Lets talk hood supports EmptyWed Oct 19, 2022 1:27 pm by scot
Lets talk hood supports EmptyTue Oct 18, 2022 8:58 pm by silverfox103
Lets talk hood supports EmptyTue Sep 28, 2021 11:01 pm by silverfox103
Lets talk hood supports EmptyFri Sep 24, 2021 9:53 am by ElKy
Lets talk hood supports EmptySun Sep 19, 2021 6:22 pm by black blur 96
Lets talk hood supports EmptySun Jun 20, 2021 11:37 am by scot
Lets talk hood supports EmptyFri Jun 11, 2021 10:41 am by scot
Lets talk hood supports EmptyWed Jun 09, 2021 9:41 pm by Chris Klein
Lets talk hood supports EmptyWed Jun 02, 2021 9:02 pm by Chris Klein
4 posters
PostSubject: Lets talk hood supports   Lets talk hood supports EmptyThu Sep 30, 2010 6:49 pm
I had purchased a set of almost new F-body hood supports with the unserstanding that they are what I need with a fiberglass hood. What I hid not know is that they do not work with all fiberglass hoods, and mine is one they do not hold up.
Deputy347K9
PostSubject: Re: Lets talk hood supports   Lets talk hood supports EmptyFri Oct 01, 2010 9:00 am
Over the years I have purchased three hoods from SunCoast out of Florida. I would have to say the very best hood I have seen. I also tried the F body struts and they would not hold the hood up. I am using the stock B body struts that work great and have had no problems what so ever. The SunCoast hood is nearly the same weight as the factory hood and I believe it's stronger, I found that out the hard way.
PostSubject: Re: Lets talk hood supports   Lets talk hood supports EmptyFri Oct 01, 2010 11:22 am
I am currently using one B-body support, but when I use two, the hood bows in the middle on both sides. The one I have is kinda week anyways. I am afraid of stress cracks and failure with just one or both. One because nothing is supporting the other side, and both because it causes the hood to bow. I figure a set of old week B-body supports would do the trick. scratch
EDIT: Found it right here at the bottom of the page. Thanks Larry
http://suncoastramairhoods.com/info-faqs-cat.html
PostSubject: Re: Lets talk hood supports   Lets talk hood supports EmptyFri Oct 01, 2010 2:03 pm
I used F-Body struts. They did hold up the hood.... Unless there was wind, or snow or ice on the hood.
I then switched to B-Body struts and they worked just fine. Didn't notice any real bowing....
PostSubject: Re: Lets talk hood supports   Lets talk hood supports EmptyFri Oct 01, 2010 2:08 pm
I'd let you try mine but they attatch differently, plus they're bowing a steel hood so I doubt they'd be good on a fiberglass one. I'll check and see if I still have the old ones, but there's still the issue of the mounting points being different.
PostSubject: Re: Lets talk hood supports   Lets talk hood supports EmptyFri Oct 01, 2010 8:47 pm
if ur worried about only haing one side and dont want to run 2 dew to bowing. just run one in the middle. Laughing Laughing
PostSubject: Re: Lets talk hood supports   Lets talk hood supports EmptyFri Oct 01, 2010 8:49 pm
I looked at that option, but there is no good spot to install it on the hood side.
PostSubject: Re: Lets talk hood supports   Lets talk hood supports EmptyFri Oct 01, 2010 8:55 pm
it sounds stupid but it proboly would look cool and u have the room with the motor being so low
PostSubject: Re: Lets talk hood supports   Lets talk hood supports EmptyFri Oct 01, 2010 8:58 pm
No, it does not sound stupid. I looked at that option, but the fiberglass is not thick enough in that area to accept it without modification. It is really a cool idea.
PostSubject: Re: Lets talk hood supports   Lets talk hood supports EmptyFri Oct 01, 2010 9:01 pm
ya u would have 2 brace it some how. u could always just sell the hood to me! Very Happy
PostSubject: Re: Lets talk hood supports   Lets talk hood supports EmptyFri Oct 01, 2010 9:04 pm
Run an old style prop-rod off the front. Most of the cars I've owned had one and it always works great. Easier to navigate then the hood struts when doing a tune-up too.
» Lets talk Mufflers
» Lets talk Turbo
» Lets talk cams
» Lets Talk Headers... One More Time
» F/S or Trade: A pair of F-body and a pair of B-body hood lift supports
