 Rhino line the trunk???
PostSubject: Rhino line the trunk???   Sun Oct 10, 2010 7:44 pm
My 9C1 has no carpet in the trunk, and I'm tired of hearing things slide around back there. Do any of you guys have experience with that spray on bedliner? Let me know, unless some one has a trunk kit thats no trashed...
PostSubject: Re: Rhino line the trunk???   Mon Oct 11, 2010 1:24 am
Richardson's Garage in North Reading does rhinos, my dad worked there for a bit but he hasn't seen the owner in ages. They do good work there though if you're interested. It can be pricey though.
PostSubject: Re: Rhino line the trunk???   Mon Oct 11, 2010 1:37 am
You are better off finding a Caprice in a junkyard with all the trunk carpet. I wouldn't want that rhino spray crap all over the inside of my trunk. Or, just take the crap rolling around in your trunk out. That's how you get outward dents in your rear quarters
PostSubject: Re: Rhino line the trunk???   Mon Oct 11, 2010 1:52 pm
I'm thinking of doing the same thing on my car. I have to patch a hole first but it'd be nice to line it on the inside as well as paint the outside to prevent future holes.
PostSubject: Re: Rhino line the trunk???   Mon Oct 11, 2010 4:52 pm
Not a bad idea, but I'd see if anyone's done it before. I'd still say just get a rubber floor mat and carpet set out of another Caprice to put back there, and make sure you have stuff on each side to prevent things from denting out the quarters.
PostSubject: Re: Rhino line the trunk???   Fri Oct 15, 2010 3:05 am
I built plywood sides to protect the guarters from dents .
Covered with grey carpet they look decent.
Only takes 3 screws to mount.
I have a spare one left over that you can use for a template for the other side.
I'll throw it in the trunk for the roundup.
Be sure and remind me,
PostSubject: Re: Rhino line the trunk???   Fri Oct 15, 2010 3:30 am
» Newbie question about upgrading a PAS 3 line amplifer only.
» Off the line stumble
» Trunk lock relocation / Shaved trunk lid
» (2) oem impala SS trunk lock emblems
» Inexpensive Line Voltage changer
