Yesterday at 9:35 pm by silverfox103
 Radiator emissions stickers?
PostSubject: Radiator emissions stickers?   Thu Sep 09, 2010 11:56 pm
I'm not digging my 4.3 emissions sticker. Are there any 5.7 stickers available? Would it be easy enough to swap one off another car?
PostSubject: Re: Radiator emissions stickers?   Fri Sep 10, 2010 1:04 am
Just swap the radiator cover with one that is the same year and has the 5.7 It's only held on by 4 screws. Just make sure you supprt the radiator while switching covers.
PostSubject: Re: Radiator emissions stickers?   Fri Sep 10, 2010 3:34 am
Its not on that. It's on the radiator support.
PostSubject: Re: Radiator emissions stickers?   Fri Sep 10, 2010 8:14 am
Best bet is to just remove it, i don't think ive see any repos, and its doubtful you would get it off another car. But your welcome to try to get one up here.
PostSubject: Re: Radiator emissions stickers?   Fri Sep 10, 2010 8:51 am
oooooooohhhhh. Well my advice is void then Laughing
You could always swap radiator supports
PostSubject: Re: Radiator emissions stickers?   Fri Sep 10, 2010 8:57 am
^ good point! ^
PostSubject: Re: Radiator emissions stickers?   Fri Sep 10, 2010 6:20 pm
Maybe cut one out of a junker and rivet it in over the old one? As long as you don't drill into the radiator itself lol.
PostSubject: Re: Radiator emissions stickers?   Fri Sep 10, 2010 11:19 pm
Anyone know how to turn a good quality pic into a weatherproof sticker?
I'm thinking thats the olny way a sticker that old can be relocated
PostSubject: Re: Radiator emissions stickers?   Sat Sep 11, 2010 12:00 am
There are machines at the craft stores that can do it. There are also places that can make them up as a vinyl graphic. Or you could always print it out on sticky paper like that used for inspection stickers and then spray a few coats of clear over it. The factory method is just to use a regular sticker with a high gloss face. When you order the air pump delete sticker it makes sense how they do it at GM.
JaySS
PostSubject: Re: Radiator emissions stickers?   Sat Sep 11, 2010 7:43 am
PostSubject: Re: Radiator emissions stickers?   Sat Sep 11, 2010 7:46 am
Well there you go cheers
All you had to do was ask (the right guy Laughing )
Now I have to look at my car & see if its 1 of those
» Lower radiator hose came flying off
» Stickers 'n stuff
» Classic Radiator from Ebay
» Stickers For A Lego Racers Ferrari
» badass stickers
