| SEM for Caprice Gray? | |
+4mean ss Tomz9C1 silverfox103 Cadet57 8 posters |
| Subject: SEM for Caprice Gray? Wed Sep 08, 2010 7:44 pm | |
| Anyone know what the matching SEM is for the '93 Gray? Someone said its the "Medium Gray" but according to the chart, it looks too dark. #15803 "Opel Gray" looks like it would work thou.
http://ep.yimg.com/ca/I/yourautotrim-store_2121_189664597 | |
| Subject: Re: SEM for Caprice Gray? Wed Sep 08, 2010 11:52 pm | |
| Justin, call VinylPro: http://www.vinylpro.com/
They can custom mix SEM colors. This may be your grey color.
Ruby Red GM code 79I = SEM 4791 Light Beige (Tan) GM code 64I= SEM 4693 Light Grey (SS Grey) GM code 14I= SEM 4698 Med DRK Adriatic Blue (94 to 96 Police car blue) GM code 30I= SEM 4820
Tom | |
| Subject: Re: SEM for Caprice Gray? Thu Sep 09, 2010 12:16 am | |
| Med DRK Adriatic Blue (94 to 96 Police car blue) GM code 30I= SEM 4820 This what I was looking for to do my 12 ways, nice! I didn't have to go far! Thanks Tom. | |
| Subject: Re: SEM for Caprice Gray? Thu Sep 09, 2010 7:01 am | |
| - Tomz9C1 wrote:
- Med DRK Adriatic Blue (94 to 96 Police car blue) GM code 30I= SEM 4820
This what I was looking for to do my 12 ways, nice! I didn't have to go far! Thanks Tom. It is a perfect match, I used it on my console and door panel repairs. Tom | |
| Subject: Re: SEM for Caprice Gray? Thu Sep 09, 2010 5:02 pm | |
| Tom,
Is that SEM 4698 a custom number? I can't find that online or at Vinyl Pro. I emailed them so hopefully they can tell me. | |
| Subject: Re: SEM for Caprice Gray? Thu Sep 09, 2010 5:26 pm | |
| medium grey (#15393) is for the Impalas 94-96 | |
| Subject: Re: SEM for Caprice Gray? Thu Sep 09, 2010 5:45 pm | |
| - mean ss wrote:
- medium grey (#15393) is for the Impalas 94-96
Yeah, thats the color someone on Longroof gave me, but it looks too dark to match mine. | |
| Subject: Re: SEM for Caprice Gray? Thu Sep 09, 2010 5:51 pm | |
| Hi Justin
Yes that is a custom color, which they mix, you will not find it on the chart. Call them up, they are real helpful.
Tom C. | |
| Subject: Re: SEM for Caprice Gray? Thu Sep 09, 2010 6:02 pm | |
| - Cadet57 wrote:
Yeah, thats the color someone on Longroof gave me, but it looks too dark to match mine. You never realize how much the sun fades colors until you get a sample of the original. I'm guessing that color probably is the right one and it'll match up well to the back of the door panels and such. | |
| Subject: Re: SEM for Caprice Gray? Mon Oct 04, 2010 6:54 pm | |
| Ok, Talked to Vinyl Pro. He said I need SEM 17123. He's trying to get a matching number for the Color Coat series so I can shoot my plastic dash piece and my vinyl seats. But looking at the chart online, 17123 still looks too dark. | |
| Subject: Re: SEM for Caprice Gray? Mon Oct 04, 2010 7:54 pm | |
| i spray a lot of interiors at the dealership..... all the SEM colors look darker but usually dry to a lighter tone. apply in light coats, allowing each coat to dry before the next is applied. dont spray to heavy it will cause headaches!!!!.......
..... also robbins auto parts stores will custom mix spray cans to what you need | |
| Subject: Re: SEM for Caprice Gray? Mon Oct 04, 2010 8:05 pm | |
| - bowtiepimp wrote:
- i spray a lot of interiors at the dealership..... all the SEM colors look darker but usually dry to a lighter tone.
..... also robbins auto parts stores will custom mix spray cans to what you need I will add to this. Wash with a mild degreaser soap like "dawn", and a fine scotchbrite pad. But do not get too wet. After it dries, wipe it again with a wax and grease remover on a rag. Then you are ready to paint. First coat should be just a dusct coat to cover the old color. I would give it 3 even coats with a half hour in between coats. |
| Subject: Re: SEM for Caprice Gray? Mon Oct 04, 2010 8:16 pm | |
..... also robbins auto parts stores will custom mix spray cans to what you need I will add to this. Wash with a mild degreaser soap like "dawn", and a fine scotchbrite pad. But do not get too wet. After it dries, wipe it again with a wax and grease remover on a rag. Then you are ready to paint. First coat should be just a dusct coat to cover the old color. I would give it 3 even coats with a half hour in between coats. I scrubbed the seats down today with Simple green to get all the moldy/gross bits off then hit them with leather and vinyl cleaner. Should I scrub them with Dawn next? | |
| Subject: Re: SEM for Caprice Gray? Mon Oct 04, 2010 8:24 pm | |
..... also robbins auto parts stores will custom mix spray cans to what you need I will add to this. Wash with a mild degreaser soap like "dawn", and a fine scotchbrite pad. But do not get too wet. After it dries, wipe it again with a wax and grease remover on a rag. Then you are ready to paint. First coat should be just a dusct coat to cover the old color. I would give it 3 even coats with a half hour in between coats. I scrubbed the seats down today with Simple green to get all the moldy/gross bits off then hit them with leather and vinyl cleaner. Should I scrub them with Dawn next? Yes. Then get some wax and grease remover or even some mineral spirits and wipe it down. You want a very good base for the paint to stick too. Especialy on a seat. |
| Subject: Re: SEM for Caprice Gray? Mon Oct 04, 2010 8:28 pm | |
..... also robbins auto parts stores will custom mix spray cans to what you need I will add to this. Wash with a mild degreaser soap like "dawn", and a fine scotchbrite pad. But do not get too wet. After it dries, wipe it again with a wax and grease remover on a rag. Then you are ready to paint. First coat should be just a dusct coat to cover the old color. I would give it 3 even coats with a half hour in between coats. I scrubbed the seats down today with Simple green to get all the moldy/gross bits off then hit them with leather and vinyl cleaner. Should I scrub them with Dawn next? Yes. Then get some wax and grease remover or even some mineral spirits and wipe it down. You want a very good base for the paint to stick too. Especialy on a seat. Will do, if Vinyl Pro gets back to me, I wanna order the SEM this week as I want the seats in for Roundup. Im just worried that i'm going to spray the seats and they wont match the rears and my OCD will kick in and it'll all be downhill from there | |
| Subject: Re: SEM for Caprice Gray? Tue Oct 05, 2010 2:36 pm | |
| Mike from Vinyl Pro called me back. Turns out 17123 equals this code: - silverfox103 wrote:
- Light Grey (SS Grey) GM code 14I= SEM 4698
Just ordered 3 cans, will be here by next week. Seats may just go in for roundup | |
| Subject: Re: SEM for Caprice Gray? Tue Oct 05, 2010 2:56 pm | |
| - Cadet57 wrote:
- Mike from Vinyl Pro called me back. Turns out 17123 equals this code:
Just ordered 3 cans, will be here by next week. Seats may just go in for roundup is your gray different than the Impala gray? FYI it took me 2 cans of black just to do my dash pad | |
| Subject: Re: SEM for Caprice Gray? Tue Oct 05, 2010 3:04 pm | |
Just ordered 3 cans, will be here by next week. Seats may just go in for roundup is your gray different than the Impala gray? FYI it took me 2 cans of black just to do my dash pad Not by much, if any from what I can tell. He recommended 2-3 cans for the seats. So I went with 3 just to be safe. If I need more, then so be it, but hopefully i'll have enough. | |
| Subject: Re: SEM for Caprice Gray? Tue Oct 12, 2010 2:27 pm | |
| Ordered my SEM from Vinyl Pro. Got here today. Started shooting the seats. Got the first one done. Dam it looks good. Almost a perfect flippin match too. Wicked happy. | |
| Subject: Re: SEM for Caprice Gray? Tue Oct 12, 2010 2:36 pm | |
| Sweet! Looking good |
| Subject: Re: SEM for Caprice Gray? Tue Oct 12, 2010 4:33 pm | |
| - Cadet57 wrote:
- Ordered my SEM from Vinyl Pro. Got here today. Started shooting the seats. Got the first one done. Dam it looks good. Almost a perfect flippin match too. Wicked happy.
Nice job. 1 can? | |
| Subject: Re: SEM for Caprice Gray? Tue Oct 12, 2010 4:55 pm | |
Nice job. 1 can? I ordered 3 cans. It was a can per seat. 3/4 of the 3rd can did the dash surround and a Riviera console. I'm taking a break as the fumes, even with both garage doors open and a fan going gave me a headache... | |
| Subject: Re: SEM for Caprice Gray? Tue Oct 12, 2010 5:28 pm | |
| Subject: Re: SEM for Caprice Gray? | |
