» C10: Before and After
Stumble help. EmptySun Jun 02, 2019 3:01 pm by MalibuSSwagon
Stumble help. EmptySat Mar 16, 2019 8:49 am by boojum
» Mass refugee now in Pa
Stumble help. EmptyTue Jan 22, 2019 8:46 am by MASShole9C1
Stumble help. EmptyTue Jan 22, 2019 12:03 am by boojum
» 1996 DGM RMW
Stumble help. EmptyFri Jan 18, 2019 12:00 pm by Gorillabiter
Stumble help. EmptyWed Oct 31, 2018 7:53 pm by Ironfistdog
» Roundup pics?
Stumble help. EmptyTue Oct 23, 2018 12:41 pm by silverfox103
Stumble help. EmptyThu Oct 18, 2018 7:51 pm by silverfox103
» Looking for exhaust part
Stumble help. EmptyTue Oct 16, 2018 12:37 pm by fatvet
June 2019
3456789
10111213141516
17181920212223
24252627282930
Share
 Stumble help.
Stumble help. Empty
PostSubject: Stumble help.   Stumble help. EmptySat Oct 23, 2010 8:32 pm
The 9c1 has a small issue. When you give it throttle, it will stumble and then clear out and go. This is just a slight stumble, but still a stumble. I know the opti is good. Pretty sure the wires are. I left the plugs in. Any Ideas?
Stumble help. Empty
PostSubject: Re: Stumble help.   Stumble help. EmptySat Oct 23, 2010 8:46 pm
With the TPS being a potentiometer, it can get dead spots. It may be stumbling at a spot it consistantly rides at. Check its resistance with OEM specs
Stumble help. Empty
PostSubject: Re: Stumble help.   Stumble help. EmptySat Oct 23, 2010 8:51 pm
It only does it in gear driving. In park, it revs fine. I probably know the answer, but my head is so full crap, I can't think.
Stumble help. Empty
PostSubject: Re: Stumble help.   Stumble help. EmptySat Oct 23, 2010 8:59 pm
Light throttle? EGR?
Regular throttle? TPS? IAC reset? TBS cleaning? Plugs? Vacuum leaks?
Stumble help. ToastedSig_zps6c195980
Stumble help. Empty
PostSubject: Re: Stumble help.   Stumble help. EmptySat Oct 23, 2010 9:03 pm
yes
Stumble help. Empty
PostSubject: Re: Stumble help.   Stumble help. EmptySat Oct 23, 2010 9:05 pm
yes
BINGO! Thanks guys. Wink
Stumble help. Empty
PostSubject: Re: Stumble help.   Stumble help. EmptySat Oct 23, 2010 9:30 pm
yes
Basketball all in a days work
Stumble help. Empty
PostSubject: Re: Stumble help.   Stumble help. EmptySat Oct 23, 2010 9:41 pm
IAC reset?
scratch Is this something I can do? What is involved?
Stumble help. Empty
PostSubject: Re: Stumble help.   Stumble help. EmptySat Oct 23, 2010 9:45 pm
Stumble help. Empty
PostSubject: Re: Stumble help.   Stumble help. EmptySat Oct 23, 2010 9:46 pm
IAC reset?
http://shbox.com/1/4th_gen_tech2.html#iac_reset
Depress accelerator slightly
Start engine, then release accelerator pedal, run engine for 5 seconds
Turn ignition "OFF" for ten seconds
Restart engine and check for proper idle operation
Stumble help. Empty
PostSubject: Re: Stumble help.   Stumble help. EmptySat Oct 23, 2010 9:49 pm
IAC reset?
I don't remember, but I know it's quick and easy. Normally that's for an idle issue anyways, but figured that it could be something worth checking if plugs and a TB service didn't clear it up... Wink
EDIT: See, I walk away for a couple minutes before I hit send and someone figured it out already... Very Happy
Stumble help. Empty
PostSubject: Re: Stumble help.   Stumble help. EmptySat Oct 23, 2010 9:51 pm
mean ss wrote:
IAC reset?
LOL i just got done reading that study ...im dumb Question
Stumble help. Empty
PostSubject: Re: Stumble help.   Stumble help. EmptySat Oct 23, 2010 9:58 pm
mean ss wrote:
IAC reset?
what you had posted is more for adj. the throttle blades by IAC counts but we want them in the 30's
Stumble help. Empty
PostSubject: Re: Stumble help.   Stumble help. EmptySat Oct 23, 2010 10:13 pm
I figured as much. I took a quick glance, posted, then found what you posted
Stumble help. Empty
PostSubject: Re: Stumble help.   Stumble help. EmptyWed Oct 27, 2010 3:07 pm
Ok
I found the IAC valve was no good. I replaced it with another one I got from crovo, along with completely rebuilding the TB out of spare parts. Now she runs like a champ. cheers
Stumble help. Empty
PostSubject: Re: Stumble help.   Stumble help. EmptyMon Nov 01, 2010 9:57 pm
Ok
I was wrong. Wound up being the EGR after further diag.
Stumble help. Empty
Stumble help.
