got from crovo, along with completely rebuilding the TB out of spare parts. Now she runs like a champ. |
| Subject: Re: Stumble help. Mon Nov 01, 2010 9:57 pm | |
- Ok
I found the IAC valve was no good. I replaced it with another one I got from crovo, along with completely rebuilding the TB out of spare parts. Now she runs like a champ. I was wrong. Wound up being the EGR after further diag. |
| Subject: Re: Stumble help. | |
| Stumble help. | |
