 Fraking scan tools
PostSubject: Fraking scan tools   Thu Sep 02, 2010 9:03 pm
I bought an obd1 cable today for my laptop from obd electronics, this is the one everyone said was good. I set it up, the cable works great, but the phucking ddt and freescan aren't working. WTF. Freescan said I have a code 26, CCP electric something, all I found was a quad driver problem. So I don't know wth is wrong.
I can't get any real time data. I set it up for 94-95 lt1 impala. I'm stumped. Sound I just buy a laptop version? Pisses me off, 65 for a cable that does very little.
PostSubject: Re: Fraking scan tools   Thu Sep 02, 2010 9:41 pm
More description please. Where did you get the cable from? Are you using a pc, or laptop? if laptop, is it plugged into lighter 12 volt dc, or 120volt ac. How long is the extension cord? How long is the cable?
PostSubject: Re: Fraking scan tools   Thu Sep 02, 2010 10:04 pm
http://www.aldlcable.com/sc/details.asp?item=aldlobd1u
This is the cable I bought. Laptop was not plugged in, Dell, windows xp.
PostSubject: Re: Fraking scan tools   Thu Sep 02, 2010 10:10 pm
did you try datamaster ? I never had any luck with freescan
Maybe a software install issue? I'd try removing the software and doing a full reinstall then any updates or anything that are needed before plugging the cable into the laptop. Windows likes to guess at what you're plugging in and use default drivers if you plug things in without installing the software first.
PostSubject: Re: Fraking scan tools   Fri Sep 03, 2010 6:26 am
The free trial of datamaster does nothing. They come free on the disc. Anyone know what the code 26 is?
PostSubject: Re: Fraking scan tools   Fri Sep 03, 2010 9:04 am
26= ECM detected the wrong potential voltage at the #1 quad-driver module circuit for 20 seconds.
http://www.troublecodes.net/articles/quaddriver.shtml
I'm checking this out (trying to educate myself)
PostSubject: Re: Fraking scan tools   Fri Sep 03, 2010 9:09 am
Cool thanks. I'll have to read it. Need a fix that light drives me nuts
PostSubject: Re: Fraking scan tools   Fri Sep 03, 2010 9:18 am
Is this a known good ECM?
Look at post #4 here
http://www.impalassforum.com/vBulletin/showthread.php?t=236826
I grabbed the DTC description from here:
http://www.troublecodes.net/GM/95_57P.shtml
which is specific for our cars
Still looking
PostSubject: Re: Fraking scan tools   Fri Sep 03, 2010 9:30 am
Check your email
Still looking
PostSubject: Re: Fraking scan tools   Fri Sep 03, 2010 2:26 pm
I'm getting info that says up to 93 the air pump, egr & evap solenoid is DTC 26.
94-95 is JUST evap purge solenoid
Fraking scan tools
» Fraking scan tools
» PokeTech Tools
» Hobby Tools/Product Reviews
» Which brand of stainless tools are the very best?
» Disinfecting tools
