| WTB 9C1 Gray Buckets | |
+6No Moa toomanytoyz bammax Waldo617 GasTT Cadet57 10 posters |
| Subject: WTB 9C1 Gray Buckets Wed Sep 08, 2010 3:57 pm | |
| Bought a Riveria console and am looking for 9C1 Buckets, or a passenger side civillian '93 gray seat. Both need to be powered | |
| Subject: Re: WTB 9C1 Gray Buckets Wed Sep 08, 2010 4:00 pm | |
| Just modify your existing drivers seat! | |
| Subject: Re: WTB 9C1 Gray Buckets Wed Sep 08, 2010 4:01 pm | |
| - GasTT wrote:
- Just modify your existing drivers seat!
How?! No srsly, if I can, Id do that | |
Waldo617
| Subject: power seat racks Wed Sep 08, 2010 4:04 pm | |
| i have power seat racks that i took off of my buckets that you can have if you need them... | |
| Subject: Re: WTB 9C1 Gray Buckets Wed Sep 08, 2010 4:07 pm | |
| That too, if you find a non power seat just make it power by using your stock rail. Also, there is a topic on here somewhere showing crovos seat getting modded for the floor shift console. You basically remove the seat cut the extra foam and bar off the inside and tuck the extra fabric underneath. The mess will be hidden by the console. You could get all fancy and trim the fabric and sew it nice nice.... | |
| Subject: Re: WTB 9C1 Gray Buckets Wed Sep 08, 2010 4:10 pm | |
| - GasTT wrote:
- Also, there is a topic on here somewhere showing crovos seat getting modded for the floor shift console. You basically remove the seat cut the extra foam and bar off the inside and tuck the extra fabric underneath. The mess will be hidden by the console. You could get all fancy and trim the fabric and sew it nice nice....
Sweet. I'll just do that then. Thou there were like 5 Bonnies at the yard today and almost all of them had nice seats... | |
| Ask Billy. He's done it before I think | |
| Subject: Re: WTB 9C1 Gray Buckets Wed Sep 08, 2010 4:12 pm | |
| Bonnies will require custom made brackets or the swapping of your stock rails + wiring. | |
| Subject: Re: WTB 9C1 Gray Buckets Wed Sep 08, 2010 4:16 pm | |
| - GasTT wrote:
- Bonnies will require custom made brackets or the swapping of your stock rails + wiring.
Eww, no. I wanna do as little wiring as possible lol. I'll just cut and sew my seat. Seems the easiest and cheapest. | |
| Subject: Re: WTB 9C1 Gray Buckets Wed Sep 08, 2010 4:19 pm | |
| - Cadet57 wrote:
Eww, no. I wanna do as little wiring as possible lol. I'll just cut and sew my seat. Seems the easiest and cheapest. Wiring IF they are 12-way. The only wiring is power and ground, not a big deal. You also have to tap into the dimmer switch if you want the controls to light up. It's worth it. | |
| Subject: Re: WTB 9C1 Gray Buckets Wed Sep 08, 2010 4:22 pm | |
| Actually, the 6 way bonnies bolt right in. Swap your rails to them and you're in business. I have the dark grey set out of my Impala. $75 and they're yours. | |
| Subject: Re: WTB 9C1 Gray Buckets Wed Sep 08, 2010 4:31 pm | |
| Only problem is none of the stock bonnies would really match my light gray interior (yes I am that anal about it) They can't be dyed can they? | |
| Subject: Re: WTB 9C1 Gray Buckets Wed Sep 08, 2010 4:35 pm | |
| Why can't they? Anything can be dyed. Is it worth it? Probably not, unless your interior is absolutely mint, in that case I would modify my factory seat. | |
| Subject: Re: WTB 9C1 Gray Buckets Wed Sep 08, 2010 4:52 pm | |
| - GasTT wrote:
- Why can't they? Anything can be dyed. Is it worth it? Probably not, unless your interior is absolutely mint, in that case I would modify my factory seat.
Minus the carpets and a small crack on the dash pad, everything else is super clean and in good shape. I think I might just mod the factory seat. | |
| Subject: Re: WTB 9C1 Gray Buckets Wed Sep 08, 2010 4:55 pm | |
| If you think your interior is clean, let me clean it for you then you will be amazed. | |
| Subject: Re: WTB 9C1 Gray Buckets Wed Sep 08, 2010 5:11 pm | |
| Let me know, I used to keep my 92 immaculate. Here's a clean light gray interior for ya. | |
| Subject: Re: WTB 9C1 Gray Buckets Wed Sep 08, 2010 5:29 pm | |
| *Looks at interior and now thinks its not as clean as it could be* | |
| Subject: Re: WTB 9C1 Gray Buckets Wed Sep 08, 2010 5:56 pm | |
| The light grey cloth bonnies, and even the leather ones, are a very good match for the grey interiors. | |
| Subject: You need this. Wed Sep 08, 2010 6:55 pm | |
| Subject: Re: WTB 9C1 Gray Buckets Wed Sep 08, 2010 7:03 pm | |
| And here I was just going to cut open the fabric, cut the frame with a Sawzall and sew it back up. | |
| Subject: Re: WTB 9C1 Gray Buckets Wed Sep 08, 2010 7:09 pm | |
| - Cadet57 wrote:
Sweet. I'll just do that then. Thou there were like 5 Bonnies at the yard today and almost all of them had nice seats... Dude, if you go back, I need a 12 way bonnie seat switch! Mine was lost. | |
| Subject: Re: WTB 9C1 Gray Buckets Wed Sep 08, 2010 7:13 pm | |
| - No Moa wrote:
- Cadet57 wrote:
Sweet. I'll just do that then. Thou there were like 5 Bonnies at the yard today and almost all of them had nice seats... Dude, if you go back, I need a 12 way bonnie seat switch! Mine was lost. I might go back this week. I *think* I saw one with a 12 way. Those are the ones with the switches in the console right? | |
| Subject: Re: WTB 9C1 Gray Buckets Wed Sep 08, 2010 10:43 pm | |
| Steering wheels and shifters always get nasty black dead skin stuck on them. It is dirty and sticky. I cannot drive with that crap on my interior. | |
| Subject: Re: WTB 9C1 Gray Buckets Wed Sep 08, 2010 11:08 pm | |
| I used some spacers on the rear bolts so the seat will move all the way back and not hang up on the floor. Other than that they fit just fine on the Caprice rails. | |
| Subject: Re: WTB 9C1 Gray Buckets Thu Sep 09, 2010 8:08 am | |
| - Cadet57 wrote:
- No Moa wrote:
- Cadet57 wrote:
Sweet. I'll just do that then. Thou there were like 5 Bonnies at the yard today and almost all of them had nice seats... Dude, if you go back, I need a 12 way bonnie seat switch! Mine was lost. I might go back this week. I *think* I saw one with a 12 way. Those are the ones with the switches in the console right? Yes!!! pease check it out. | |
| Subject: Re: WTB 9C1 Gray Buckets Thu Sep 09, 2010 8:10 am | |
| - Cadet57 wrote:
Sweet. I'll just do that then. Thou there were like 5 Bonnies at the yard today and almost all of them had nice seats... How much did they want for them and did they have the 12 way controller? | |
| Subject: Re: WTB 9C1 Gray Buckets Thu Sep 09, 2010 9:40 am | |
| If you see any light gray ones, I need a driver side upper skin (as a minimum) Post up, we may need to road trip based on your sighting of 5 with good seats I dont need the controller so maybe this'll all work out.
| Subject: Re: WTB 9C1 Gray Buckets Thu Sep 09, 2010 10:20 am | |
| I'm at work on my phone so ill post a full reply when I get home. But for now ill say that there was at least 1 car with 12 ways. They were mostly black and tan. No light grau. One tan leatheer. I dunno about shape but I diddnt szee any with tears. Not sure on prices. He once quoted me $200 for a set of rms seats so idk. | |
| Subject: Re: WTB 9C1 Gray Buckets Thu Sep 09, 2010 3:33 pm | |
| I paid about $40 @ Harry's u-pull it in Hazelton, PA A few yrs back, but you have to buy two sets to get one good one. My original 12 ways I got installed by Karl Malone back in 2006 for about $300? They were (and still are) ripped and taupe colored I guess? But I was happier than a pig in slop!
| Subject: Re: WTB 9C1 Gray Buckets Thu Sep 09, 2010 4:52 pm | |
| Ok, here's the full rundown of the Bonnies that I saw.
1 Tan leather. 6 way, iirc 2 Charcoal, 1 was manual, not sure on the other 1 blue/gray, 12 ways 1 tan cloth (I think, looked quick) 6 way.
Like I said, not 100% sure on prices, he once quoted me $200 for a RMS set. But maybe if we pull them all he'll cut us a deal. Idk. | |
| Subject: Re: WTB 9C1 Gray Buckets | |
