Exhaust manifold bolt fix EmptyWed Oct 19, 2022 1:27 pm by scot
Exhaust manifold bolt fix EmptyTue Oct 18, 2022 8:58 pm by silverfox103
Exhaust manifold bolt fix EmptyTue Sep 28, 2021 11:01 pm by silverfox103
Exhaust manifold bolt fix EmptyFri Sep 24, 2021 9:53 am by ElKy
Exhaust manifold bolt fix EmptySun Sep 19, 2021 6:22 pm by black blur 96
Exhaust manifold bolt fix EmptySun Jun 20, 2021 11:37 am by scot
Exhaust manifold bolt fix EmptyFri Jun 11, 2021 10:41 am by scot
Exhaust manifold bolt fix EmptyWed Jun 09, 2021 9:41 pm by Chris Klein
Exhaust manifold bolt fix EmptyWed Jun 02, 2021 9:02 pm by Chris Klein
4 posters
PostSubject: Exhaust manifold bolt fix   Exhaust manifold bolt fix EmptyMon Jan 26, 2009 5:50 am
Has anyone tried to weld a washer to what is left of a broken exhaust manifold bolt? Does not seem to difficult.
I am going to give it a try come spring to see if I can get one out on the rear pass side.
PostSubject: Re: Exhaust manifold bolt fix   Exhaust manifold bolt fix EmptyMon Jan 26, 2009 8:21 am
Try welding a nut instead. That way you can put a wrench on it. Jim's actually gotten pretty good at it!
PostSubject: Re: Exhaust manifold bolt fix   Exhaust manifold bolt fix EmptyMon Jan 26, 2009 1:53 pm
Try a pair of vice grips first. I pulled the exhaust manifold on one car to replace the rear stud only to find it came out easy. On the ohter hand all the other bolts broke. AS Bill said weld a nut on the stud. You can put a large washer behind the nut to avoid getting any splatter on the head. If you take apart an old hard drive from a PC you can get some nice super stong magnets. I use 'em to hold the nut in place.
PostSubject: Re: Exhaust manifold bolt fix   Exhaust manifold bolt fix EmptyMon Jan 26, 2009 4:54 pm
Great idea Jim
UberWagon
PostSubject: Re: Exhaust manifold bolt fix   Exhaust manifold bolt fix EmptyThu Feb 19, 2009 4:10 am
My method is a reverse drill bit and heat, if the bolt is broken flush. If there is a "stud" heat, and vice grips have always worked. Of course the only time I have had to do this is with my engine out or on with the head off.
PostSubject: Re: Exhaust manifold bolt fix   Exhaust manifold bolt fix EmptyWed Apr 01, 2009 9:31 pm
That's how we got both side rear bolts out of my grey 9c1. Worked quite well.
» Broken Manifold Bolt - Don't Try This At Home!
» exhaust manifold heat sheld
» WANTED DR side Exhaust manifold
» Passenger Side Exhaust manifold needed
» INTAKE MANIFOLD GASKET
